我使用使用TI的官方例程,进行网络通信测试。每次发送100个ping,偶尔会出现连接超时,请问这可能是什么原因导致的?
下面代码是CPU1的主程序
// FILE: cm_common_config_c28x.c
// TITLE: C28x Common Configurations to be used for the CM Side.
//! \addtogroup driver_example_list
//! <h1>C28x Common Configurations</h1>
//! This example configures the GPIOs and Allocates the shared peripherals
//! according to the defines selected by the users.
// $Copyright:
// Copyright (C) 2022 Texas Instruments Incorporated - http://www.ti.com
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
void main(void)
// Initialize device clock and peripherals
Device_init();
// Boot CM core
#ifdef _FLASH
Device_bootCM(BOOTMODE_BOOT_TO_FLASH_SECTOR0);
#else
Device_bootCM(BOOTMODE_BOOT_TO_S0RAM);
#endif
// Disable pin locks and enable internal pull-ups.
Device_initGPIO();
GPIO_setPadConfig(DEVICE_GPIO_PIN_LED1, GPIO_PIN_TYPE_STD);
GPIO_setDirectionMode(DEVICE_GPIO_PIN_LED1, GPIO_DIR_MODE_OUT);
GPIO_setPadConfig(DEVICE_GPIO_PIN_LED2, GPIO_PIN_TYPE_STD);
GPIO_setDirectionMode(DEVICE_GPIO_PIN_LED2, GPIO_DIR_MODE_OUT);
// Configure CM to control the LED2
GPIO_setMasterCore(DEVICE_GPIO_PIN_LED1, GPIO_CORE_CM);
GPIO_setMasterCore(DEVICE_GPIO_PIN_LED2, GPIO_CORE_CM);
//#ifdef ETHERNET
// // Set up EnetCLK to use SYSPLL as the clock source and set the
// // clock divider to 2.
// // This way we ensure that the PTP clock is 100 MHz. Note that this value
// // is not automatically/dynamically known to the CM core and hence it needs
// // to be made available to the CM side code beforehand.
// SysCtl_setEnetClk(SYSCTL_ENETCLKOUT_DIV_2, SYSCTL_SOURCE_SYSPLL);
// // Configure the GPIOs for ETHERNET.
// // MDIO Signals
// GPIO_setPinConfig(GPIO_105_ENET_MDIO_CLK);
// GPIO_setPinConfig(GPIO_106_ENET_MDIO_DATA);
// // Use this only for RMII Mode
// //GPIO_setPinConfig(GPIO_73_ENET_RMII_CLK);
// //MII Signals
// GPIO_setPinConfig(GPIO_109_ENET_MII_CRS);
// GPIO_setPinConfig(GPIO_110_ENET_MII_COL);
// GPIO_setPinConfig(GPIO_75_ENET_MII_TX_DATA0);
// GPIO_setPinConfig(GPIO_122_ENET_MII_TX_DATA1);
// GPIO_setPinConfig(GPIO_123_ENET_MII_TX_DATA2);
// GPIO_setPinConfig(GPIO_124_ENET_MII_TX_DATA3);
// //Use this only if the TX Error pin has to be connected
// //GPIO_setPinConfig(GPIO_46_ENET_MII_TX_ERR);
// GPIO_setPinConfig(GPIO_118_ENET_MII_TX_EN);
// GPIO_setPinConfig(GPIO_114_ENET_MII_RX_DATA0);
// GPIO_setPinConfig(GPIO_115_ENET_MII_RX_DATA1);
// GPIO_setPinConfig(GPIO_116_ENET_MII_RX_DATA2);
// GPIO_setPinConfig(GPIO_117_ENET_MII_RX_DATA3);
// GPIO_setPinConfig(GPIO_113_ENET_MII_RX_ERR);
// GPIO_setPinConfig(GPIO_112_ENET_MII_RX_DV);
// GPIO_setPinConfig(GPIO_44_ENET_MII_TX_CLK);
// GPIO_setPinConfig(GPIO_111_ENET_MII_RX_CLK);
// //Power down pin to bring the external PHY out of Power down
// GPIO_setDirectionMode(108, GPIO_DIR_MODE_OUT);
// GPIO_setPadConfig(108, GPIO_PIN_TYPE_PULLUP);
// GPIO_writePin(108,1);
// //PHY Reset Pin to be driven High to bring external PHY out of Reset
// GPIO_setDirectionMode(119, GPIO_DIR_MODE_OUT);
// GPIO_setPadConfig(119, GPIO_PIN_TYPE_PULLUP);
// GPIO_writePin(119,1);
//#endif
//MII Signals
GPIO_setPinConfig(GPIO_39_ENET_MII_COL);
GPIO_setPinConfig(GPIO_59_ENET_MII_TX_DATA0);
GPIO_setPinConfig(GPIO_60_ENET_MII_TX_DATA1);
GPIO_setPinConfig(GPIO_61_ENET_MII_TX_DATA2);
GPIO_setPinConfig(GPIO_62_ENET_MII_TX_DATA3);
GPIO_setPinConfig(GPIO_45_ENET_MII_TX_EN);
GPIO_setPinConfig(GPIO_65_ENET_MII_RX_DATA2);
GPIO_setPinConfig(GPIO_66_ENET_MII_RX_DATA3);
// GPIO_setPinConfig(GPIO_57_ENET_MII_RX_ERR);
GPIO_setPinConfig(GPIO_50_ENET_MII_RX_DV);
GPIO_setPinConfig(GPIO_58_ENET_MII_TX_CLK);
GPIO_setPinConfig(GPIO_67_ENET_MII_RX_CLK);
while(1){
下面代码是cm的主程序
// FILE: enet_lwip.c
// TITLE: lwIP based Ethernet Example.
// $TI Release: $
// $Release Date: $
// $Copyright:
// are met:
// distribution.
#include <string.h>
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_nvic.h"
#include "inc/hw_types.h"
#include "inc/hw_sysctl.h"
#include "inc/hw_emac.h"
#include "driverlib_cm/ethernet.h"
#include "driverlib_cm/gpio.h"
#include "driverlib_cm/interrupt.h"
#include "driverlib_cm/flash.h"
#include "driverlib_cm/sysctl.h"
#include "driverlib_cm/systick.h"
#include "utils/lwiplib.h"
#include "board_drivers/pinout.h"
#include "lwip/apps/httpd.h"
//! \addtogroup master_example_list
//! <h1>Ethernet with lwIP (enet_lwip)</h1>
//! This example application demonstrates the operation of the F2838x
//! microcontroller Ethernet controller using the lwIP TCP/IP Stack. Once
//! programmed, the device sits endlessly waiting for ICMP ping requests. It
//! has a static IP address. To ping the device, the sender has to be in the
//! same network. The stack also supports ARP.
//! For additional details on lwIP, refer to the lwIP web page at:
//! savannah.nongnu.org/.../
// These are defined by the linker (see device linker command file)
extern uint16_t RamfuncsLoadStart;
extern uint16_t RamfuncsLoadSize;
extern uint16_t RamfuncsRunStart;
extern uint16_t RamfuncsLoadEnd;
extern uint16_t RamfuncsRunEnd;
extern uint16_t RamfuncsRunSize;
extern uint16_t constLoadStart;
extern uint16_t constLoadEnd;
extern uint16_t constLoadSize;
extern uint16_t constRunStart;
extern uint16_t constRunEnd;
extern uint16_t constRunSize;
#define DEVICE_FLASH_WAITSTATES 2
// Driver specific initialization code and macro.
#define ETHERNET_NO_OF_RX_PACKETS 2U
#define ETHERNET_MAX_PACKET_LENGTH 1538U
#define NUM_PACKET_DESC_RX_APPLICATION 8
Ethernet_Handle emac_handle;
Ethernet_InitConfig *pInitCfg;
uint32_t Ethernet_numRxCallbackCustom = 0;
uint32_t releaseTxCount = 0;
uint32_t genericISRCustomcount = 0;
uint32_t genericISRCustomRBUcount = 0;
uint32_t genericISRCustomROVcount = 0;
uint32_t genericISRCustomRIcount = 0;
uint32_t systickPeriodValue = 15000000;
Ethernet_Pkt_Desc pktDescriptorRXCustom[NUM_PACKET_DESC_RX_APPLICATION];
extern uint32_t Ethernet_numGetPacketBufferCallback;
extern Ethernet_Device Ethernet_device_struct;
uint8_t Ethernet_rxBuffer[ETHERNET_NO_OF_RX_PACKETS *
ETHERNET_MAX_PACKET_LENGTH];
extern Ethernet_Pkt_Desc*
lwIPEthernetIntHandler(Ethernet_Pkt_Desc *pPacket);
void CM_init(void)
// Disable the watchdog
SysCtl_disableWatchdog();
#ifdef _FLASH
// Copy time critical code and flash setup code to RAM. This includes the
// following functions: InitFlash();
// The RamfuncsLoadStart, RamfuncsLoadSize, and RamfuncsRunStart symbols
// are created by the linker. Refer to the device .cmd file.
// Html pages are also being copied from flash to ram.
memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (size_t)&RamfuncsLoadSize);
memcpy(&constRunStart, &constLoadStart, (size_t)&constLoadSize);
// Call Flash Initialization to setup flash waitstates. This function must
// reside in RAM.
Flash_initModule(FLASH0CTRL_BASE, FLASH0ECC_BASE, DEVICE_FLASH_WAITSTATES);
#endif
// Sets the NVIC vector table offset address.
#ifdef _FLASH
Interrupt_setVectorTableOffset((uint32_t)vectorTableFlash);
#else
Interrupt_setVectorTableOffset((uint32_t)vectorTableRAM);
#endif
// HTTP Webserver related callbacks and definitions.
// Currently, this implemented as a pointer to function which is called when
// corresponding query is received by the HTTP webserver daemon. When more
// features are needed to be added, it should be implemented as a separate
// interface.
void httpLEDToggle(void);
void(*ledtoggleFuncPtr)(void) = &httpLEDToggle;
// The interrupt handler for the SysTick interrupt.
void
SysTickIntHandler(void)
// Call the lwIP timer handler.
lwIPTimer(systickPeriodValue);
// This function is a callback function called by the example to
// get a Packet Buffer. Has to return a ETHERNET_Pkt_Desc Structure.
// Rewrite this API for custom use case.
Ethernet_Pkt_Desc* Ethernet_getPacketBufferCustom(void)
// Get the next packet descriptor from the descriptor pool
uint32_t shortIndex = (Ethernet_numGetPacketBufferCallback + 3)
% NUM_PACKET_DESC_RX_APPLICATION;
// Increment the book-keeping pointer which acts as a head pointer
// to the circular array of packet descriptor pool.
Ethernet_numGetPacketBufferCallback++;
// Update buffer length information to the newly procured packet
// descriptor.
pktDescriptorRXCustom[shortIndex].bufferLength =
ETHERNET_MAX_PACKET_LENGTH;
// Update the receive buffer address in the packer descriptor.
pktDescriptorRXCustom[shortIndex].dataBuffer =
&Ethernet_device_struct.rxBuffer [ \
(ETHERNET_MAX_PACKET_LENGTH*Ethernet_device_struct.rxBuffIndex)];
// Update the receive buffer pool index.
Ethernet_device_struct.rxBuffIndex += 1U;
Ethernet_device_struct.rxBuffIndex = \
(Ethernet_device_struct.rxBuffIndex%ETHERNET_NO_OF_RX_PACKETS);
// Receive buffer is usable from Address 0
pktDescriptorRXCustom[shortIndex].dataOffset = 0U;
// Return this new descriptor to the driver.
return (&(pktDescriptorRXCustom[shortIndex]));
// This is a hook function and called by the driver when it receives a
// packet. Application is expected to replenish the buffer after consuming it.
// Has to return a ETHERNET_Pkt_Desc Structure.
Ethernet_Pkt_Desc* Ethernet_receivePacketCallbackCustom(
Ethernet_Handle handleApplication,
// Book-keeping to maintain number of callbacks received.
#ifdef ETHERNET_DEBUG
Ethernet_numRxCallbackCustom++;
#endif
// This is a placeholder for Application specific handling
// We are replenishing the buffer received with another buffer
return lwIPEthernetIntHandler(pPacket);
void Ethernet_releaseTxPacketBufferCustom(
// Once the packet is sent, reuse the packet memory to avoid
// memory leaks. Call this interrupt handler function which will take care
// of freeing the memory used by the packet descriptor.
// Increment the book-keeping counter.
releaseTxCount++;
#endif
interrupt void Ethernet_genericISRCustom(void)
genericISRCustomcount++;
Ethernet_RxChDesc *rxChan;
Ethernet_TxChDesc *txChan;
Ethernet_HW_descriptor *descPtr;
Ethernet_HW_descriptor *tailPtr;
uint16_t i=0;
Ethernet_clearMACConfiguration(Ethernet_device_struct.baseAddresses.enet_base,ETHERNET_MAC_CONFIGURATION_RE);
Ethernet_clearMACConfiguration(Ethernet_device_struct.baseAddresses.enet_base,ETHERNET_MAC_CONFIGURATION_TE);
for(i = 0U;i < Ethernet_device_struct.initConfig.numChannels;i++)
Ethernet_disableRxDMAReception(
i);
if(((ETHERNET_DMA_CH0_STATUS_AIS |
ETHERNET_DMA_CH0_STATUS_RBU) ==
(HWREG(Ethernet_device_struct.baseAddresses.enet_base +
ETHERNET_O_DMA_CH0_STATUS) &
(uint32_t)(ETHERNET_DMA_CH0_STATUS_AIS |
ETHERNET_DMA_CH0_STATUS_RBU))) ||
(ETHERNET_MTL_Q0_INTERRUPT_CONTROL_STATUS_RXOVFIS) ==
ETHERNET_O_MTL_Q0_INTERRUPT_CONTROL_STATUS) &
(uint32_t)(ETHERNET_MTL_Q0_INTERRUPT_CONTROL_STATUS_RXOVFIS
if((ETHERNET_DMA_CH0_STATUS_AIS |
genericISRCustomRBUcount++;
if((ETHERNET_MTL_Q0_INTERRUPT_CONTROL_STATUS_RXOVFIS) ==
genericISRCustomROVcount++;
Ethernet_enableMTLInterrupt(Ethernet_device_struct.baseAddresses.enet_base,0,
ETHERNET_MTL_Q0_INTERRUPT_CONTROL_STATUS_RXOVFIS);
* Clear the AIS and RBU status bit. These MUST be
* cleared together!
Ethernet_clearDMAChannelInterrupt(
ETHERNET_DMA_CHANNEL_NUM_0,
ETHERNET_DMA_CH0_STATUS_RBU);
*Recover from Receive Buffer Unavailable (and hung DMA)
* All descriptor buffers are owned by the application, and
* in result the DMA cannot transfer incoming frames to the
* buffers (RBU condition). DMA has also entered suspend
* mode at this point, too.
* Drain the RX queues
/* Upon RBU error, discard all previously received packets */
if(Ethernet_device_struct.initConfig.pfcbDeletePackets != NULL)
(*Ethernet_device_struct.initConfig.pfcbDeletePackets)();
rxChan =
&Ethernet_device_struct.dmaObj.rxDma[ETHERNET_DMA_CHANNEL_NUM_0];
txChan=
&Ethernet_device_struct.dmaObj.txDma[ETHERNET_DMA_CHANNEL_NUM_0];
* Need to disable multiple interrupts, so protect the code to do so within
* a global disable block (to prevent getting interrupted in between)
if(NULL!= Ethernet_device_struct.ptrPlatformInterruptDisable)
(*Ethernet_device_struct.ptrPlatformInterruptDisable)(
Ethernet_device_struct.interruptNum[
ETHERNET_RX_INTR_CH0 + rxChan->chInfo->chNum]);
ETHERNET_GENERIC_INTERRUPT]);
/* verify we have full capacity in the descriptor queue */
if(rxChan->descQueue.count < rxChan->descMax) {
/* The queue is not at full capacity due to OOM errors.
Try to fill it again */
Ethernet_addPacketsIntoRxQueue(rxChan);
Ethernet_initRxChannel(
&Ethernet_device_struct.initConfig.chInfo[ETHERNET_CH_DIR_RX][0]);
Ethernet_writeRxDescTailPointer(
0,
(&Ethernet_device_struct.rxDesc[
((uint32_t)ETHERNET_DESCRIPTORS_NUM_RX_PER_CHANNEL) *
(0 + (uint32_t)1U)]));
if(NULL!= Ethernet_device_struct.ptrPlatformInterruptEnable)
(*Ethernet_device_struct.ptrPlatformInterruptEnable)(
if(0U != (HWREG(Ethernet_device_struct.baseAddresses.enet_base +
(uint32_t) ETHERNET_DMA_CH0_STATUS_RI))
genericISRCustomRIcount++;
ETHERNET_DMA_CH0_STATUS_NIS | ETHERNET_DMA_CH0_STATUS_RI);
Ethernet_enableRxDMAReception(
i);
Ethernet_setMACConfiguration(Ethernet_device_struct.baseAddresses.enet_base,ETHERNET_MAC_CONFIGURATION_RE);
Ethernet_setMACConfiguration(Ethernet_device_struct.baseAddresses.enet_base,ETHERNET_MAC_CONFIGURATION_TE);
void
Ethernet_init(const unsigned char *mac)
Ethernet_InitInterfaceConfig initInterfaceConfig;
uint32_t macLower;
uint32_t macHigher;
uint8_t *temp;
initInterfaceConfig.ssbase = EMAC_SS_BASE;
initInterfaceConfig.enet_base = EMAC_BASE;
initInterfaceConfig.phyMode = ETHERNET_SS_PHY_INTF_SEL_MII;
// Assign SoC specific functions for Enabling,Disabling interrupts
// and for enabling the Peripheral at system level
initInterfaceConfig.ptrPlatformInterruptDisable =
&Platform_disableInterrupt;
initInterfaceConfig.ptrPlatformInterruptEnable =
&Platform_enableInterrupt;
initInterfaceConfig.ptrPlatformPeripheralEnable =
&Platform_enablePeripheral;
initInterfaceConfig.ptrPlatformPeripheralReset =
&Platform_resetPeripheral;
// Assign the peripheral number at the SoC
initInterfaceConfig.peripheralNum = SYSCTL_PERIPH_CLK_ENET;
// Assign the default SoC specific interrupt numbers of Ethernet interrupts
initInterfaceConfig.interruptNum[0] = INT_EMAC;
initInterfaceConfig.interruptNum[1] = INT_EMAC_TX0;
initInterfaceConfig.interruptNum[2] = INT_EMAC_TX1;
initInterfaceConfig.interruptNum[3] = INT_EMAC_RX0;
initInterfaceConfig.interruptNum[4] = INT_EMAC_RX1;
pInitCfg = Ethernet_initInterface(initInterfaceConfig);
Ethernet_getInitConfig(pInitCfg);
pInitCfg->dmaMode.InterruptMode = ETHERNET_DMA_MODE_INTM_MODE2;
// Assign the callbacks for Getting packet buffer when needed
// Releasing the TxPacketBuffer on Transmit interrupt callbacks
// Receive packet callback on Receive packet completion interrupt
pInitCfg->pfcbRxPacket = &Ethernet_receivePacketCallbackCustom;
pInitCfg->pfcbGetPacket = &Ethernet_getPacketBuffer;
pInitCfg->pfcbFreePacket = &Ethernet_releaseTxPacketBufferCustom;
//Assign the Buffer to be used by the Low level driver for receiving
//Packets. This should be accessible by the Ethernet DMA
pInitCfg->rxBuffer = Ethernet_rxBuffer;
// The Application handle is not used by this application
// Hence using a dummy value of 1
Ethernet_getHandle((Ethernet_Handle)1, pInitCfg , &emac_handle);
// Disable transmit buffer unavailable and normal interrupt which
// are enabled by default in Ethernet_getHandle.
Ethernet_disableDmaInterrupt(Ethernet_device_struct.baseAddresses.enet_base,
0, (ETHERNET_DMA_CH0_INTERRUPT_ENABLE_TBUE |
ETHERNET_DMA_CH0_INTERRUPT_ENABLE_NIE));
// Enable the MTL interrupt to service the receive FIFO overflow
// condition in the Ethernet module.
ETHERNET_MTL_Q0_INTERRUPT_CONTROL_STATUS_RXOIE);
// Disable the MAC Management counter interrupts as they are not used
// in this application.
HWREG(Ethernet_device_struct.baseAddresses.enet_base + ETHERNET_O_MMC_RX_INTERRUPT_MASK) = 0xFFFFFFFF;
HWREG(Ethernet_device_struct.baseAddresses.enet_base + ETHERNET_O_MMC_IPC_RX_INTERRUPT_MASK) = 0xFFFFFFFF;
//Do global Interrupt Enable
(void)Interrupt_enableInProcessor();
//Assign default ISRs
Interrupt_registerHandler(INT_EMAC_TX0, Ethernet_transmitISR);
Interrupt_registerHandler(INT_EMAC_RX0, Ethernet_receiveISR);
Interrupt_registerHandler(INT_EMAC, Ethernet_genericISRCustom);
//Enable the default interrupt handlers
Interrupt_enable(INT_EMAC_TX0);
Interrupt_enable(INT_EMAC_RX0);
Interrupt_enable(INT_EMAC);
// Convert the mac address string into the 32/16 split variables format
// that is required by the driver to program into hardware registers.
// Note: This step is done after the Ethernet_getHandle function because
// a dummy MAC address is programmed in that function.
temp = (uint8_t *)&macLower;
temp[0] = mac[0];
temp[1] = mac[1];
temp[2] = mac[2];
temp[3] = mac[3];
temp = (uint8_t *)&macHigher;
temp[0] = mac[4];
temp[1] = mac[5];
// Program the unicast mac address.
Ethernet_setMACAddr(EMAC_BASE,
0,
macHigher,
macLower,
ETHERNET_CHANNEL_0);
// This example demonstrates the use of the Ethernet Controller.
int
main(void)
unsigned long ulUser0, ulUser1;
unsigned char pucMACArray[8];
// User specific IP Address Configuration.
// Current implementation works with Static IP address only.
unsigned long IPAddr = 0xC0A80004;
unsigned long NetMask = 0xFFFFFF00;
unsigned long GWAddr = 0x00000000;
// Initializing the CM. Loading the required functions to SRAM.
CM_init();
SYSTICK_setPeriod(systickPeriodValue);
SYSTICK_enableCounter();
SYSTICK_registerInterruptHandler(SysTickIntHandler);
SYSTICK_enableInterrupt();
// Enable processor interrupts.
// Set user/company specific MAC octets
// (for this code we are using A8-63-F2-00-00-80)
// 0x00 MACOCT3 MACOCT2 MACOCT1
ulUser0 = 0x00F263A8;
// 0x00 MACOCT6 MACOCT5 MACOCT4
ulUser1 = 0x00800000;
// Convert the 24/24 split MAC address from NV ram into a 32/16 split MAC
// address needed to program the hardware registers, then program the MAC
// address into the Ethernet Controller registers.
pucMACArray[0] = ((ulUser0 >> 0) & 0xff);
pucMACArray[1] = ((ulUser0 >> 8) & 0xff);
pucMACArray[2] = ((ulUser0 >> 16) & 0xff);
pucMACArray[3] = ((ulUser1 >> 0) & 0xff);
pucMACArray[4] = ((ulUser1 >> 8) & 0xff);
pucMACArray[5] = ((ulUser1 >> 16) & 0xff);
// Initialize ethernet module.
Ethernet_init(pucMACArray);
// Initialze the lwIP library, using DHCP.
lwIPInit(0, pucMACArray, IPAddr, NetMask, GWAddr, IPADDR_USE_STATIC);
// Initialize the HTTP webserver daemon.
httpd_init();
IPC_clearFlagLtoR(IPC_CM_L_CPU1_R, IPC_FLAG_ALL);
IPC_sync(IPC_CM_L_CPU1_R, IPC_FLAG31); // 等待远端IPC初始化
// Loop forever. All the work is done in interrupt handlers.
while(1);
// Called by lwIP Library. Toggles the led when a command is received by the
// HTTP webserver.
// Toggle the LED D1 on the control card.
GPIO_togglePin(DEVICE_GPIO_PIN_LED1);
// Called by lwIP Library. Could be used for periodic custom tasks.
void lwIPHostTimerHandler(void)
感谢您对TI产品的关注!为更加有效地解决您的问题,我们建议您将问题发布在E2E英文技术论坛上(https://e2e.ti.com/),将由资深的英文论坛工程师为您提供帮助。
