Other Parts Discussed in Thread: C2000WARE, SYSCONFIG
例程文件路径:C:\ti\c2000\C2000Ware_5_04_00_00\driverlib\f2837xd\examples\cpu1\empty_projects
编译后的报错信息:
**** Build of configuration CPU1_FLASH for project clb_ex8_external_signal_AND_gate ****
"D:\\ti\\ccs1250\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
Building file: "../clb_ex8_external_signal_AND_gate.syscfg"
Invoking: SysConfig
"D:/ti/ccs1250/ccs/utils/sysconfig_1.18.0/sysconfig_cli.bat" -s "C:/ti/c2000/C2000Ware_5_04_00_00/.metadata/sdk.json" -d "F2837xD" --script "D:/ti workspace_v12/clb_ex8_external_signal_AND_gate/clb_ex8_external_signal_AND_gate.syscfg" -o "syscfg" --package F2837xD_176PTP --part F2837xD_176PTP --compiler ccs
subdir_rules.mk:16: recipe for target 'build-415176289' failed
Error: C:\ti\c2000\C2000Ware_5_04_00_00\.metadata\sdk.json: Validation failed: [
"keyword": "additionalProperties",
"dataPath": "",
"schemaPath": "#/additionalProperties",
"params": {
"additionalProperty": "migrationProducts"
"message": "should NOT have additional properties"
at Object.validateMeta (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\src\pinmux\services\JSONschemaValidator.ts:49:9)
at Object.toProductFile (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\src\pinmux\services\product\parseProductFile.ts:20:14)
at iteratee (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\src\pinmux\services\product\loadResources.ts:80:46)
at baseMap (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\node_modules\lodash\lodash.js:653:23)
at Function.map (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\node_modules\lodash\lodash.js:9621:51)
at products (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\src\pinmux\services\product\loadResources.ts:80:21)
at products (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\src\pinmux\services\args\resolveProductArgs.ts:77:8)
at Object.products [as resolveProducts] (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\src\pinmux\services\args\resolveProductArgs.ts:31:3)
at Object.resolvedArgs [as parseAndResolveArgs] (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\src\pinmux\services\args\parseAndResolveArgs.ts:43:8)
at Object.t.runCLI (D:\ti\ccs1250\ccs\utils\sysconfig_1.18.0\dist\webpack:\src\cli\runCli.ts:31:9)
gmake: *** [build-415176289] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
