MatrixMUL(float* A, int A_Row,int A_Col, float* B,int B_Row, int B_Col, float *Result)
int i,j,k;
float sum;
if(A_Col == B_Row) // dimensions of matrixes must be accordance with each other
for( i = 0; i < A_Row; i++) // compute the first row of results
for(j = 0; j < B_Col; j++)
sum = 0.0f;
for(k = 0; k < A_Col; k++)
sum += (*(A + i*A_Col + k))*( *(B + k*B_Col + j));
//sum = sum + temp;
*(Result + i*B_Col + j) = sum;
在一个工程里运行,出现如下错误,
"C:\Users\User\AppData\Local\Temp\0912810", ERROR! at line 754: [E0004] Illegal operand combination
MACF32 R7H,R3H,*XAR0++,*XAR7 ; [CPU_] |146|
1 Assembly Error, No Assembly Warnings
Errors in Source - Assembler Aborted
是什么原因?
