28069 ePWM模块间相移问题
在使用不同EPWM模块间移相设置时,EPwm4设置为up_down模式EPwm4Regs.TBPHS.half.TBPHS = (AlgorithmReg.PwmReg.LLC_PwmPeriod_Pre >> 1) ;// Phase is 90°,理论上可以得到90°的移相,在实际波形测试时相移位107°左右,需要-20才能得到90度相移,可以帮忙找下原因吗?谢谢!
配置代码如下:
#define BUCK_PWM_PERIOD           (562)  //Set PWM period =(90Mhz/80KHz)/2
#define LLC_PWM_PERIOD_80KHZ    (562)  //Set PWM period =(90Mhz/80KHz)/2
#define LLC_PWM_PERIOD_200KHZ   (225)  //Set PWM period =(90Mhz/200KHz)/2
void InitEPwm1(void)
      * 1.0 Setup Time-Base(TB)
    // Setup TBCLK
    EPwm1Regs.TBPRD = BUCK_PWM_PERIOD;     // Set timer period period
    EPwm1Regs.TBPHS.half.TBPHS = 0x0000;                // Phase is 0
    EPwm1Regs.TBCTR = 0x0000;                            // Clear counter
    // Set Compare values
    EPwm1Regs.CMPA.half.CMPA = BUCK_PWM_PERIOD;// Set compare A value
    EPwm1Regs.CMPB = 0;                                   // Set compare B value
    // Setup counter mode
    EPwm1Regs.TBCTL.bit.CTRMODE   = TB_COUNT_UPDOWN; // Count up and down
    EPwm1Regs.TBCTL.bit.PHSEN     = TB_DISABLE;      // Disable phase loading
    EPwm1Regs.TBCTL.bit.SYNCOSEL  = TB_SYNC_DISABLE; // SYNC_DISABLE
    EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;            // Clock ratio to SYSCLKOUT
    EPwm1Regs.TBCTL.bit.CLKDIV    = TB_DIV1;         // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
      * 2.0 Setup Counter Compare(CC)
    // Setup shadowing (CC)
    EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;      // Shadow mode.
    EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;    // Load on Zero
    EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
      * 3.0 Setup Action Qualifier(AQ)
    // Set actions (AQ)
    EPwm1Regs.AQCTLA.bit.CAU = AQ_SET;             // Set PWM1A on event A, up count
    EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR;               // Clear PWM1A on event A, down count
    EPwm1Regs.AQCTLB.bit.CBU = AQ_CLEAR ;           // Clear PWM1B on event B, up count
    EPwm1Regs.AQCTLB.bit.CBD = AQ_SET;              // Set PWM1B on event B, down count
      * 4.0 Setup Dead Band(DB)
      EPwm1Regs.DBCTL.bit.IN_MODE  = DBA_RED_DBB_FED; // EPWMxA In (from the action-qualifier) is the source for rising-edge delayed signal.
                                                     // EPWMxB In (from the action-qualifier) is the source for falling-edge delayed signal.
      EPwm1Regs.DBCTL.bit.POLSEL   = DB_ACTV_HI;      // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
      EPwm1Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;      // Dead-band generation is bypassed for both output signals.
      EPwm1Regs.DBRED = 45;                         // 500ns,not active
      EPwm1Regs.DBFED = 45;                         // 500ns,not active
      * 5.0 Setup PWM-Chopper (PC)
      EPwm1Regs.PCCTL.bit.CHPEN = 0;                  // Disable (bypass) PWM chopping function
      * 6.0 Digital Compare (DC)
    /*               比较器过流保护关驱动操作                                             */
      /* TZDCSEL\DCTRIPSEL\DCACTL\DCBCTL\DCFCTL\DCCAPCTL寄存器受保护 */
      /* 必须开启.                                                  */
      EALLOW;
      // Define an event (DCAEVT1) as OSHT to lock PWM
      EPwm1Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT;  /* DCAH = Comparator 1 output */
      EPwm1Regs.TZDCSEL.bit.DCAEVT1       = TZ_DCAH_HI;   /* DCAEVT1 =  DCAH low(will become active as Comparator output goes high)*/
     EPwm1Regs.DCACTL.bit.EVT1SRCSEL     = DC_EVT1;      /* DCAEVT1 = DCAEVT1 (not filtered) */
      EPwm1Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
      EPwm1Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
      EPwm1Regs.TZDCSEL.bit.DCBEVT1       = TZ_DCBH_HI;
      EPwm1Regs.DCBCTL.bit.EVT1SRCSEL     = DC_EVT1;
      EPwm1Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
      EDIS;
      * 7.0 Trip Zone(TZ)
      /* TZSEL/TZCTL/TZEINT/TZCLR/TZFRC/HRCNFG are EALLOW-protected registers */
      // Enable DCAEVT1 and DCBEVT1 are one shot trip sources
      // Note: DCxEVT1 events can be defined as one-shot.
      //       DCxEVT2 events can be defined as cycle-by-cycle.
      EALLOW;
      EPwm1Regs.TZSEL.bit.DCAEVT1 = 1;                  /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
      EPwm1Regs.TZSEL.bit.DCBEVT1 = 1;                  /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
      // DCAEVTx events can force EPWMxA
      // DCBEVTx events can force EPWMxB
      EPwm1Regs.TZCTL.bit.TZA     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1A will go low
      EPwm1Regs.TZCTL.bit.TZB     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1B will go low
      EPwm1Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
      EPwm1Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
      EDIS;
      * 8.0 Event Trigger and Interrupt(ET)
    // SOC
    EPwm1Regs.ETSEL.bit.SOCAEN  = 1;                 // 使能EPWMxSOCA;
    EPwm1Regs.ETSEL.bit.SOCASEL = ET_CTR_PRD;       // TBCTR=TBTRD,时触发SOCA;
    EPwm1Regs.ETPS.bit.SOCAPRD  = ET_1ST;           // Generate the EPWMxSOCA pulse on the first event
    EPwm1Regs.ETSEL.bit.SOCBEN  = 1;                 // 使能EPWMxSOCB;
    EPwm1Regs.ETSEL.bit.SOCBSEL = ET_CTR_PRD;       // TBCTR=TBTRD,时触发SOCB;
    EPwm1Regs.ETPS.bit.SOCBPRD  = ET_1ST;           // Generate the EPWMxSOCB pulse on the first event
    // Interrupt
    EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO;       // Select INT on Zero event
    EPwm1Regs.ETSEL.bit.INTEN  = 1;                 // 使能Enable INT,外设级中断允许
    EPwm1Regs.ETPS.bit.INTPRD  = ET_1ST;            // Generate an interrupt on the first event
* Function: InitEPwm2()
* Description: Initializes the EPwm2 module on the F2806x.
*              将PWM2A与PWM2B配置成互补驱动,以PWM1A为信号源
*              上升沿死区:500ns
*              下降沿死区:500ns
void InitEPwm2(void)
    // Setup TBCLK
    EPwm2Regs.TBPRD = LLC_PWM_PERIOD_200KHZ;                   // Set timer period period
    EPwm2Regs.TBPHS.half.TBPHS = 0x0000;                // Phase is 0
    EPwm2Regs.TBCTR = 0x0000;                            // Clear counter
    EPwm2Regs.CMPA.half.CMPA = LLC_PWM_PERIOD_200KHZ;// Set compare A value
    EPwm2Regs.CMPB = 0;                                   // Set compare B value
    EPwm2Regs.TBCTL.bit.CTRMODE   = TB_COUNT_UPDOWN; // Count up and down
    EPwm2Regs.TBCTL.bit.PHSEN     = TB_DISABLE;      // Disable phase loading
    EPwm2Regs.TBCTL.bit.SYNCOSEL  = TB_CTR_ZERO;     // CTR = zero时输出同步信号,EPWM2同步用
    EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;            // Clock ratio to SYSCLKOUT
    EPwm2Regs.TBCTL.bit.CLKDIV    = TB_DIV1;         // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
    EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;      // Shadow mode.
    EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;    // Load on Zero
    EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    // Set actions (AQ)
    EPwm2Regs.AQCTLA.bit.CAU = AQ_SET;             // Set PWM1A on event A, up count
    EPwm2Regs.AQCTLA.bit.CAD = AQ_CLEAR;               // Clear PWM1A on event A, down count
    EPwm2Regs.AQCTLB.bit.CBU = AQ_CLEAR ;           // Clear PWM1B on event B, up count
    EPwm2Regs.AQCTLB.bit.CBD = AQ_SET;              // Set PWM1B on event B, down count
      EPwm2Regs.DBCTL.bit.IN_MODE  = DBA_ALL;         // EPWMxA In (from the action-qualifier) is the source for both falling-edge and rising-edge delay.
      EPwm2Regs.DBCTL.bit.POLSEL   = DB_ACTV_HIC;     // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
      EPwm2Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;//DB_FULL_ENABLE;  // Dead-band generation is bypassed for both output signals.
      EPwm2Regs.DBRED = 45;                         // Rising-edge delay 500ns is active.
      EPwm2Regs.DBFED = 45;                         // Fising-edge delay 500ns is active.
      EPwm2Regs.PCCTL.bit.CHPEN = 0;                  // Disable (bypass) PWM chopping function
    /*               比较器过流保护关驱动操作                                             */
      /* 必须开启.                                                  */
      EALLOW;
      EPwm2Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT;  /* DCAH = Comparator 1 output */
      EPwm2Regs.TZDCSEL.bit.DCAEVT1       = TZ_DCAH_HI;   /* DCAEVT1 =  DCAH low(will become active as Comparator output goes high)*/
     EPwm2Regs.DCACTL.bit.EVT1SRCSEL     = DC_EVT1;      /* DCAEVT1 = DCAEVT1 (not filtered) */
      EPwm2Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
      EPwm2Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
      EPwm2Regs.TZDCSEL.bit.DCBEVT1       = TZ_DCBH_HI;
      EPwm2Regs.DCBCTL.bit.EVT1SRCSEL     = DC_EVT1;
      EPwm2Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
      EDIS;
      * 7.0 Trip Zone(TZ)
      EALLOW;
      EPwm2Regs.TZSEL.bit.DCAEVT1 = 1;                  /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
      EPwm2Regs.TZSEL.bit.DCBEVT1 = 1;                  /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
      EPwm2Regs.TZCTL.bit.TZA     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1A will go low
      EPwm2Regs.TZCTL.bit.TZB     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1B will go low
      EPwm2Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
      EPwm2Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
      EDIS;
    // SOC
    //None
    // Interrupt
    EPwm2Regs.ETSEL.bit.INTSEL = ET_DCAEVT1SOC;       // Select INT on Zero event
    EPwm2Regs.ETSEL.bit.INTEN  = 0;                   // Disable INT, 外设级中断允许
    EPwm2Regs.ETPS.bit.INTPRD  = ET_DISABLE;          // Generate an interrupt on the first event
* Function: InitEPwm3()
* Description: Initializes the EPwm3 module on the F2806x.
*              上升沿死区:500ns
*              下降沿死区:500ns
void InitEPwm3(void)
    // Setup TBCLK
    EPwm3Regs.TBPRD = LLC_PWM_PERIOD_200KHZ;                   // Set timer period period
    EPwm3Regs.TBPHS.half.TBPHS = 0x0000;                // Phase is 0
    EPwm3Regs.TBCTR = 0x0000;                            // Clear counter
    EPwm3Regs.CMPA.half.CMPA = LLC_PWM_PERIOD_200KHZ;       // Set compare A value
    EPwm3Regs.CMPB = 0;                                   // Set compare B value
    EPwm3Regs.TBCTL.bit.CTRMODE   = TB_COUNT_UPDOWN; // Count up and down
    EPwm3Regs.TBCTL.bit.PHSEN     = TB_ENABLE;      // Disable phase loading
    EPwm3Regs.TBCTL.bit.SYNCOSEL  = TB_SYNC_IN;//TB_CTR_ZERO;     // CTR = zero时输出同步信号,EPWM2同步用
    EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;            // Clock ratio to SYSCLKOUT
    EPwm3Regs.TBCTL.bit.CLKDIV    = TB_DIV1;         // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
    EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;      // Shadow mode.
    EPwm3Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;    // Load on Zero
    EPwm3Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    // Set actions (AQ)
 * 变压器需要取反,2015.12.01
    EPwm3Regs.AQCTLA.bit.CAU = AQ_SET;             // Set PWM1A on event A, up count
    EPwm3Regs.AQCTLA.bit.CAD = AQ_CLEAR;               // Clear PWM1A on event A, down count
    EPwm3Regs.AQCTLB.bit.CBU = AQ_CLEAR;           // Clear PWM1B on event B, up count
    EPwm3Regs.AQCTLB.bit.CBD = AQ_SET;              // Set PWM1B on event B, down count
    EPwm3Regs.AQCTLA.bit.CBU = AQ_CLEAR;               // Set PWM1A on event A, up count
    EPwm3Regs.AQCTLA.bit.CBD = AQ_SET;              // Clear PWM1A on event A, down count
    EPwm3Regs.AQCTLB.bit.CAU = AQ_SET;           // Clear PWM1B on event B, up count
    EPwm3Regs.AQCTLB.bit.CAD = AQ_CLEAR;              // Set PWM1B on event B, down count
      EPwm3Regs.DBCTL.bit.IN_MODE  = DBA_ALL;         // EPWMxA In (from the action-qualifier) is the source for both falling-edge and rising-edge delay.
      EPwm3Regs.DBCTL.bit.POLSEL   = DB_ACTV_HIC;     // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
      EPwm3Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;      // Dead-band generation is bypassed for both output signals.
      EPwm3Regs.DBRED = 45;                         // Rising-edge delay 500ns is active.
      EPwm3Regs.DBFED = 45;                         // Fising-edge delay 500ns is active.
      EPwm3Regs.PCCTL.bit.CHPEN = 0;                  // Disable (bypass) PWM chopping function
    /*               比较器过流保护关驱动操作                                             */
      /* 必须开启.                                                  */
      EALLOW;
      EPwm3Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT;  /* DCAH = Comparator 1 output */
      EPwm3Regs.TZDCSEL.bit.DCAEVT1       = TZ_DCAH_HI;   /* DCAEVT1 =  DCAH low(will become active as Comparator output goes high)*/
     EPwm3Regs.DCACTL.bit.EVT1SRCSEL     = DC_EVT1;      /* DCAEVT1 = DCAEVT1 (not filtered) */
      EPwm3Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
      EPwm3Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
      EPwm3Regs.TZDCSEL.bit.DCBEVT1       = TZ_DCBH_HI;
      EPwm3Regs.DCBCTL.bit.EVT1SRCSEL     = DC_EVT1;
      EPwm3Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
      EDIS;
      * 7.0 Trip Zone(TZ)
      EALLOW;
      EPwm3Regs.TZSEL.bit.DCAEVT1 = 1;                  /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
      EPwm3Regs.TZSEL.bit.DCBEVT1 = 1;                  /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
      EPwm3Regs.TZCTL.bit.TZA     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1A will go low
      EPwm3Regs.TZCTL.bit.TZB     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1B will go low
      EPwm3Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
      EPwm3Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
      EDIS;
    // SOC
    //None
    // Interrupt
    EPwm3Regs.ETSEL.bit.INTSEL = ET_DCAEVT1SOC;       // Select INT on Zero event
    EPwm3Regs.ETSEL.bit.INTEN  = 0;                   // Disable INT, 外设级中断允许
    EPwm3Regs.ETPS.bit.INTPRD  = ET_DISABLE;          // Generate an interrupt on the first event
* Function: InitEPwm4()
* Description: Initializes the EPwm4 module on the F2806x.
*              与EPwm1,EPwm4移向90度,
*              将PWM4A与PWM4B配置成互补驱动,以PWM4A为信号源
*              上升沿死区:500ns
*              下降沿死区:500ns
void InitEPwm4(void)
    // Setup TBCLK
    EPwm4Regs.TBPRD = LLC_PWM_PERIOD_200KHZ;                   // Set timer period period
    EPwm4Regs.TBPHS.half.TBPHS = (LLC_PWM_PERIOD_200KHZ >> 1);// Phase is 90°
    EPwm4Regs.TBCTR = 0x0000;                            // Clear counter
    EPwm4Regs.CMPA.half.CMPA = LLC_PWM_PERIOD_200KHZ;       // Set compare A value
    EPwm4Regs.CMPB = 0;                                   // Set compare B value
    EPwm4Regs.TBCTL.bit.CTRMODE   = TB_COUNT_UPDOWN; // Count up and down
    EPwm4Regs.TBCTL.bit.PHSEN     = TB_ENABLE;       // Phase loading
    EPwm4Regs.TBCTL.bit.PHSDIR    = TB_DOWN;         // Count DOWN on sync (=90 deg)
    EPwm4Regs.TBCTL.bit.PRDLD     = TB_SHADOW;       // The period register (TBPRD) is loaded from its shadow register
                                                     // when the time-base counter,TBCTR, is equal to zero.
    EPwm4Regs.TBCTL.bit.SYNCOSEL  = TB_SYNC_IN;      // CTR = zero时输出同步信号,EPWM2同步用
    EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;            // Clock ratio to SYSCLKOUT
    EPwm4Regs.TBCTL.bit.CLKDIV    = TB_DIV1;         // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
    EPwm4Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;      // Shadow mode.
    EPwm4Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm4Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;    // Load on Zero
    EPwm4Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    // Set actions (AQ)
    EPwm4Regs.AQCTLA.bit.CAU = AQ_SET;             // Set PWM1A on event A, up count
    EPwm4Regs.AQCTLA.bit.CAD = AQ_CLEAR;               // Clear PWM1A on event A, down count
    EPwm4Regs.AQCTLB.bit.CBU = AQ_CLEAR ;           // Clear PWM1B on event B, up count
    EPwm4Regs.AQCTLB.bit.CBD = AQ_SET;              // Set PWM1B on event B, down count
      EPwm4Regs.DBCTL.bit.IN_MODE  = DBA_ALL;         // EPWMxA In (from the action-qualifier) is the source for both falling-edge and rising-edge delay.
      EPwm4Regs.DBCTL.bit.POLSEL   = DB_ACTV_HIC;     // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
      EPwm4Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;  // Dead-band generation is bypassed for both output signals.
      EPwm4Regs.DBRED = 45;                         // 500ns,not active
      EPwm4Regs.DBFED = 45;                         // 500ns,not active
      EPwm4Regs.PCCTL.bit.CHPEN = 0;                  // Disable (bypass) PWM chopping function
    /*               比较器过流保护关驱动操作                                             */
      /* 必须开启.                                                  */
      EALLOW;
      EPwm4Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT;  /* DCAH = Comparator 1 output */
      EPwm4Regs.TZDCSEL.bit.DCAEVT1       = TZ_DCAH_HI;   /* DCAEVT1 =  DCAH low(will become active as Comparator output goes high)*/
     EPwm4Regs.DCACTL.bit.EVT1SRCSEL     = DC_EVT1;      /* DCAEVT1 = DCAEVT1 (not filtered) */
      EPwm4Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
      EPwm4Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
      EPwm4Regs.TZDCSEL.bit.DCBEVT1       = TZ_DCBH_HI;
      EPwm4Regs.DCBCTL.bit.EVT1SRCSEL     = DC_EVT1;
      EPwm4Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
      EDIS;
      * 7.0 Trip Zone(TZ)
      EALLOW;
      EPwm4Regs.TZSEL.bit.DCAEVT1 = 1;                  /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
      EPwm4Regs.TZSEL.bit.DCBEVT1 = 1;                  /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
      EPwm4Regs.TZCTL.bit.TZA     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1A will go low
      EPwm4Regs.TZCTL.bit.TZB     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1B will go low
      EPwm4Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
      EPwm4Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
      EDIS;
    // SOC
    EPwm4Regs.ETSEL.bit.SOCBEN  = 1;                 // 使能EPWMxSOCB;
    EPwm4Regs.ETSEL.bit.SOCBSEL = ET_CTR_PRD;       // TBCTR=TBTRD,时触发SOCB;
    EPwm4Regs.ETPS.bit.SOCBPRD  = ET_1ST;           // Generate the EPWMxSOCA pulse on the first event
    // Interrupt
    EPwm4Regs.ETSEL.bit.INTSEL = ET_DCAEVT1SOC;       // Select INT on Zero event
    EPwm4Regs.ETSEL.bit.INTEN  = 0;                   // Disable INT, 外设级中断允许
    EPwm4Regs.ETPS.bit.INTPRD  = ET_DISABLE;          // Generate an interrupt on the first event
* Function: InitEPwm5()
*              与EPwm4,EPwm5同相,都与EPwm1移向90度,
*              将PWM5A与PWM5B配置成互补驱动,以PWM5A为信号源
*              上升沿死区:500ns
*              下降沿死区:500ns
void InitEPwm5(void)
      // Setup TBCLK
      EPwm5Regs.TBPRD = LLC_PWM_PERIOD_200KHZ;                   // Set timer period period
      EPwm5Regs.TBPHS.half.TBPHS = (LLC_PWM_PERIOD_200KHZ >> 1);// Phase is 90
      EPwm5Regs.TBCTR = 0x0000;                                  // Clear counter
      EPwm5Regs.CMPA.half.CMPA = LLC_PWM_PERIOD_200KHZ;     // Set compare A value
      EPwm5Regs.CMPB = 0;                                   // Set compare B value
      EPwm5Regs.TBCTL.bit.CTRMODE   = TB_COUNT_UPDOWN; // Count up and down
      EPwm5Regs.TBCTL.bit.PHSEN     = TB_ENABLE;       // Enable phase loading
      EPwm5Regs.TBCTL.bit.SYNCOSEL  = TB_SYNC_IN;      // sync flow-through
      EPwm5Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;            // Clock ratio to SYSCLKOUT
      EPwm5Regs.TBCTL.bit.CLKDIV    = TB_DIV1;         // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
    EPwm5Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;      // Shadow mode.
    EPwm5Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm5Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;    // Load on Zero
    EPwm5Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    // Set actions (AQ)
    EPwm5Regs.AQCTLA.bit.CAU = AQ_SET;             // Set PWM1A on event A, up count
    EPwm5Regs.AQCTLA.bit.CAD = AQ_CLEAR;               // Clear PWM1A on event A, down count
    EPwm5Regs.AQCTLB.bit.CBU = AQ_CLEAR ;           // Clear PWM1B on event B, up count
    EPwm5Regs.AQCTLB.bit.CBD = AQ_SET;              // Set PWM1B on event B, down count
    EPwm5Regs.AQCTLA.bit.CBU = AQ_CLEAR;               // Set PWM1A on event A, up count
    EPwm5Regs.AQCTLA.bit.CBD = AQ_SET;              // Clear PWM1A on event A, down count
    EPwm5Regs.AQCTLB.bit.CAU = AQ_SET ;           // Clear PWM1B on event B, up count
    EPwm5Regs.AQCTLB.bit.CAD = AQ_CLEAR;              // Set PWM1B on event B, down count
      EPwm5Regs.DBCTL.bit.IN_MODE  = DBA_ALL;         // EPWMxA In (from the action-qualifier) is the source for both falling-edge and rising-edge delay.
      EPwm5Regs.DBCTL.bit.POLSEL   = DB_ACTV_HIC;     // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
      EPwm5Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;      // Dead-band generation is bypassed for both output signals.
      EPwm5Regs.DBRED = 45;                         // 500ns,not active
      EPwm5Regs.DBFED = 45;                         // 500ns,not active
      EPwm5Regs.PCCTL.bit.CHPEN = 0;                  // Disable (bypass) PWM chopping function
    /*               比较器过流保护关驱动操作                                             */
      /* 必须开启.                                                  */
      EALLOW;
      EPwm5Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT;  /* DCAH = Comparator 1 output */
      EPwm5Regs.TZDCSEL.bit.DCAEVT1       = TZ_DCAH_HI;   /* DCAEVT1 =  DCAH low(will become active as Comparator output goes high)*/
     EPwm5Regs.DCACTL.bit.EVT1SRCSEL     = DC_EVT1;      /* DCAEVT1 = DCAEVT1 (not filtered) */
      EPwm5Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
      EPwm5Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
      EPwm5Regs.TZDCSEL.bit.DCBEVT1       = TZ_DCBH_HI;
      EPwm5Regs.DCBCTL.bit.EVT1SRCSEL     = DC_EVT1;
      EPwm5Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
      EDIS;
      * 7.0 Trip Zone(TZ)
      EALLOW;
      EPwm5Regs.TZSEL.bit.DCAEVT1 = 1;                  /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
      EPwm5Regs.TZSEL.bit.DCBEVT1 = 1;                  /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
      EPwm5Regs.TZCTL.bit.TZA     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1A will go low
      EPwm5Regs.TZCTL.bit.TZB     = TZ_FORCE_LO;        // 本项目使用软件出发TZ,EPWM1B will go low
      EPwm5Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
      EPwm5Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
      EDIS;
    // SOC
//    EPwm5Regs.ETSEL.bit.SOCBEN  = 1;                    // 使能EPWMxSOCB;
//    EPwm5Regs.ETSEL.bit.SOCBSEL = ET_CTR_PRD;          // TBCTR=TBTRD,时触发SOCB;
//    EPwm5Regs.ETPS.bit.SOCBPRD  = ET_1ST;         // Generate the EPWMxSOCA pulse on the first event
    // Interrupt
    EPwm5Regs.ETSEL.bit.INTSEL = ET_DCAEVT1SOC;       // Select INT on Zero event
    EPwm5Regs.ETSEL.bit.INTEN  = 0;                   // Disable INT, 外设级中断允许
    EPwm5Regs.ETPS.bit.INTPRD  = ET_DISABLE;          // Generate an interrupt on the first event
