TMDSCNCD28027F+TMDSHVMTRINSPIN load program problem?黄色高压开发板
Other Parts Discussed in Thread: TMDSCNCD28027F, TMDSHVMTRINSPIN, MOTORWARE
TMDSCNCD28027F+TMDSHVMTRINSPIN+XDS100V3,J5,J9有跳线帽,USB口供电,TEST CONNECT可以通过,也可以连接到TARGET,就是LOAD PROGRAM提示错误,
C28xx: Error occurred during flash operation: Timed out waiting for target to halt while executing FlashAPIInterface2802xV2_00.out
C28xx: Flash operation timed out waiting for the algorithm to complete. Operation cancelled.
C28xx: File Loader: Memory write failed: Unknown error
C28xx: GEL: File: C:\ti\motorware\motorware_1_01_00_14\sw\solutions\instaspin_foc\boards\hvkit_rev1p1\f28x\f2802xF\projects\ccs5\proj_lab01\Flash\proj_lab01.out: Load failed.
请问有朋友知道这个问题怎么解决吗,望告知,谢谢!
  • Jacky,
    1. 试下在target 窗口中直接选择F28027后lunch,然后连接,再下载试试;
    2. 检查下你的CMD文件等,确保工程等是对的;
    3. 或者你用的是套件,直接连GUI看看是否正常;
