目标芯片是28054F,好像改过一次debug的设置,后来就一直弹出这个提示:
Device blocked debug access because it is currently executing non-debugable code. You may retry after the device has had time to enter debuggable code, or you may cancel, disable realtime mode, and then attempt to connect.
提示的两种方法都是过了,不行的。
怎么才能解决呢??求助高手!!
