使用CPUTIME 触发ADC 采集信号,并且用DMA 搬运数据。具体具体实现是这样的,cputime 以1MHZ 的速率触发ADC采集数据,ADC只是采集一路,使用的是A0,采集完成使用DMA将数据搬运,程序运行的情况是DMA end int 能正常触发,但是adc buff 里面没有数值!
//############################################################################# // // FILE: empty_driverlib_main.c // //! \addtogroup driver_example_list //! <h1>Empty Project Example</h1> //! //! This example is an empty project setup for Driverlib development. //! // //############################################################################# // // // $Copyright: // Copyright (C) 2024 Texas Instruments Incorporated - http://www.ti.com/ // // Redistribution and use in source and binary forms, with or without // modification, are permitted provided that the following conditions // are met: // // Redistributions of source code must retain the above copyright // notice, this list of conditions and the following disclaimer. // // Redistributions in binary form must reproduce the above copyright // notice, this list of conditions and the following disclaimer in the // documentation and/or other materials provided with the // distribution. // // Neither the name of Texas Instruments Incorporated nor the names of // its contributors may be used to endorse or promote products derived // from this software without specific prior written permission. // // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. // $ //############################################################################# // // Included Files // #include "driverlib.h" #include "device.h" #include "board.h" #include "c2000ware_libraries.h" uint16_t adc_global_buf[myDMA0_TRANSFERSIZE]; const void *adc_result_reg = (uint16_t*)(myADC0_RESULT_BASE + (uint32_t)ADC_RESULTx_OFFSET_BASE + (uint32_t)myADC0_SOC0); const void *adc_cap_buf = adc_global_buf; uint16_t sample_done = 0; __interrupt void INT_myDMA0_ISR(void) { DMA_stopChannel(myDMA0_BASE); EALLOW; Interrupt_clearACKGroup(INT_myDMA0_INTERRUPT_ACK_GROUP); EDIS; sample_done = 1; // ADC_readResult } ////#define INT_myADC0_1 INT_ADCA1 ////#define INT_myADC0_1_INTERRUPT_ACK_GROUP INTERRUPT_ACK_GROUP1 //volatile uint16_t adc_val; //__interrupt void INT_myADC0_1_ISR(void) //{ // adc_val = ADC_readResult(myADC0_RESULT_BASE,myADC0_SOC0); // Interrupt_clearACKGroup(INT_myADC0_1_INTERRUPT_ACK_GROUP); //} void main(void) { // // Initialize device clock and peripherals // Device_init(); // // Disable pin locks and enable internal pull-ups. // Device_initGPIO(); // // Initialize PIE and clear PIE registers. Disables CPU interrupts. // Interrupt_initModule(); // // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // Interrupt_initVectorTable(); // // PinMux and Peripheral Initialization // Board_init(); // // C2000Ware Library initialization // C2000Ware_libraries_init(); // // Enable Global Interrupt (INTM) and real time interrupt (DBGM) // EINT; ERTM; int i; for( i = 0; i < myDMA0_TRANSFERSIZE; ++i){ adc_global_buf[i] = i; } DMA_clearTriggerFlag(myDMA0_BASE); ADC_clearInterruptStatus(myADC0_BASE,ADC_INT_NUMBER1); DMA_startChannel(myDMA0_BASE); CPUTimer_startTimer(myCPUTIMER0_BASE); while(1) { if(sample_done == 1){ ESTOP0; } } } // // End of File //
/** * These arguments were used when this file was generated. They will be automatically applied on subsequent loads * via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments. * @cliArgs --device "F28003x" --package "100PZ" --part "F28003x_100PZ" --context "system" --product "C2000WARE@5.02.00.00" * @versions {"tool":"1.20.0+3587"} */ /** * Import the modules used in this configuration. */ const adc = scripting.addModule("/driverlib/adc.js", {}, false); const adc1 = adc.addInstance(); const analog = scripting.addModule("/driverlib/analog.js", {}, false); const analog1 = analog.addInstance(); const asysctl = scripting.addModule("/driverlib/asysctl.js"); const cputimer = scripting.addModule("/driverlib/cputimer.js", {}, false); const cputimer1 = cputimer.addInstance(); const dma = scripting.addModule("/driverlib/dma.js", {}, false); const dma1 = dma.addInstance(); /** * Write custom configuration values to the imported modules. */ adc1.$name = "myADC0"; adc1.adcClockPrescaler = "ADC_CLK_DIV_2_0"; adc1.soc0Trigger = "ADC_TRIGGER_CPU1_TINT0"; adc1.soc0SampleWindow = 9; adc1.soc1Channel = "ADC_CH_ADCIN1"; adc1.enabledSOCs = ["ADC_SOC_NUMBER0"]; adc1.interruptPulseMode = "ADC_PULSE_END_OF_CONV"; adc1.enableInterrupt1 = true; adc1.enableInterrupt1ContinuousMode = true; adc1.registerInterrupts = ["1"]; adc1.soc0InterruptTrigger = "ADC_INT_SOC_TRIGGER_ADCINT1"; adc1.enableInterrupt2 = true; adc1.enableInterrupt2ContinuousMode = true; adc1.enableInterrupt3 = true; adc1.enableInterrupt3ContinuousMode = true; adc1.enableInterrupt4 = true; adc1.enableInterrupt4ContinuousMode = true; adc1.enabledInts = ["ADC_INT_NUMBER1"]; adc1.useInterrupts = false; analog1.$name = "myANALOGPinMux0"; adc1.analog = analog1; analog1.useCase = "CUSTOM"; analog1.useInterfacePins = ["A0/B15/C15/DACA_OUT"]; analog1.analog.$assign = "ANALOG"; analog1.analog["a0/b15/c15/daca_outPin"].$assign = "A0/B15/C15/DACA_OUT"; asysctl.analogReference = "INTERNAL"; asysctl.analogReferenceVoltage = "1P65"; cputimer1.$name = "myCPUTIMER0"; cputimer1.enableInterrupt = true; cputimer1.timerPeriod = 120; cputimer1.emulationMode = "CPUTIMER_EMULATIONMODE_RUNFREE"; dma1.$name = "myDMA0"; dma1.enableTriggers = true; dma1.useInterrupts = true; dma1.registerInterrupts = true; dma1.enableInterrupts = true; dma1.transferSize = 512; dma1.destAddressInputMode = "VARIABLE"; dma1.destAddressVariable = "adc_cap_buf"; dma1.srcAddressVariable = "adc_result_reg"; dma1.interruptMode = "DMA_INT_AT_END"; dma1.destTransferStep = 1; dma1.destBurstStep = 1; dma1.emulationMode = "DMA_EMULATION_FREE_RUN"; dma1.srcAddressInputMode = "VARIABLE"; dma1.triggerSource = "DMA_TRIGGER_ADCA1"; dma1.dmaInt.enableInterrupt = true;
