Part Number: TMS320F28035
28035 串口升级BIN文件后无法跳转。
使用二次BootLoader升级程序,通过串口升级应用程序,发现无法跳转到APP。使用仿真器烧录APP程序,则可以正常跳转。通过仿真对比烧录器烧录APP 和 串口升级烧录完成后的Memory Browser APP地址数据,数据完全一致,可见SCI烧录正常的。重新上电依然无法调整
bootlaoder CMD 文件
-heap 0x400
MEMORY
PAGE 0: /* Program Memory */
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
RAM_BOOTPROG : origin = 0x008000, length = 0x000020 /* on-chip RAM block L0, bootloader 中对时间敏感函数 */
RAM_PROG : origin = 0x008020, length = 0x000520 /* on-chip RAM block L0, bootloader 数据接收缓存区,1313byte,每次接收1Kb */
RAM_CLAPRG : origin = 0x009000, length = 0x001000 /* For CLA */
OTP : origin = 0x3D7800, length = 0x000400 /* on-chip OTP */
Flash_EEPROM : origin = 0x3E8000, length = 0x002000 /* Flash EEPROM 扇区H */
APP_VER : origin = 0x3EA000, length = 0x000010 /* 应用程序版本号 ,16Byte*/
FLASH_APPPROG : origin = 0x3EA010, length = 0x00A000 /* 应用程序存储空间,40Kb */
APP_START : origin = 0x3F5FFC, length = 0x000002 /* 应用程序入口 2Byte */
BOOT_VER : origin = 0x3F6000, length = 0x000002 /* Bootloader 程序版本号 */
FLASH_BOOTRAM : origin = 0x3F6002, length = 0x000020 /* FLASH 操作函数存储空间 */
FLASH_RTS : origin = 0x3F6022, length = 0x00032E /* RTS库空间 */
BOOT_UPDATE : origin = 0x3F6350, length = 0x000002 /* bootloader 升级入口地址*/
BOOT_RESET : origin = 0x3F6352, length = 0x000002 /* bootloader 复位入口地址*/
FLASH_BOOT : origin = 0x3F6354, length = 0x001400 /* bootloader 程序存储空间 5kB */
CSM_RSVD : origin = 0x3F7F80, length = 0x000076 /* Bootloader :9/14 */
BEGIN : origin = 0x3F7FF6, length = 0x000002 /* Bootloader :10/14 */
CSM_PWL_P0 : origin = 0x3F7FF8, length = 0x000008 /* Bootloader :11/14 */
IQTABLES : origin = 0x3FE000, length = 0x000B50 /* IQ Math Tables in Boot ROM */
IQTABLES2 : origin = 0x3FEB50, length = 0x00008C /* IQ Math Tables in Boot ROM */
IQTABLES3 : origin = 0x3FEBDC, length = 0x0000AA /* IQ Math Tables in Boot ROM */
ROM : origin = 0x3FF27C, length = 0x000D44 /* Boot ROM */
RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM */
VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM */
PAGE 1 : /* Data Memory */
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
/* Registers remain on PAGE1 */
BOOT_RSVD : origin = 0x000000, length = 0x000050 /* Part of M0, BOOT rom will use this for stack */
RAMM0 : origin = 0x000050, length = 0x0003B0 /* on-chip RAM block M0 */
RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
RAM_DATA : origin = 0x008540, length = 0x000AC0 /* For .ebss */
CLA2CPU : origin = 0x001480, length = 0x000080 /* CLA1_MSGRAMLOW */
CPU2CLA : origin = 0x001500, length = 0x000080 /* CLA1_MSGRAMHIGH */
FLASH_BOOTDATA : origin = 0x3F7754, length = 0x00082C /* BootLoader数据空间 ,共计2.04Kb*/
FLASH_APPDATA : origin = 0x3F4010, length = 0x001FEC /* 应用程序数据空间 ,共计7.98Kb*/
APP_CHECK : origin = 0x3F5FFE, length = 0x000001 /* 应用升级标志 */
JTAG_FLAG : origin = 0x3F5FFF, length = 0x000001 /* JTAG 仿真标志 */
/* Allocate sections to memory blocks.
Note:
codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
execution when booting to flash
ramfuncs user defined section to store functions that will be copied from Flash into RAM
SECTIONS
/* Bootloader :14/14 */
codestart : > BEGIN, PAGE = 0
UpdateEntry : > BOOT_UPDATE, PAGE = 0
BootReset : > BOOT_RESET, PAGE = 0
FlashBoot : > FLASH_BOOT, PAGE = 0
RamBoot : LOAD = FLASH_BOOTRAM,
RUN = RAM_BOOTPROG,
LOAD_START(_RamBootLoadStart),
LOAD_END(_RamBootLoadEnd),
RUN_START(_RamBootRunStart),
PAGE = 0
Rts : LOAD = FLASH_RTS, PAGE = 0
-lrts2800_ml.lib <exit.obj _lock.obj> (.text)
-lrts2800_ml.lib <exit.obj _lock.obj> (.cinit)
BootVer : > BOOT_VER, PAGE = 0, ALIGN(4)
AppStart : > APP_START, PAGE = 0, ALIGN(4)
AppCheck : > APP_CHECK, PAGE = 1, ALIGN(4)
JtagFlag : > JTAG_FLAG, PAGE = 1, ALIGN(4)
/* Bootloader :14/14 End*/
/* Application Version*/
AppVer : > APP_VER, PAGE = 0, ALIGN(4)
/* Allocate program areas: */
//.cinit : > FLASH_BOOTDATA PAGE = 1, ALIGN(4)
.cinit : > FLASH_BOOT, PAGE = 0, ALIGN(4)
.pinit : > FLASH_BOOT, PAGE = 0, ALIGN(4)
.text : > FLASH_BOOT PAGE = 0, ALIGN(4)
ramfuncs : LOAD = FLASH_BOOT,
RUN = RAM_PROG,
LOAD_START(_RamfuncsLoadStart),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
PAGE = 0
csmpasswds : > CSM_PWL_P0 PAGE = 0
csm_rsvd : > CSM_RSVD PAGE = 0
/* Allocate uninitalized data sections: */
.stack : > RAMM1, PAGE = 1, ALIGN(4)
.cio : >> RAMM0 | RAMM1, PAGE = 1, ALIGN(4)
.sysmem : > RAMM0, PAGE = 1, ALIGN(4)
.ebss : > RAM_DATA, PAGE = 1, ALIGN(4)
.esysmem : > RAM_DATA, PAGE = 1, ALIGN(4)
/* Initalized sections go in Flash */
/* For SDFlash to program these, they must be allocated to page 0 */
.econst : > FLASH_BOOT, PAGE = 0, ALIGN(4)
.switch : > FLASH_BOOT, PAGE = 0, ALIGN(4)
.const : > FLASH_BOOT PAGE = 0, ALIGN(4)
/* Allocate IQ math areas: */
IQmath : > FLASH_BOOT, PAGE = 0 /* Math Code */
IQmathTables : > IQTABLES, PAGE = 0, TYPE = NOLOAD
Cla1Prog : LOAD = FLASH_APPPROG,
RUN = RAM_CLAPRG,
LOAD_START(_Cla1funcsLoadStart),
LOAD_END(_Cla1funcsLoadEnd),
RUN_START(_Cla1funcsRunStart),
PAGE = 0
Cla1ToCpuMsgRAM : > CLA2CPU, PAGE = 1
CpuToCla1MsgRAM : > CPU2CLA, PAGE = 1
.reset : > RESET, PAGE = 0, TYPE = DSECT
vectors : > VECTORS PAGE = 0, TYPE = DSECT
// End of file.
APP CMD 文件
-heap 0x400
MEMORY
FLASH_APPPROG : origin = 0x3EA010, length = 0x00BFEC /* 应用程序存储空间,47.98 Kb BFEC*/
BOOT_UPDATE : origin = 0x3F6350, length = 0x000002 /* Bootloader程序 升级入口地址*/
BOOT_RESET : origin = 0x3F6352, length = 0x000002 /* Bootloader程序 复位入口地址*/
FLASH_BOOT : origin = 0x3F6354, length = 0x001C2C /* bootloader程序存储空间 7.04kB */
CSM_RSVD : origin = 0x3F7F80, length = 0x000076 /* !!!不能修改 */
BEGIN : origin = 0x3F7FF6, length = 0x000002 /* !!!不能修改 */
CSM_PWL_P0 : origin = 0x3F7FF8, length = 0x000008 /* !!!不能修改 */
RAM_DATA : origin = 0x008940, length = 0x0006C0 /* For .ebss */
Note:
SECTIONS
codestart : > APP_START, PAGE = 0
RUN = RAM_BOOTPROG,
PAGE = 0
.cinit : > FLASH_APPPROG PAGE = 0
.pinit : > FLASH_APPPROG, PAGE = 0
.text : > FLASH_APPPROG PAGE = 0
ramfuncs : LOAD = FLASH_APPPROG,
RUN = RAM_PROG,
PAGE = 0
.econst : > FLASH_APPPROG, PAGE = 0
.switch : > FLASH_APPPROG, PAGE = 0
.const : > FLASH_APPPROG PAGE = 0
IQmath : > FLASH_APPPROG, PAGE = 0 /* Math Code */
RUN = RAM_CLAPRG,
PAGE = 0
// End of file.
