Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
sysconfig(1.17.0)中配置文件中的deviceData中F2838x.json似乎有问题。
parts节点中的“ID_501”(176pin)和“ID_500”(337bga)位置应该调换,否则在使用337bga款时,会被当做176pin,在设置IO端口#100以上(除#133,因为176pin有#133)时sysconfig会出错,提示没有此端口。
参考下工程师的回复:
Can you share what you are trying to do with the SysConfig tool?
I think the issue may be something else. If the part/package info was not correct non of our validation would pass. I think we are missing something else.
The order in which they are in the "parts" entry should not even matter.
Now this is my guess:
I think you are using CCS and you change the DEVICE in SysConfig and when you BUILD the project you are running into error messages.
Which I believe stems from this: https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1130472/faq-how-do-i-use-the-switch-button-in-c2000-sysconfig-within-a-ccs-project-to-change-my-device-package-or-switch-to-board-view
