- 配置:(使用dcsm_security_tool例程,在sysconfig中配置DCSM如下)
- 解锁
- 然后在launch selected configuration,connect设备,结果失败
参考下这个文件看是否有帮助:
Enhancing Device Security by Using JTAGLOCK Feature (ti.com)
参考下工程师的回复:
It seems this is an issue with CC12.4 and lower. I discussed this with other DCSM experts and they are not aware of this issue, but they recommended to use the latest CCS. Since this is a previous release of CCS it cannot be updated/fixed, however I will look into whether this issue can be added to the release notes for previous CCS versions.
