Other Parts Discussed in Thread: C2000WARE, SYSCONFIG
对C2000Ware_5_04_00_00\libraries\ai\feature_extract\c28\examples\ex_arc_fault_dataset_validation_f28004x的例程进行编译,报错如下:
**** Build of configuration CPU1_LAUNCHXL_FLASH for project ex_arc_fault_dataset_validation_f28004x ****
"D:\\CCS\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
Building file: "../c2000.syscfg"
Invoking: SysConfig
"D:/CCS/ccs/utils/sysconfig_1.16.1/sysconfig_cli.bat" -s "D:/C2000Ware_5_04_00_00/.metadata/sdk.json" -d "F28004x" --script "D:/ccsworkplace/ex_arc_fault_dataset_validation_f28004x/c2000.syscfg" -o "syscfg" --package F28004x_100PZ --part F28004x_100PZ --compiler ccs
subdir_rules.mk:16: recipe for target 'build-85191425' failed
Error: D:\C2000Ware_5_04_00_00\.metadata\sdk.json: Validation failed: [
"keyword": "additionalProperties",
"dataPath": "",
"schemaPath": "#/additionalProperties",
"params": {
"additionalProperty": "migrationProducts"
"message": "should NOT have additional properties"
at Object.validateMeta (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\src\pinmux\services\JSONschemaValidator.ts:49:9)
at Object.toProductFile (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\src\pinmux\services\product\parseProductFile.ts:20:14)
at iteratee (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\src\pinmux\services\product\loadResources.ts:80:46)
at baseMap (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\node_modules\lodash\lodash.js:653:23)
at Function.map (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\node_modules\lodash\lodash.js:9621:51)
at products (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\src\pinmux\services\product\loadResources.ts:80:21)
at products (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\src\pinmux\services\args\resolveProductArgs.ts:77:8)
at Object.products [as resolveProducts] (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\src\pinmux\services\args\resolveProductArgs.ts:31:3)
at Object.resolvedArgs [as parseAndResolveArgs] (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\src\pinmux\services\args\parseAndResolveArgs.ts:43:8)
at Object.t.runCLI (D:\CCS\ccs\utils\sysconfig_1.16.1\dist\webpack:\src\cli\runCli.ts:31:9)
gmake: *** [build-85191425] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
