Part Number: LAUNCHXL-F2800137
LAUNCHXL-F2800137+DRV5353RS公版,电源采用24V5A输入,电机型号TB57BL115S21_230TF9,淘宝商家调试好的电机。软件使用ti\c2000\C2000Ware_MotorControl_SDK_4_02_01_00\solutions\universal_motorcontrol_lab\f280013x,根据TI的spruj26-Universal Motor Control Project and Lab User’s Guide开发文档,设置#define DMC_BUILDLEVEL DMC_LEVEL_2,debug中设置motorVars_M1.flagEnableRunAndIdentify=true,启动电机后电机转速慢,并且噪音大,震动大。设置目标转速motorVars_M1.speedRef_Hz = 60.0f,实际转速只有3HZ左右。请贵司帮忙分析电机转动异常原因。感谢支持!
