以前在CCS3.3的平台上编译的项目上,现在更换为CCS10,Tlv5.2.9
编译后,报错如下:如何解决?
warning #16002-D: build attribute vendor section TI missing in
"../rts32tiabi.lib<i_div32.obj>": compatibility cannot be determined
fatal error #16005: ABI of "../rts32tiabi.lib<i_div32.obj>" (TI-ARM7) is
incompatible with "./clear_program_flash.obj" (TI-ARM9)
