F28M35工程从ccs5移到ccs6后编译无误,下载报错
工程在另一台装有ccs5的电脑调试好之后拷贝到一台装有ccs6的电脑,编译同样无误,但是下载会报错,提示如下:
C28xx_0: Loader: One or more sections of your program falls into a memory region that is not writable.  These regions will not actually be written to the target.  Check your linker configuration and/or memory map.
C28xx_0: File Loader: Verification failed: Values at address 0x000000000013EBB2 do not match Please verify target memory and memory map.
我用的CMD文件是官方的F28M35H52C1_c28.cmd折腾很久没有解决问题。
我在这一块算是新手,板子是非官方的PCB
