tms320f28069工程编译的问题
我的工程文件在另一台电脑里的CCS4编译可以通过,可是换一台电脑,改工程文件就编译不过,编译提示如下:
<Linking>
"../F2806x_common/cmd/F28069.cmd", line 68: error: RAML0 memory range has
  already been specified
"../F2806x_common/cmd/F28069.cmd", line 68: error: RAML0 memory range overlaps
  existing memory range RAML0
"../F2806x_common/cmd/F28069.cmd", line 69: error: RAML1 memory range has
"../F2806x_common/cmd/F28069.cmd", line 69: error: RAML1 memory range overlaps
  existing memory range RAML1
"../F2806x_common/cmd/F28069.cmd", line 70: error: OTP memory range has already
  been specified
"../F2806x_common/cmd/F28069.cmd", line 70: error: OTP memory range overlaps
  existing memory range OTP
"../F2806x_common/cmd/F28069.cmd", line 72: error: FLASHH memory range has
"../F2806x_common/cmd/F28069.cmd", line 72: error: FLASHH memory range overlaps
  existing memory range FLASHH
"../F2806x_common/cmd/F28069.cmd", line 73: error: FLASHG memory range has
"../F2806x_common/cmd/F28069.cmd", line 73: error: FLASHG memory range overlaps
  existing memory range FLASHG
"../F2806x_common/cmd/F28069.cmd", line 74: error: FLASHF memory range has
"../F2806x_common/cmd/F28069.cmd", line 74: error: FLASHF memory range overlaps
  existing memory range FLASHF
"../F2806x_common/cmd/F28069.cmd", line 75: error: FLASHE memory range has
"../F2806x_common/cmd/F28069.cmd", line 75: error: FLASHE memory range overlaps
  existing memory range FLASHE
"../F2806x_common/cmd/F28069.cmd", line 76: error: FLASHD memory range has
"../F2806x_common/cmd/F28069.cmd", line 76: error: FLASHD memory range overlaps
  existing memory range FLASHD
"../F2806x_common/cmd/F28069.cmd", line 77: error: FLASHC memory range has
"../F2806x_common/cmd/F28069.cmd", line 77: error: FLASHC memory range overlaps
  existing memory range FLASHC
"../F2806x_common/cmd/F28069.cmd", line 78: error: FLASHA memory range has
"../F2806x_common/cmd/F28069.cmd", line 78: error: FLASHA memory range overlaps
  existing memory range FLASHA
"../F2806x_common/cmd/F28069.cmd", line 79: error: CSM_RSVD memory range has
  overlaps existing memory range CSM_RSVD
"../F2806x_common/cmd/F28069.cmd", line 80: error: BEGIN memory range has
"../F2806x_common/cmd/F28069.cmd", line 80: error: BEGIN memory range overlaps
  existing memory range BEGIN
"../F2806x_common/cmd/F28069.cmd", line 81: error: CSM_PWL_P0 memory range has
  overlaps existing memory range CSM_PWL_P0
"../F2806x_common/cmd/F28069.cmd", line 83: error: FPUTABLES memory range has
  overlaps existing memory range FPUTABLES
"../F2806x_common/cmd/F28069.cmd", line 84: error: IQTABLES memory range has
  overlaps existing memory range IQTABLES
"../F2806x_common/cmd/F28069.cmd", line 85: error: IQTABLES2 memory range has
  overlaps existing memory range IQTABLES2
"../F2806x_common/cmd/F28069.cmd", line 86: error: IQTABLES3 memory range has
这个是什么问题呢?
