**** Build of configuration CPU1_RAM for project led_ex1_blinky ****
"C:\\ti\\ccs1271\\ccs\\utils\\bin\\gmake" -k -j 16 all -O
Building file: "../led_ex1_blinky.syscfg"
Invoking: SysConfig
"C:/ti/ccs1271/ccs/utils/sysconfig_1.20.0/sysconfig_cli.bat" --script "C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky/led_ex1_blinky.syscfg" -o "syscfg" -s "C:/ti/c2000/C2000Ware_5_02_00_00/.metadata/sdk.json" --compiler ccs
Running script...
Validating...
info: CPUSELx(/driverlib/clocktree/mux.js) cpu_sel_mux: For enabling peripherals, use the /driverlib/sysctl.js enable_SYSCTL_PERIPH_CLK_TIMER0
info: PERx_CPU1_SYSCLK_GATE(/driverlib/clocktree/unknown.js) cpu1_sysclk_gate: For enabling peripherals, use the /driverlib/sysctl.js enable_SYSCTL_PERIPH_CLK_TIMER0
info: PERx_CPU2_SYSCLK_GATE(/driverlib/clocktree/unknown.js) cpu2_sysclk_gate: For enabling peripherals, use the /driverlib/sysctl.js enable_SYSCTL_PERIPH_CLK_TIMER0
Generating Code (led_ex1_blinky.syscfg)...
should not be In here
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\board.c...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\board.h...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\board.cmd.genlibs...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\board.opt...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\board.json...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\pinmux.csv...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\device.c...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\device.h...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\device_cmd.cmd...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\device_cmd.c...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\device_cmd.h...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\device_cmd.opt...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\device_cmd.cmd.genlibs...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\c2000ware_libraries.cmd.genlibs...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\c2000ware_libraries.opt...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\c2000ware_libraries.c...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\c2000ware_libraries.h...
Writing C:\ti\c2000\C2000Ware_5_02_00_00\driverlib\f28p65x\examples\c28x\led\led_ex1_blinky\CPU1_RAM\syscfg\clocktree.h...
Finished building: "../led_ex1_blinky.syscfg"
Building file: "../led_ex1_blinky.c"
Invoking: C2000 Compiler
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla2 --float_support=fpu64 --tmu_support=tmu1 --vcu_support=vcrc -Ooff --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00" --include_path="C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/include" --define=DEBUG --define=CPU1 --define=RAM --define=generic_ram_lnk --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="led_ex1_blinky.d_raw" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky/CPU1_RAM/syscfg" --cmd_file="syscfg/board.opt" --cmd_file="syscfg/device_cmd.opt" --cmd_file="syscfg/c2000ware_libraries.opt" "../led_ex1_blinky.c"
>> Compilation failure
subdir_rules.mk:9: recipe for target 'led_ex1_blinky.obj' failed
"../led_ex1_blinky.c", line 1: error #7: unrecognized token
"../led_ex1_blinky.c", line 1: warning #78-D: this declaration has no storage class or type specifier
"../led_ex1_blinky.c", line 1: error #66: expected a ";"
"../led_ex1_blinky.c", line 1: warning #1268-D: null (zero) character in input line ignored
"../led_ex1_blinky.c", line 1: warning #1269-D: null (zero) character in string or character constant
"../led_ex1_blinky.c", line 1: error #8: missing closing quote
"../led_ex1_blinky.c", line 2: warning #1-D: last line of file ends without a newline
"../led_ex1_blinky.c", line 2: error #7: unrecognized token
"../led_ex1_blinky.c", line 2: error #19: extra text after expected end of number
"../led_ex1_blinky.c", line 2: error #8: missing closing quote
84 errors detected in the compilation of "../led_ex1_blinky.c".
gmake: *** [led_ex1_blinky.obj] Error 1
Building file: "C:/ti/c2000/C2000Ware_5_02_00_00/device_support/f28p65x/common/source/f28p65x_codestartbranch.asm"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla2 --float_support=fpu64 --tmu_support=tmu1 --vcu_support=vcrc -Ooff --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00" --include_path="C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/include" --define=DEBUG --define=CPU1 --define=RAM --define=generic_ram_lnk --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="f28p65x_codestartbranch.d_raw" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky/CPU1_RAM/syscfg" --cmd_file="syscfg/board.opt" --cmd_file="syscfg/device_cmd.opt" --cmd_file="syscfg/c2000ware_libraries.opt" "C:/ti/c2000/C2000Ware_5_02_00_00/device_support/f28p65x/common/source/f28p65x_codestartbranch.asm"
Finished building: "C:/ti/c2000/C2000Ware_5_02_00_00/device_support/f28p65x/common/source/f28p65x_codestartbranch.asm"
Building file: "syscfg/device_cmd.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla2 --float_support=fpu64 --tmu_support=tmu1 --vcu_support=vcrc -Ooff --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00" --include_path="C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/include" --define=DEBUG --define=CPU1 --define=RAM --define=generic_ram_lnk --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="syscfg/device_cmd.d_raw" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky/CPU1_RAM/syscfg" --obj_directory="syscfg" --cmd_file="syscfg/board.opt" --cmd_file="syscfg/device_cmd.opt" --cmd_file="syscfg/c2000ware_libraries.opt" "syscfg/device_cmd.c"
Finished building: "syscfg/device_cmd.c"
Building file: "syscfg/c2000ware_libraries.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla2 --float_support=fpu64 --tmu_support=tmu1 --vcu_support=vcrc -Ooff --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00" --include_path="C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/include" --define=DEBUG --define=CPU1 --define=RAM --define=generic_ram_lnk --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="syscfg/c2000ware_libraries.d_raw" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky/CPU1_RAM/syscfg" --obj_directory="syscfg" --cmd_file="syscfg/board.opt" --cmd_file="syscfg/device_cmd.opt" --cmd_file="syscfg/c2000ware_libraries.opt" "syscfg/c2000ware_libraries.c"
Finished building: "syscfg/c2000ware_libraries.c"
Building file: "syscfg/device.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla2 --float_support=fpu64 --tmu_support=tmu1 --vcu_support=vcrc -Ooff --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00" --include_path="C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/include" --define=DEBUG --define=CPU1 --define=RAM --define=generic_ram_lnk --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="syscfg/device.d_raw" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky/CPU1_RAM/syscfg" --obj_directory="syscfg" --cmd_file="syscfg/board.opt" --cmd_file="syscfg/device_cmd.opt" --cmd_file="syscfg/c2000ware_libraries.opt" "syscfg/device.c"
Finished building: "syscfg/device.c"
Building file: "syscfg/board.c"
"C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla2 --float_support=fpu64 --tmu_support=tmu1 --vcu_support=vcrc -Ooff --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00" --include_path="C:/ti/ccs1271/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/include" --define=DEBUG --define=CPU1 --define=RAM --define=generic_ram_lnk --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="syscfg/board.d_raw" --include_path="C:/ti/c2000/C2000Ware_5_02_00_00/driverlib/f28p65x/examples/c28x/led/led_ex1_blinky/CPU1_RAM/syscfg" --obj_directory="syscfg" --cmd_file="syscfg/board.opt" --cmd_file="syscfg/device_cmd.opt" --cmd_file="syscfg/c2000ware_libraries.opt" "syscfg/board.c"
Finished building: "syscfg/board.c"
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
