Part Number: TMS320F280039C
Other Parts Discussed in Thread: SYSCONFIG, PMP23069, C2000WARE, POWERSUITE
使用CCS 20.1.0 打开import projects时,无法build ttplpfc_pmp23069_F28003X
SYSCONFIG是1.23.4最新版本
显示如下错误信息:
Error loading C:\Users\Eason.****\workspace_ccstheia\ttplpfc_pmp23069_F28004x\main.syscfg
Would you like to re-try in compatibility mode?
Error: Exception occurred calling scripting.addModule()
at Object.addModule (localhost:58866/.../ui.js:312:1192918) at eval (C:\Users\Eason.****\workspace_ccstheia\ttplpfc_pmp23069_F28004x\main.syscfg:12:28) at read (localhost:58866/.../ui.js:312:1189538) at t.withDeprecatedAccess (localhost:58866/.../ui.js:312:755400) at t.runAsUserScript (localhost:58866/.../ui.js:312:1193110) at localhost:58866/.../ui.js:312:1189527 at Pt (localhost:58866/.../ui.js:234:4794) at Function.va (localhost:58866/.../ui.js:234:39864) at localhost:58866/.../ui.js:312:1189396 at Pt (localhost:58866/.../ui.js:234:4794) Caused by: Error: Resource not under a .meta folder: /Kit.json at t.FileSystemLoader.loadResourceSource (localhost:58866/.../ui.js:312:1149566) at t.FileSystemLoader.loadResource (localhost:58866/.../ui.js:312:1149223) at t.ResourceLoader.loadResource (localhost:58866/.../ui.js:312:1153375) at t.ResourceLoader.getResource (localhost:58866/.../ui.js:312:1154884) at Object.getScript (localhost:58866/.../ui.js:312:1157615) at eval (C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_04_00_00\powerSUITE\source\devkits\.meta\PMP23069\PMP23069.syscfg.js:49:25) at localhost:58866/.../ui.js:312:1153463 at t.internalBoundary (localhost:58866/.../ui.js:312:865866) at t.ResourceLoader.loadResource (localhost:58866/.../ui.js:312:1153457) at t.ResourceLoader.getResource (localhost:58866/.../ui.js:312:1154884)
