Part Number: TMS320F280039C
void Epwm1Init()
EALLOW; //120kHz // Config for conventional PWM first EPwm1Regs.
TBCTL.bit.PRDLD = TB_SHADOW; // set TB_SHADOW load
EPwm1Regs.TBPRD = 632; // 120M/95K/2 = 632;
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;
EPwm1Regs.TBPHS.bit.TBPHS = 0;
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE ; // EPWM1 is the Master
EPwm1Regs.TBCTL.bit.PRDLD = 0;
EPwm1Regs.TBCTL2.bit.PRDLDSYNC = 1;
EPwm1Regs.EPWMSYNCOUTEN.bit.ZEROEN = 1;
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; // Note: ChB is initialized here only for comparison purposes, it is not required
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // optional
EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; // optional //
EPwm1Regs.AQCTLA.bit.CAD = AQ_SET; //
EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR; //
EPwm1Regs.AQCTLB.bit.CBD = AQ_CLEAR; // optional //
EPwm1Regs.AQCTLB.bit.CBU = AQ_SET; // optional
EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR ;
EPwm1Regs.AQCTLA.bit.CAD = AQ_SET ; //配置死区; //
EPwm1Regs.DBCTL.bit.IN_MODE = DBA_RED_DBB_FED; //
EPwm1Regs.DBCTL.bit.POLSEL = DBA_ALL; //
EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm1Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm1Regs.DBCTL.bit.POLSEL = DBA_RED_DBB_FED;
EPwm1Regs.DBFED.all = 96;//800ns
EPwm1Regs.DBRED.all = 96; //
HRPWM EPwm1Regs.HRCNFG.all = 0x0;
EPwm1Regs.HRCNFG.bit.EDGMODE = HR_BEP;
EPwm1Regs.HRCNFG.bit.CTLMODE = HR_CMP;
EPwm1Regs.HRCNFG.bit.HRLOAD = HR_CTR_ZERO_PRD;
EPwm1Regs.HRCNFG.bit.AUTOCONV = 1;
EPwm1Regs.HRPCTL.bit.HRPE = 1; EDIS;
void Epwm2Init()
EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW; // set TB_SHADOW load
EPwm2Regs.TBPRD = 632; // 120M/95K/2 = 632;
EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;
EPwm2Regs.TBPHS.bit.TBPHS = 0;
EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; // EPWM1 is the Master
EPwm2Regs.TBCTL.bit.PRDLD = 0;
EPwm2Regs.TBCTL2.bit.PRDLDSYNC = 1;
EPwm2Regs.EPWMSYNCINSEL.bit.SEL = 0x01;
EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1; // Note: ChB is initialized here only for comparison purposes, it is not required
EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // optional
EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; // optional
EPwm2Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EPwm2Regs.AQCTLA.bit.CAD = AQ_SET; //配置死区;
EPwm2Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm2Regs.DBCTL.bit.POLSEL = DBA_RED_DBB_FED;
EPwm2Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm2Regs.DBFED.all = 96;//800ns
EPwm2Regs.DBRED.all = 96; //
HRPWM EPwm2Regs.HRCNFG.all = 0x0;
EPwm2Regs.HRCNFG.bit.EDGMODE = HR_BEP;
EPwm2Regs.HRCNFG.bit.CTLMODE = HR_CMP;
EPwm2Regs.HRCNFG.bit.HRLOAD = HR_CTR_ZERO_PRD;
EPwm2Regs.HRCNFG.bit.AUTOCONV = 1;
EPwm2Regs.HRPCTL.bit.HRPE = 1; EDIS;
