Part Number: TMS320F28035
struct COMPCTL_BITS { // bit description
Uint16 COMPDACEN:1; // 0 Comparator/DAC Enable
Uint16 COMPSOURCE:1; // 1 Source select for comparator inverting input
Uint16 CMPINV:1; // 2 Invert select for Comparator
Uint16 QUALSEL:5; // 7:03 Qualification Period for synchronized output of the comparator
Uint16 SYNCSEL:1; // 8 Synchronization select for output of the comparator
Uint16 rsvd1:7; // 15:09 reserved
union COMPCTL_REG {
Uint16 all;
struct COMPCTL_BITS bit;
struct COMPSTS_BITS { // bit description
Uint16 COMPSTS:1; // 0 Logical latched value of the comparator
Uint16 rsvd1:15; // 15:01 reserved
union COMPSTS_REG {
Uint16 all;
struct COMPSTS_BITS bit;
struct DACCTL_BITS { // bits description
Uint16 DACSOURCE:1; // 0 DAC source control bits.
Uint16 RAMPSOURCE:4; // 4:01 Ramp generator source control bits
Uint16 rsvd1:9; // 13:05 reserved
Uint16 FREE_SOFT:2; // 15:14 Debug Mode Bit
union DACCTL_REG {
Uint16 all;
struct DACCTL_BITS bit;
struct DACVAL_BITS { // bit description
Uint16 DACVAL:10; // 9:00 DAC Value bit
Uint16 rsvd1:6; // 15:10 reserved
union DACVAL_REG {
Uint16 all;
struct DACVAL_BITS bit;
// Comparator Register Definitions
struct COMP_REGS {
union COMPCTL_REG COMPCTL;
Uint16 rsvd1;
union COMPSTS_REG COMPSTS;
Uint16 rsvd2;
union DACCTL_REG DACCTL;
Uint16 rsvd3;
union DACVAL_REG DACVAL;
Uint16 rsvd4;
Uint16 RAMPMAXREF_ACTIVE;
Uint16 rsvd5;
Uint16 RAMPMAXREF_SHDW;
Uint16 rsvd6;
Uint16 RAMPDECVAL_ACTIVE;
Uint16 rsvd7;
Uint16 RAMPDECVAL_SHDW;
Uint16 rsvd8;
Uint16 RAMPSTS;
Uint16 rsvd9[3];
// Comparator External References and Function Declarations
extern volatile struct COMP_REGS Comp1Regs;
extern volatile struct COMP_REGS Comp2Regs;
extern volatile struct COMP_REGS Comp3Regs;
#ifdef __cplusplus
#endif /* extern "C" */
#endif // end of DSP2803x_COMP_H definition
// End of file
在参照例程编写使用28035的COMP模块的斜坡发生器时,我发现DSP2803X_COMP.h文件中DACCTL寄存器没有被定义,于是我对照2802X文件中的comp.h文件重新定义了DACCTL寄存器,请问这样编写可以吗,是否还需要进行其他操作。
