关于ePWM周期更新时机?
   // Setup TBCLK
   EPwm1Regs.TBPRD = EPWM1_TIMER_TBPRD;           // Set timer period 801 TBCLKs
   EPwm1Regs.TBPHS.half.TBPHS = 0x0000;           // Phase is 0
   EPwm1Regs.TBCTR = 0x0000;                      // Clear counter
   // Set Compare values
   EPwm1Regs.CMPA.half.CMPA = EPWM1_MIN_CMPA;     // Set compare A value
   EPwm1Regs.CMPB = EPWM1_MAX_CMPB;               // Set Compare B value
   // Setup counter mode
   EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up
   EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;        // Disable phase loading
   EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;       // Clock ratio to SYSCLKOUT
   EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
   // Setup shadowing
   EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
   EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
   EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;  // Load on Zero
   EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
   // Set actions
   EPwm1Regs.AQCTLA.bit.CAU = AQ_SET;             // Set PWM1A on event A, up count
   EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR;           // Clear PWM1A on event A, down count
   EPwm1Regs.AQCTLB.bit.CBU = AQ_SET;             // Set PWM1B on event B, up count
   EPwm1Regs.AQCTLB.bit.CBD = AQ_CLEAR;           // Clear PWM1B on event B, down count
代码如上,若改变   EPwm1Regs.CMPA.half.CMPA 与   EPwm1Regs.CMPB的值,那么会在CTR=ZERO时将EPwm1Regs.CMPA.half.CMPA 与   EPwm1Regs.CMPB的值进行更新,问题是若改变EPwm1Regs.TBPRD 的值,会在什么时候更新?
