Part Number: TMS320F280025
Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
没看懂是不是权限问题,因为C盘有管理员权限。大家帮忙分析下原因
"C:\\ti\\ccs1240\\ccs\\utils\\bin\\gmake" -k -j 20 all -O
Building file: "../epwm_ex3_synchronization.syscfg"
Invoking: SysConfig
"C:/ti/ccs1240/ccs/utils/sysconfig_1.17.0/sysconfig_cli.bat" -s "C:/ti/C2000Ware_5_04_00_00/.metadata/sdk.json" -d "F28002x" --script "C:/Users/Administrator/workspace_v12/epwm_ex3_synchronization/epwm_ex3_synchronization.syscfg" -o "syscfg" --package 80QFP --part F28002x_80QFP --compiler ccs
subdir_rules.mk:16: recipe for target 'build-347603361' failed
Error: C:\ti\C2000Ware_5_04_00_00\.metadata\sdk.json: Validation failed: [
"keyword": "additionalProperties",
"dataPath": "",
"schemaPath": "#/additionalProperties",
"params": {
"additionalProperty": "migrationProducts"
"message": "should NOT have additional properties"
at Object.validateMeta (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\JSONschemaValidator.ts:49:9)
at Object.toProductFile (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\product\parseProductFile.ts:20:14)
at iteratee (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\product\loadResources.ts:80:46)
at baseMap (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\node_modules\lodash\lodash.js:653:23)
at Function.map (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\node_modules\lodash\lodash.js:9621:51)
at products (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\product\loadResources.ts:80:21)
at products (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\args\resolveProductArgs.ts:77:8)
at Object.products [as resolveProducts] (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\args\resolveProductArgs.ts:31:3)
at Object.resolvedArgs [as parseAndResolveArgs] (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\pinmux\services\args\parseAndResolveArgs.ts:43:8)
at Object.t.runCLI (C:\ti\ccs1240\ccs\utils\sysconfig_1.17.0\dist\webpack:\src\cli\runCli.ts:31:9)
gmake: *** [build-347603361] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
