1、f28002x_dcsm_z1otp.asm中已经配置的加密;
2、280025_FLASH_lnk.cmd配置了DCSM的地址;
3、f28002x_headers_nonbios.cmd中注释// DCSMBANK0Z1OTP : origin = 0x00078000, length = 0x00000020, 已通过编译
4、实际OTP和FLASH区域数据并未被加密
;;############################################################################# ;; ;; FILE: f28002x_dcsm_z1otp.asm ;; ;; TITLE: Dual Code Security Module Zone 1 OTP ;; ;; DESCRIPTION: ;; ;; This file is used to specify Z1 DCSM OTP and zone select block ;; values to program. ;; ;; In addition, the 60 reserved values after the zone select block ;; are all programmed to 0x0000 as well. ;; ;; !!IMPORTANT!! The below memory sections are mapped to OTP (one-time ;; programmable) memory with the *dcsm_lnk.cmd linker command file. In order ;; to program the below memory sections, user should uncomment the .long words ;; of each section and change the value to what is desired. Additionally, the ;; corresponding section of *dcsm_lnk.cmd should no longer be labelled as a ;; dummy section. Remove ", type = DSECT" in SECTIONS from the memory section ;; that is being programmed. ;; ;; ;; !!IMPORTANT!! The "bx_dcsm_otp_z1_linkpointer" section contains the ;; Z1 LINKPOINTER which determines the location of the Z1 Zone Select block. ;; If the LINKPOINTER is changed, then the "bx_dcsm_zsel_z1_linkpointer" ;; section in the *_dcsm_lnk.cmd command linker file must also change to an ;; address decoded from the value specified in the Z1-LINKPOINTER location. ;; ;; The "bx_dcsm_zsel_z1" section contains the actual Z1 Zone Select Block ;; values that will be linked and programmed into to the DCSM Z1 OTP Zone ;; Select block in OTP. ;; These values must be known in order to unlock the CSM module. ;; Refer TRM for default values for the password locations. ;; ;; It is recommended that all values be left as at default during code ;; development. When code development is complete, modify values as required. ;; The new values has to take ECC values as well in to consideration (only bits ;; with value of '1' can be changed to '0' and NOT vice versa). ;; ;; TI ships this example commenting out the initialization of all the ;; below locations, users need to enable them for programming these values. ;; ;;############################################################################# ;; $TI Release: F28002x Support Library v3.04.00.00 $ ;; $Release Date: Fri Feb 12 18:58:34 IST 2021 $ ;; $Copyright: ;// Copyright (C) 2021 Texas Instruments Incorporated - http://www.ti.com/ ;// ;// Redistribution and use in source and binary forms, with or without ;// modification, are permitted provided that the following conditions ;// are met: ;// ;// Redistributions of source code must retain the above copyright ;// notice, this list of conditions and the following disclaimer. ;// ;// Redistributions in binary form must reproduce the above copyright ;// notice, this list of conditions and the following disclaimer in the ;// documentation and/or other materials provided with the ;// distribution. ;// ;// Neither the name of Texas Instruments Incorporated nor the names of ;// its contributors may be used to endorse or promote products derived ;// from this software without specific prior written permission. ;// ;// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS ;// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT ;// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR ;// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT ;// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, ;// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT ;// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, ;// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY ;// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT ;// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE ;// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ;// $ ;;############################################################################# .sect "b0_dcsm_otp_z1_linkpointer" .retain .long 0x1FFFFFFF ;Z1-LINKPOINTER1 .long 0xFFFFFFFF ;Reserved .long 0x1FFFFFFF ;B0_Z1OTP_LINKPOINTER2 .long 0xFFFFFFFF ;Reserved .long 0x1FFFFFFF ;B0_Z1OTP_LINKPOINTER3 .long 0xFFFFFFFF ;Reserved .sect "b0_dcsm_otp_z1_gpreg" .retain ;; See the ROM Code and Peripheral Booting chapter of TRM for more details. ;; ;; Below is a description of the bit fields of Z1OTP_BOOTPIN_CONFIG ;; used by Boot ROM. ;; ;; | Key (31-24) | BMSP2 (23-16) | BMSP1 (15-8) | BMSP0 (7-0) | ;; ;; Below is a description of the bit fields of Z1OTP_GPREG2 used by ;; Boot ROM. ;; ;; | Key (31-24) | RSVD (23-8) | RSVD (7-6) | ESP (5-4) | RSVD (3-0) | ;; .long 0xFFFFFFFF ;Z1OTP_BOOTPIN_CONFIG .long 0xFFFFFFFF ;Z1OTP_GPREG2 .sect "b0_dcsm_otp_z1_pswdlock" .retain .long 0xFB7FFFFF ;Z1-PSWDLOCK .long 0x7FFFFFFF ;Reserved .sect "b0_dcsm_otp_z1_crclock" .retain .long 0x4BFFFFFF ;Z1-CRCLOCK .long 0x3FFFFFFF ;Reserved .sect "b0_dcsm_otp_z1_bootctrl" .retain ;; See the ROM Code and Peripheral Booting chapter of TRM for more details. ;; ;; Below is a description of the bit fields of Z1OTP_BOOTDEF_LOW used by ;; Boot ROM. ;; ;; | BOOT_DEF3(31-24) | BOOT_DEF2(23-16) | BOOT_DEF1(15-8) | BOOT_DEF0(7-0) | ;; ;; Below is a description of the bit fields of Z1OTP_BOOTDEF_HIGH ;; used by Boot ROM. ;; ;; | BOOT_DEF7(31-24) | BOOT_DEF6(23-16) | BOOT_DEF5(15-8) | BOOT_DEF4(7-0) | ;; ;; .long 0xFFFFFFFF ;Z1OTP_BOOTDEF_LOW ;; .long 0xFFFFFFFF ;Z1OTP_BOOTDEF_HIGH .sect "b0_dcsm_zsel_z1" .retain .long 0xFFFFFFFF ;Z1-EXEONLYRAM .long 0xFFFFFFFF ;Z1-EXEONLYSECT .long 0xFFFFFFFF ;Z1-GRABRAM .long 0xFFFFFFFF ;Z1-GRABSECT .long 0xFFFFFFFF ;Z1-CSMPSWD0 (LSW of 128-bit password) .long 0x47FFFFFF ;Z1-CSMPSWD1 // this value is for ZSB0 .long 0xFFFFFFFF ;Z1-CSMPSWD2 .long 0xFFFFFFFF ;Z1-CSMPSWD3 (MSW of 128-bit password) .sect "b1_dcsm_otp_z1_linkpointer" .retain ;; .long 0x1FFFFFFF ;B1_Z1OTP_LINKPOINTER1 ;; .long 0xFFFFFFFF ;Reserved ;; .long 0x1FFFFFFF ;B1_Z1OTP_LINKPOINTER2 ;; .long 0xFFFFFFFF ;Reserved ;; .long 0x1FFFFFFF ;B1_Z1OTP_LINKPOINTER3 ;; .long 0xFFFFFFFF ;Reserved .sect "b1_dcsm_zsel_z1" .retain ;; .long 0xFFFFFFFF ;Reserved ;; .long 0xFFFFFFFF ;B1_Z1OTP_EXEONLYSECT ;; .long 0xFFFFFFFF ;Reserved ;; .long 0xFFFFFFFF ;B1_Z1OTP_GRABSECT ;; .long 0xFFFFFFFF ;Reserved ;; .long 0xFFFFFFFF ;Reserved ;; .long 0xFFFFFFFF ;Reserved ;; .long 0xFFFFFFFF ;Reserved ;;---------------------------------------------------------------------- ;; For code security operation,after development has completed, prior to ;; production, all other zone select block locations should be programmed ;; to 0x0000 for maximum security. ;; If the first zone select block at offset 0x10 is used, the section ;; "dcsm_rsvd_z1" can be used to program these locations to 0x0000. ;; This code is commented out for development. ;; .sect "dcsm_rsvd_z1" ;; .retain ;; .loop (1e0h) ;; .int 0x0000 ;; .endloop ;;############################################################################# ;; End of file ;;#############################################################################
MEMORY { PAGE 0 : /* Program Memory */ BOOT_RSVD : origin = 0x00000002, length = 0x00000126 RAMM0 : origin = 0x00000128, length = 0x000002D8 RAMM1 : origin = 0x00000400, length = 0x000003F8 /* on-chip RAM block M1 */ // RAMM1_RSVD : origin = 0x000007F8, length = 0x00000008 /* Reserve and do not use for code as per the errata advisory "Memory: Prefetching Beyond Valid Memory" */ /* RAMLS4 : origin = 0x0000A000, length = 0x00000800 RAMLS5 : origin = 0x0000A800, length = 0x00000800 RAMLS6 : origin = 0x0000B000, length = 0x00000800 RAMLS7 : origin = 0x0000B800, length = 0x00000800 */ /* Combining all the LS RAMs */ // RAMLS4567 : origin = 0x0000A000, length = 0x00002000 RAMLS4567 : origin = 0x0000A000, length = 0x00001800 RAMLS7 : origin = 0x0000b800, length = 0x00000800 RAMGS0 : origin = 0x0000C000, length = 0x000007F8 // RAMGS0_RSVD : origin = 0x0000C7F8, length = 0x00000008 /* Reserve and do not use for code as per the errata advisory "Memory: Prefetching Beyond Valid Memory" */ /* Z1 OTP. LinkPointers */ DCSM_OTP_Z1_LINKPOINTER : origin = 0x78000, length = 0x00000C /* Z1 OTP. GPREG1/GPREG2 */ DCSM_OTP_Z1_GPREG : origin = 0x7800C, length = 0x000004 /* Z1 OTP. PSWDLOCK/RESERVED */ DCSM_OTP_Z1_PSWDLOCK : origin = 0x78010, length = 0x000004 /* Z1 OTP. CRCLOCK/RESERVED */ DCSM_OTP_Z1_CRCLOCK : origin = 0x78014, length = 0x000004 /* Z1 OTP. RESERVED/BOOTCTRL */ DCSM_OTP_Z1_BOOTCTRL : origin = 0x7801C, length = 0x000004 /* DCSM Z1 Zone Select Contents (!!Movable!!) */ /* Z1 OTP. Z1 password locations / Flash and RAM partitioning */ DCSM_ZSEL_Z1_P0 : origin = 0x78020, length = 0x000010 /* Z2 OTP. LinkPointers */ // DCSM_OTP_Z2_LINKPOINTER : origin = 0x78200, length = 0x00000C /* Z2 OTP. GPREG1/GPREG2 */ // DCSM_OTP_Z2_GPREG : origin = 0x7820C, length = 0x000004 /* Z2 OTP. PSWDLOCK/RESERVED */ // DCSM_OTP_Z2_PSWDLOCK : origin = 0x78210, length = 0x000004 /* Z2 OTP. CRCLOCK/RESERVED */ // DCSM_OTP_Z2_CRCLOCK : origin = 0x78214, length = 0x000004 /* Z2 OTP. GPREG3/BOOTCTRL */ // DCSM_OTP_Z2_BOOTCTRL : origin = 0x7821C, length = 0x000004 /* DCSM Z1 Zone Select Contents (!!Movable!!) */ /* Z2 OTP. Z2 password locations / Flash and RAM partitioning */ // DCSM_ZSEL_Z2_P0 : origin = 0x78220, length = 0x000010 RESET : origin = 0x003FFFC0, length = 0x00000002 BOOTROM : origin = 0x003F0000, length = 0x00008000 BOOTROM_EXT : origin = 0x003F8000, length = 0x00007FC0 #ifdef __TI_COMPILER_VERSION__ #if __TI_COMPILER_VERSION__ >= 20012000 GROUP { /* GROUP memory ranges for crc/checksum of entire flash */ #endif #endif #define DEBUG_MODE #ifdef DEBUG_MODE BEGIN : origin = 0x080000, length = 0x000010 // 上电能跑的程序引导地址。 #else BEGIN : origin = 0x082010, length = 0x000010 // 需要bootload引导的地址。 #endif /* Flash sectors */ /* BANK 0 */ #ifdef DEBUG_MODE FLASH_BANK0_SEC1 : origin = 0x080010, length = 0x00EFF0 /* on-chip Flash */ #else FLASH_BANK0_SEC1 : origin = 0x082020, length = 0x00CFE0 /* on-chip Flash */ // 需要bootload引导的地址。 #endif // FLASH_BANK0_SEC1 : origin = 0x082000, length = 0x00D000 /* on-chip Flash */ // 上电能跑的程序引导地址。 // FLASH_BANK0_SEC1 : origin = 0x081000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC2 : origin = 0x082000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC3 : origin = 0x083000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC4 : origin = 0x084000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC5 : origin = 0x085000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC6 : origin = 0x086000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC7 : origin = 0x087000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC8 : origin = 0x088000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC9 : origin = 0x089000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC10 : origin = 0x08A000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC11 : origin = 0x08B000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC12 : origin = 0x08C000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC13 : origin = 0x08D000, length = 0x001000 /* on-chip Flash */ // FLASH_BANK0_SEC14 : origin = 0x08E000, length = 0x001000 /* on-chip Flash */ FLASH_BANK0_SEC15 : origin = 0x08F000, length = 0x000FF0 /* on-chip Flash */ // FLASH_BANK0_SEC15_RSVD : origin = 0x08FFF0, length = 0x000010 /* Reserve and do not use for code as per the errata advisory "Memory: Prefetching Beyond Valid Memory" */ #ifdef __TI_COMPILER_VERSION__ #if __TI_COMPILER_VERSION__ >= 20012000 } crc(_table_name, algorithm=C28_CHECKSUM_16) #endif #endif } SECTIONS { codestart : > BEGIN, ALIGN(8) b0_dcsm_otp_z1_linkpointer : > DCSM_OTP_Z1_LINKPOINTER PAGE = 0 b0_dcsm_otp_z1_gpreg : > DCSM_OTP_Z1_GPREG PAGE = 0 b0_dcsm_otp_z1_pswdlock : > DCSM_OTP_Z1_PSWDLOCK PAGE = 0 b0_dcsm_otp_z1_crclock : > DCSM_OTP_Z1_CRCLOCK PAGE = 0 b0_dcsm_otp_z1_bootctrl : > DCSM_OTP_Z1_BOOTCTRL PAGE = 0 b0_dcsm_zsel_z1 : > DCSM_ZSEL_Z1_P0 PAGE = 0 // b0_dcsm_otp_z2_linkpointer : > DCSM_OTP_Z2_LINKPOINTER PAGE = 0 // b0_dcsm_otp_z2_gpreg : > DCSM_OTP_Z2_GPREG PAGE = 0 // b0_dcsm_otp_z2_pswdlock : > DCSM_OTP_Z2_PSWDLOCK PAGE = 0 // b0_dcsm_otp_z2_crclock : > DCSM_OTP_Z2_CRCLOCK PAGE = 0 // b0_dcsm_otp_z2_bootctrl : > DCSM_OTP_Z2_BOOTCTRL PAGE = 0 // b0_dcsm_zsel_z2 : > DCSM_ZSEL_Z2_P0 PAGE = 0 // .text : >> FLASH_BANK0_SEC2 | FLASH_BANK0_SEC3 | FLASH_BANK0_SEC4, ALIGN(8) .text : >> FLASH_BANK0_SEC1 , ALIGN(8) .cinit : > FLASH_BANK0_SEC1, ALIGN(8) .switch : > FLASH_BANK0_SEC1, ALIGN(8) .reset : > RESET, TYPE = DSECT /* not used, */ .stack : > RAMM1 .init_array : > FLASH_BANK0_SEC1, ALIGN(8) .bss : > RAMLS4567 .bss:output : > RAMLS4567 .bss:cio : > RAMGS0 .const : > FLASH_BANK0_SEC1, ALIGN(8) .data : > RAMLS4567 .sysmem : > RAMLS4567 ramgs0 : > RAMGS0 /* Allocate IQ math areas: */ //IQmath : > RAMLS4567 //IQmathTables : > RAMLS4567 IQmath : > FLASH_BANK0_SEC1 IQmathTables : > FLASH_BANK0_SEC1 /* .TI.ramfunc : LOAD = FLASH_BANK0_SEC1, RUN = RAMGS0, LOAD_START(RamfuncsLoadStart), LOAD_SIZE(RamfuncsLoadSize), LOAD_END(RamfuncsLoadEnd), RUN_START(RamfuncsRunStart), RUN_SIZE(RamfuncsRunSize), RUN_END(RamfuncsRunEnd), ALIGN(8) */ .TI.ramfunc : LOAD = FLASH_BANK0_SEC1, RUN = RAMLS7, LOAD_START(RamfuncsLoadStart), LOAD_SIZE(RamfuncsLoadSize), LOAD_END(RamfuncsLoadEnd), RUN_START(RamfuncsRunStart), RUN_SIZE(RamfuncsRunSize), RUN_END(RamfuncsRunEnd), ALIGN(8) /* crc/checksum section configured as COPY section to avoid including in executable */ .TI.memcrc : type = COPY } /* //=========================================================================== // End of file. //=========================================================================== */
MEMORY { ACCESSPROTECTION : origin = 0x0005F500, length = 0x0000003E ADCA : origin = 0x00007400, length = 0x00000080 ADCC : origin = 0x00007500, length = 0x00000080 ADCARESULT : origin = 0x00000B00, length = 0x00000018 ADCCRESULT : origin = 0x00000B40, length = 0x00000018 ANALOGSUBSYS : origin = 0x0005D700, length = 0x00000100 BGCRCCPU : origin = 0x00006340, length = 0x00000040 CANA : origin = 0x00048000, length = 0x00000200 CLB1DATAEXCH : origin = 0x00003180, length = 0x00000080 CLB2DATAEXCH : origin = 0x00003580, length = 0x00000080 CLB1LOGICCFG : origin = 0x00003000, length = 0x00000052 CLB2LOGICCFG : origin = 0x00003400, length = 0x00000052 CLB1LOGICCTRL : origin = 0x00003100, length = 0x00000040 CLB2LOGICCTRL : origin = 0x00003500, length = 0x00000040 CLBXBAR : origin = 0x00007A40, length = 0x00000040 CLKCFG : origin = 0x0005D200, length = 0x00000100 CMPSS1 : origin = 0x00005C80, length = 0x00000020 CMPSS2 : origin = 0x00005CA0, length = 0x00000020 CMPSS3 : origin = 0x00005CC0, length = 0x00000020 CMPSS4 : origin = 0x00005CE0, length = 0x00000020 CPUTIMER0 : origin = 0x00000C00, length = 0x00000008 CPUTIMER1 : origin = 0x00000C08, length = 0x00000008 CPUTIMER2 : origin = 0x00000C10, length = 0x00000008 CPUSYS : origin = 0x0005D300, length = 0x000000A0 DCC0 : origin = 0x0005E700, length = 0x00000038 DCC1 : origin = 0x0005E740, length = 0x00000038 // DCSMBANK0Z1OTP : origin = 0x00078000, length = 0x00000020 DCSMBANK0Z1 : origin = 0x0005F000, length = 0x00000024 DCSMBANK0Z2OTP : origin = 0x00078200, length = 0x00000020 DCSMBANK0Z2 : origin = 0x0005F040, length = 0x00000024 DCSMCOMMON : origin = 0x0005F070, length = 0x00000010 DEVCFG : origin = 0x0005D000, length = 0x000001AC DMACLASRCSEL : origin = 0x00007980, length = 0x0000001A DMA : origin = 0x00001000, length = 0x00000200 ECAP1 : origin = 0x00005200, length = 0x00000020 ECAP2 : origin = 0x00005240, length = 0x00000020 ECAP3 : origin = 0x00005280, length = 0x00000020 EPWM1 : origin = 0x00004000, length = 0x00000100 EPWM2 : origin = 0x00004100, length = 0x00000100 EPWM3 : origin = 0x00004200, length = 0x00000100 EPWM4 : origin = 0x00004300, length = 0x00000100 EPWM5 : origin = 0x00004400, length = 0x00000100 EPWM6 : origin = 0x00004500, length = 0x00000100 EPWM7 : origin = 0x00004600, length = 0x00000100 EPWMXBAR : origin = 0x00007A00, length = 0x00000040 EQEP1 : origin = 0x00005100, length = 0x00000040 EQEP2 : origin = 0x00005140, length = 0x00000040 ERADCOUNTER1 : origin = 0x0005E980, length = 0x00000010 ERADCOUNTER2 : origin = 0x0005E990, length = 0x00000010 ERADCOUNTER3 : origin = 0x0005E9A0, length = 0x00000010 ERADCOUNTER4 : origin = 0x0005E9B0, length = 0x00000010 ERADCRCGLOBAL : origin = 0x0005EA00, length = 0x00000010 ERADCRC1 : origin = 0x0005EA10, length = 0x00000010 ERADCRC2 : origin = 0x0005EA20, length = 0x00000010 ERADCRC3 : origin = 0x0005EA30, length = 0x00000010 ERADCRC4 : origin = 0x0005EA40, length = 0x00000010 ERADCRC5 : origin = 0x0005EA50, length = 0x00000010 ERADCRC6 : origin = 0x0005EA60, length = 0x00000010 ERADCRC7 : origin = 0x0005EA70, length = 0x00000010 ERADCRC8 : origin = 0x0005EA80, length = 0x00000010 ERADGLOBAL : origin = 0x0005E800, length = 0x00000014 ERADHWBP1 : origin = 0x0005E900, length = 0x00000008 ERADHWBP2 : origin = 0x0005E908, length = 0x00000008 ERADHWBP3 : origin = 0x0005E910, length = 0x00000008 ERADHWBP4 : origin = 0x0005E918, length = 0x00000008 ERADHWBP5 : origin = 0x0005E920, length = 0x00000008 ERADHWBP6 : origin = 0x0005E928, length = 0x00000008 ERADHWBP7 : origin = 0x0005E930, length = 0x00000008 ERADHWBP8 : origin = 0x0005E938, length = 0x00000008 FLASH0CTRL : origin = 0x0005F800, length = 0x00000182 FLASH0ECC : origin = 0x0005FB00, length = 0x00000028 FSIRXA : origin = 0x00006680, length = 0x00000050 FSITXA : origin = 0x00006600, length = 0x00000050 GPIOCTRL : origin = 0x00007C00, length = 0x00000200 GPIODATAREAD : origin = 0x00007F80, length = 0x00000010 GPIODATA : origin = 0x00007F00, length = 0x00000040 HIC : origin = 0x00006500, length = 0x00000080 HRCAP3 : origin = 0x000052A0, length = 0x00000020 I2CA : origin = 0x00007300, length = 0x00000022 I2CB : origin = 0x00007340, length = 0x00000022 INPUTXBAR : origin = 0x00007900, length = 0x00000020 CLBINPUTXBAR : origin = 0x00007960, length = 0x00000020 LINA : origin = 0x00006A00, length = 0x000000EC LINB : origin = 0x00006B00, length = 0x000000EC MEMORYERROR : origin = 0x0005F540, length = 0x00000040 MEMCFG : origin = 0x0005F400, length = 0x000000C0 NMIINTRUPT : origin = 0x00007060, length = 0x00000010 OUTPUTXBAR : origin = 0x00007A80, length = 0x00000040 CLBOUTPUTXBAR : origin = 0x00007BC0, length = 0x00000040 SYSPERIPHAC : origin = 0x0005D500, length = 0x00000200 PIECTRL : origin = 0x00000CE0, length = 0x0000001A PIEVECTTABLE : origin = 0x00000D00, length = 0x00000200 PMBUSA : origin = 0x00006400, length = 0x00000020 SCIA : origin = 0x00007200, length = 0x00000010 SPIA : origin = 0x00006100, length = 0x00000010 SPIB : origin = 0x00006110, length = 0x00000010 SYNCSOC : origin = 0x00007940, length = 0x00000006 WD : origin = 0x00007000, length = 0x0000002C XBAR : origin = 0x00007920, length = 0x00000020 XINT : origin = 0x00007070, length = 0x0000000C } SECTIONS { /*** PIE Vect Table and Boot ROM Variables Structures ***/ UNION run = PIEVECTTABLE { PieVectTableFile GROUP { EmuKeyVar EmuBModeVar EmuBootPinsVar FlashCallbackVar FlashScalingVar } } AccessProtectionRegsFile : > ACCESSPROTECTION, type=NOINIT AdcaRegsFile : > ADCA, type=NOINIT AdccRegsFile : > ADCC, type=NOINIT AdcaResultRegsFile : > ADCARESULT, type=NOINIT AdccResultRegsFile : > ADCCRESULT, type=NOINIT AnalogSubsysRegsFile : > ANALOGSUBSYS, type=NOINIT BgcrcCpuRegsFile : > BGCRCCPU, type=NOINIT CanaRegsFile : > CANA, type=NOINIT Clb1DataExchRegsFile : > CLB1DATAEXCH, type=NOINIT Clb2DataExchRegsFile : > CLB2DATAEXCH, type=NOINIT Clb1LogicCfgRegsFile : > CLB1LOGICCFG, type=NOINIT Clb2LogicCfgRegsFile : > CLB2LOGICCFG, type=NOINIT Clb1LogicCtrlRegsFile : > CLB1LOGICCTRL, type=NOINIT Clb2LogicCtrlRegsFile : > CLB2LOGICCTRL, type=NOINIT ClbXbarRegsFile : > CLBXBAR, type=NOINIT ClkCfgRegsFile : > CLKCFG, type=NOINIT Cmpss1RegsFile : > CMPSS1, type=NOINIT Cmpss2RegsFile : > CMPSS2, type=NOINIT Cmpss3RegsFile : > CMPSS3, type=NOINIT Cmpss4RegsFile : > CMPSS4, type=NOINIT CpuTimer0RegsFile : > CPUTIMER0, type=NOINIT CpuTimer1RegsFile : > CPUTIMER1, type=NOINIT CpuTimer2RegsFile : > CPUTIMER2, type=NOINIT CpuSysRegsFile : > CPUSYS, type=NOINIT Dcc0RegsFile : > DCC0, type=NOINIT Dcc1RegsFile : > DCC1, type=NOINIT // DcsmBank0Z1OtpRegsFile : > DCSMBANK0Z1OTP, type=NOINIT DcsmBank0Z1RegsFile : > DCSMBANK0Z1, type=NOINIT DcsmBank0Z2OtpRegsFile : > DCSMBANK0Z2OTP, type=NOINIT DcsmBank0Z2RegsFile : > DCSMBANK0Z2, type=NOINIT DcsmCommonRegsFile : > DCSMCOMMON, type=NOINIT DevCfgRegsFile : > DEVCFG, type=NOINIT DmaClaSrcSelRegsFile : > DMACLASRCSEL, type=NOINIT DmaRegsFile : > DMA, type=NOINIT ECap1RegsFile : > ECAP1, type=NOINIT ECap2RegsFile : > ECAP2, type=NOINIT ECap3RegsFile : > ECAP3, type=NOINIT EPwm1RegsFile : > EPWM1, type=NOINIT EPwm2RegsFile : > EPWM2, type=NOINIT EPwm3RegsFile : > EPWM3, type=NOINIT EPwm4RegsFile : > EPWM4, type=NOINIT EPwm5RegsFile : > EPWM5, type=NOINIT EPwm6RegsFile : > EPWM6, type=NOINIT EPwm7RegsFile : > EPWM7, type=NOINIT EPwmXbarRegsFile : > EPWMXBAR, type=NOINIT EQep1RegsFile : > EQEP1, type=NOINIT EQep2RegsFile : > EQEP2, type=NOINIT EradCounter1RegsFile : > ERADCOUNTER1, type=NOINIT EradCounter2RegsFile : > ERADCOUNTER2, type=NOINIT EradCounter3RegsFile : > ERADCOUNTER3, type=NOINIT EradCounter4RegsFile : > ERADCOUNTER4, type=NOINIT EradCRCGlobalRegsFile : > ERADCRCGLOBAL, type=NOINIT EradCRC1RegsFile : > ERADCRC1, type=NOINIT EradCRC2RegsFile : > ERADCRC2, type=NOINIT EradCRC3RegsFile : > ERADCRC3, type=NOINIT EradCRC4RegsFile : > ERADCRC4, type=NOINIT EradCRC5RegsFile : > ERADCRC5, type=NOINIT EradCRC6RegsFile : > ERADCRC6, type=NOINIT EradCRC7RegsFile : > ERADCRC7, type=NOINIT EradCRC8RegsFile : > ERADCRC8, type=NOINIT EradGlobalRegsFile : > ERADGLOBAL, type=NOINIT EradHWBP1RegsFile : > ERADHWBP1, type=NOINIT EradHWBP2RegsFile : > ERADHWBP2, type=NOINIT EradHWBP3RegsFile : > ERADHWBP3, type=NOINIT EradHWBP4RegsFile : > ERADHWBP4, type=NOINIT EradHWBP5RegsFile : > ERADHWBP5, type=NOINIT EradHWBP6RegsFile : > ERADHWBP6, type=NOINIT EradHWBP7RegsFile : > ERADHWBP7, type=NOINIT EradHWBP8RegsFile : > ERADHWBP8, type=NOINIT Flash0CtrlRegsFile : > FLASH0CTRL, type=NOINIT Flash0EccRegsFile : > FLASH0ECC, type=NOINIT FsiRxaRegsFile : > FSIRXA, type=NOINIT FsiTxaRegsFile : > FSITXA, type=NOINIT GpioCtrlRegsFile : > GPIOCTRL, type=NOINIT GpioDataReadRegsFile : > GPIODATAREAD, type=NOINIT GpioDataRegsFile : > GPIODATA, type=NOINIT HicRegsFile : > HIC, type=NOINIT HRCap3RegsFile : > HRCAP3, type=NOINIT I2caRegsFile : > I2CA, type=NOINIT I2cbRegsFile : > I2CB, type=NOINIT InputXbarRegsFile : > INPUTXBAR, type=NOINIT ClbInputXbarRegsFile : > CLBINPUTXBAR, type=NOINIT LinaRegsFile : > LINA, type=NOINIT LinbRegsFile : > LINB, type=NOINIT MemoryErrorRegsFile : > MEMORYERROR, type=NOINIT MemCfgRegsFile : > MEMCFG, type=NOINIT NmiIntruptRegsFile : > NMIINTRUPT, type=NOINIT OutputXbarRegsFile : > OUTPUTXBAR, type=NOINIT ClbOutputXbarRegsFile : > CLBOUTPUTXBAR, type=NOINIT SysPeriphAcRegsFile : > SYSPERIPHAC, type=NOINIT PieCtrlRegsFile : > PIECTRL, type=NOINIT PieVectTableFile : > PIEVECTTABLE, type=NOINIT PmbusaRegsFile : > PMBUSA, type=NOINIT SciaRegsFile : > SCIA, type=NOINIT SpiaRegsFile : > SPIA, type=NOINIT SpibRegsFile : > SPIB, type=NOINIT SyncSocRegsFile : > SYNCSOC, type=NOINIT WdRegsFile : > WD, type=NOINIT XbarRegsFile : > XBAR, type=NOINIT XintRegsFile : > XINT, type=NOINIT } /* //=========================================================================== // End of file. //=========================================================================== */
