TMS320F280049C: SPLL_1PH_SOGI_FLL_run()锁相环中 FLL功能模块执行原理或依据是什么
Part Number: TMS320F280049C
TI 案列 C:\ti\c2000\C2000Ware_DigitalPower_SDK_4_02_00_00\solutions\tidm_02008中锁相环 SPLL_1PH_SOGI_FLL_run()函数执行如下:
static inline void SPLL_1PH_SOGI_FLL_run(SPLL_1PH_SOGI_FLL *spll_obj,
float32_t acValue)
float32_t osgx,osgy,temp;
// Update the spll_obj->u[0] with the grid value
spll_obj->u[0]=acValue;
// Orthogonal Signal Generator
spll_obj->osg_u[0]=(spll_obj->osg_coeff.osg_b0*
(spll_obj->u[0]-spll_obj->u[2])) +
(spll_obj->osg_coeff.osg_a1*spll_obj->osg_u[1]) +
(spll_obj->osg_coeff.osg_a2*spll_obj->osg_u[2]);
spll_obj->osg_u[2]=spll_obj->osg_u[1];
spll_obj->osg_u[1]=spll_obj->osg_u[0];
spll_obj->osg_qu[0]=(spll_obj->osg_coeff.osg_qb0*spll_obj->u[0]) +
(spll_obj->osg_coeff.osg_qb1*spll_obj->u[1]) +
(spll_obj->osg_coeff.osg_qb2*spll_obj->u[2]) +
(spll_obj->osg_coeff.osg_a1*spll_obj->osg_qu[1]) +
(spll_obj->osg_coeff.osg_a2*spll_obj->osg_qu[2]);
spll_obj->osg_qu[2]=spll_obj->osg_qu[1];
spll_obj->osg_qu[1]=spll_obj->osg_qu[0];
spll_obj->u[2]=spll_obj->u[1];
spll_obj->u[1]=spll_obj->u[0];
// Park Transform from alpha beta to d-q axis
spll_obj->u_Q[0]=(spll_obj->cosine*spll_obj->osg_u[0]) +
(spll_obj->sine*spll_obj->osg_qu[0]);
spll_obj->u_D[0]=(spll_obj->cosine*spll_obj->osg_qu[0]) -
(spll_obj->sine*spll_obj->osg_u[0]);
// Loop Filter
spll_obj->ylf[0]=spll_obj->ylf[1] +
(spll_obj->lpf_coeff.b0*spll_obj->u_Q[0]) +
(spll_obj->lpf_coeff.b1*spll_obj->u_Q[1]);
spll_obj->ylf[1]=spll_obj->ylf[0];
//spll_obj->ylf[0] = (spll_obj->ylf[0]>0.5)?0.5:spll_obj->ylf[0];
//spll_obj->ylf[0] = (spll_obj->ylf[0]<-0.5)?-0.5:spll_obj->ylf[0];
spll_obj->u_Q[1]=spll_obj->u_Q[0];
// VCO
spll_obj->fo=spll_obj->fn+spll_obj->ylf[0];
spll_obj->theta=spll_obj->theta + (spll_obj->fo*spll_obj->delta_t)*
(float32_t)(2.0*3.1415926f);
if(spll_obj->theta>(float32_t)(2.0*3.1415926f))
spll_obj->theta=spll_obj->theta-(float32_t)(2.0*3.1415926f);
spll_obj->sine=(float32_t)sinf(spll_obj->theta);
spll_obj->cosine=(float32_t)cosf(spll_obj->theta);
// FLL
spll_obj->ef2 = ((spll_obj->u[0] - spll_obj->osg_u[0])*spll_obj->osg_qu[0])
* spll_obj->gamma * spll_obj->delta_t*-1.0f;
spll_obj->x3[0]=spll_obj->x3[1] + spll_obj->ef2;
//spll_obj->x3[0]= (spll_obj->x3[0]>1.0)?1.0:spll_obj->x3[0];
//spll_obj->x3[0]= (spll_obj->x3[0]<-1.0)?-1.0:spll_obj->x3[0];
spll_obj->x3[1]=spll_obj->x3[0];
spll_obj->w_dash = spll_obj->wc + spll_obj->x3[0];
spll_obj->fn = spll_obj->w_dash / (2.0*3.1415926f);
osgx = (float32_t)(2.0f*spll_obj->k*spll_obj->w_dash*spll_obj->delta_t);
osgy = (float32_t)(spll_obj->w_dash * spll_obj->delta_t * spll_obj->w_dash *
spll_obj->delta_t);
temp = (float32_t)1.0f/(osgx+osgy+4.0f);
spll_obj->osg_coeff.osg_b0=((float32_t)osgx*temp);
spll_obj->osg_coeff.osg_b2=((float32_t)(-1.0f)*spll_obj->osg_coeff.osg_b0);
spll_obj->osg_coeff.osg_a1=((float32_t)(2.0f*(4.0f-osgy))*temp);
spll_obj->osg_coeff.osg_a2=((float32_t)(osgx-osgy-4)*temp);
spll_obj->osg_coeff.osg_qb0=((float32_t)(spll_obj->k*osgy)*temp);
spll_obj->osg_coeff.osg_qb1=(spll_obj->osg_coeff.osg_qb0*(float32_t)(2.0));
spll_obj->osg_coeff.osg_qb2=spll_obj->osg_coeff.osg_qb0;
红色部分FLL模块,用于实时更新OSGI的系数(b0、b1、a1、a2、qb0、qb1、qb2),我想知道FLL计算过程的原理或依据是什么?
我在《Software Phase Locked Loop Design Using C2000Tm Microcontrollers for Single Phase Grid Connected Inverter
》中没有找到相关的描述。
