TMS320F2808: TMS32F2808PZA 编程失败
Part Number: TMS320F2808
MPN:TMS32F2808PZA,Reading the datasheet and found the DSP has lock functional . Suspect that the DSP was lock when programmed FW , even swape DSP , it was also programmed fail Need supplier analysis the failing sample if it was locked and if yes ,please analyze the reasonable .
