Other Parts Discussed in Thread: TMS570LS3137, HALCOGEN
看门狗可以在hal中进行设置吗
* Copyright (C) 2009-2015 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* INCLUDING NEGLIGENCE OR OTHERWISE ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "sys_common.h"
#include "system.h"
/* USER CODE BEGIN (1) */
#include "rti.h"
#include "het.h"
#include "esm.h"
/* USER CODE END */
/* USER CODE BEGIN (2) */
int ctr = 0;
/* USER CODE END */
void main(void)
/* USER CODE BEGIN (3) */
/* Enable interrupt */
_enable_IRQ();
gioSetDirection(hetPORT1, 0xFFFFFFFF);
/* Initialize RTI */
rtiInit();
/* Enable RTI compare 0 notification */
rtiEnableNotification(rtiNOTIFICATION_COMPARE0);
/* Start counter */
rtiStartCounter(rtiCOUNTER_BLOCK0);
/* Initialize and start DWD */
dwwdInit(Generate_NMI, 4095, Size_100_Percent);
dwdCounterEnable();
/* DWD is serviced in the RTI interrupt*/
/* Delay */
while(ctr < 5);
/* Stop Servicing DWD */
rtiDisableNotification(rtiNOTIFICATION_COMPARE0);
while(1);
/* USER CODE END */
/* USER CODE BEGIN (4) */
void rtiNotification(uint32 notification)
ctr++;
gioToggleBit(hetPORT1,0);
dwdReset();
/* USER CODE END */
