Part Number: TMS320F28379D
在运行利用emif与FPGA通讯程序时,ccs报错如下:
C28xx_CPU1: JTAG Communication Error: (Error -1135 @ 0x83383) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.5.0.00143)
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
请问是什么原因怎么解决
