Use CCS for free - By default when you install Code Composer Studio a free license will be enabled that supports working with development boards with an onboard debug interface, XDS1xx class debug probes, MSP430 with 16KB code size limit when using the TI compiler and 32KB code size limit with MSP432 and no limit when using GCC. A 90-day evaluation license is also available.
