TMS320F28035: 自己做的最小系统,程序就是编译没问题,仿真器连接正常,就是下不进去程序,请大佬帮帮忙看一下哪里出问题了
Part Number: TMS320F28035
这是CCS10.4报的错误:
C28xx: Failed CPU Reset: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.4.0.00129)
C28xx: Trouble Reading Register PC: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.4.0.00129)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.4.0.00129)
C28xx: GEL: Error while executing OnReset(-1): Target failed to read register ST1
at (ST1&~(0x0100)) [f28035.gel:292]
at C28x_Mode() [f28035.gel:32]
at OnReset(-(1))
C28xx: GEL: Error while executing OnTargetConnect(): Reset failed: retcode=-1
at GEL_Reset() [f28035.gel:92]
at OnTargetConnect()
C28xx: Flash Programmer: Warning: The configured device (TMS320F28035), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Failed CPU Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.4.0.00129)
at OnReset(-(1))
C28xx: GEL: Error calling OnPreFileLoaded(): Reset failed: retcode=-1
C28xx: Trouble Writing Memory Block at 0x0 on Page 0 of Length 0x2: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 9.4.0.00129)
C28xx: File Loader: Verification failed: Target failed to write 0x00000@Program
C28xx: GEL: File: E:\CCSworkspace\test_ccs_project\Debug\test_ccs_project.out: Load failed.
