Other Parts Discussed in Thread: HALCOGEN
我想产生一个有相移功能的PWM信号去控制相移全桥电路,但是透过HALCOGEN HET产生的PWM信号无法相位移,请问我该如何透过设定HALCOGEN和使用Code Composer Studio建立程式达成PWM相移效果,麻烦各位指导,谢谢。
下面是我之前收藏的关于PWM phase shift 的工程,您可以参考一下
很抱歉,目前没有直接的例程。HALCoGen使用的HET程序不允许您在PWM之间引入相位延迟
您可以参考下面的示例,可以需要根据需要对其进行调整。研究此问题的最佳方法是使用HET IDE对其进行仿真。
关于HET IDE,请您参考 http://www.ti.com/lit/ug/spnu483a/spnu483a.pdf
https://e2echina.ti.com/cfs-file/__key/communityserver-discussions-components-files/70/1856.pwm_5F00_3Phase-_2800_2_2900_.het
在TI的例程内我们一般使用的是RTI,如下
U32 waitTill = currentRTIvalue + wtime;
while((I32)(currentRTIvalue - waitTill) < 0) // trick to compare over RTI overload
{ /* do nothing */ }
例如
//delay 50ms while HET starts up rtiResetCounter(rtiCOUNTER_BLOCK0); rtiStartCounter(rtiCOUNTER_BLOCK0); while(rtiGetCurrentTick(rtiCOMPARE0) < 50000); rtiStopCounter(rtiCOUNTER_BLOCK0);
/* --COPYRIGHT--,BSD
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* --/COPYRIGHT--*/
/** @file rti.c
* @brief RTI Driver Source File
* @date 15.December.2011
* @version 03.00.00
* This file contains:
* - API Funcions
* - Interrupt Handlers
* which are relevant for the RTI driver.
/* (c) Texas Instruments 2009-2011, All rights reserved. */
/* USER CODE BEGIN (0) */
//! \file ~/drivers/rit/src/32b/hercules/tms570ls3137/rti.c
//! \brief Contains the various functions related to the
//! rti timer peripheral
//! (C) Copyright 2012, Texas Instruments, Inc.
// the includes
/* USER CODE END */
/* Include Files */
#include "rti.h"
/* USER CODE BEGIN (1) */
// the defines
// the globals
// the functions
/* USER CODE END */
/** @fn void rtiInit(void)
* @brief Initializes RTI Driver
* This function initializes the RTI driver.
/* USER CODE BEGIN (2) */
/* USER CODE END */
void rtiInit(void)
/* USER CODE BEGIN (3) */
/* USER CODE END */
/** @b Initialize @b RTI1: */
/** - Setup NTU source, debug options and disable both counter blocks */
rtiREG1->GCTRL = (1U << 16U) | 0x00000000U;
/** - Setup timebase for free running counter 0 */
rtiREG1->TBCTRL = 0x00000000U;
/** - Enable/Disable capture event sources for both counter blocks */
rtiREG1->CAPCTRL = 0U | 0U;
/** - Setup input source compare 0-3 */
rtiREG1->COMPCTRL = 0x00001000U | 0x00000100U | 0x00000000U | 0x00000000U;
/** - Reset up counter 0 */
rtiREG1->CNT[0U].UCx = 0x00000000U;
/** - Reset free running counter 0 */
rtiREG1->CNT[0U].FRCx = 0x00000000U;
/** - Setup up counter 0 compare value
* - 0x00000000: Divide by 2^32
* - 0x00000001-0xFFFFFFFF: Divide by (CPUC0 + 1)
rtiREG1->CNT[0U].CPUCx = 79U;
/** - Reset up counter 1 */
rtiREG1->CNT[1U].UCx = 0x00000000U;
/** - Reset free running counter 1 */
rtiREG1->CNT[1U].FRCx = 0x00000000U;
/** - Setup up counter 1 compare value
* - 0x00000001-0xFFFFFFFF: Divide by (CPUC1 + 1)
rtiREG1->CNT[1U].CPUCx = 79U;
/** - Setup compare 0 value. This value is compared with selected free running counter. */
rtiREG1->CMP[0U].COMPx = 1000000U;
/** - Setup update compare 0 value. This value is added to the compare 0 value on each compare match. */
rtiREG1->CMP[0U].UDCPx = 1000000U;
/** - Setup compare 1 value. This value is compared with selected free running counter. */
rtiREG1->CMP[1U].COMPx = 5000U;
/** - Setup update compare 1 value. This value is added to the compare 1 value on each compare match. */
rtiREG1->CMP[1U].UDCPx = 5000U;
/** - Setup compare 2 value. This value is compared with selected free running counter. */
rtiREG1->CMP[2U].COMPx = 8000U;
/** - Setup update compare 2 value. This value is added to the compare 2 value on each compare match. */
rtiREG1->CMP[2U].UDCPx = 8000U;
/** - Setup compare 3 value. This value is compared with selected free running counter. */
rtiREG1->CMP[3U].COMPx = 10000U;
/** - Setup update compare 3 value. This value is added to the compare 3 value on each compare match. */
rtiREG1->CMP[3U].UDCPx = 10000U;
/** - Clear all pending interrupts */
rtiREG1->INTFLAG = 0x0007000FU;
/** - Disable all interrupts */
rtiREG1->CLEARINT = 0x00070F0FU;
/** @note This function has to be called before the driver can be used.\n
* This function has to be executed in priviledged mode.\n
* This function does not start the counters.
/* USER CODE BEGIN (4) */
/* USER CODE END */
/* USER CODE BEGIN (5) */
/* USER CODE END */
/** @fn void rtiStartCounter(uint32_t counter)
* @brief Starts RTI Counter block
* @param[in] counter Select counter block to be started:
* - rtiCOUNTER_BLOCK0: RTI counter block 0 will be started
* - rtiCOUNTER_BLOCK1: RTI counter block 1 will be started
* This function starts selected counter block of the selected RTI module.
/* USER CODE BEGIN (6) */
/* USER CODE END */
/* USER CODE BEGIN (7) */
/* USER CODE END */
rtiREG1->GCTRL |= (1U << (counter & 3U));
/** @note The function rtiInit has to be called before this function can be used.\n
/* USER CODE BEGIN (8) */
/* USER CODE END */
/* USER CODE BEGIN (9) */
/* USER CODE END */
/** @fn void rtiStopCounter(uint32_t counter)
* @brief Stops RTI Counter block
* @param[in] counter Select counter to be stopped:
* - rtiCOUNTER_BLOCK0: RTI counter block 0 will be stopped
* - rtiCOUNTER_BLOCK1: RTI counter block 1 will be stopped
* This function stops selected counter block of the selected RTI module.
/* USER CODE BEGIN (10) */
/* USER CODE END */
/* USER CODE BEGIN (11) */
/* USER CODE END */
rtiREG1->GCTRL &= ~(1U << (counter & 3U));
/* USER CODE BEGIN (12) */
/* USER CODE END */
/* USER CODE BEGIN (13) */
/* USER CODE END */
/** @fn uint32_t rtiResetCounter(uint32_t counter)
* @brief Reset RTI Counter block
* @param[in] counter Select counter block to be reset:
* - rtiCOUNTER_BLOCK0: RTI counter block 0 will be reset
* - rtiCOUNTER_BLOCK1: RTI counter block 1 will be reset
* @return The function will return:
* - 0: When the counter reset wasn't successful
* - 1: When the counter reset was successful
* This function resets selected counter block of the selected RTI module.
/* USER CODE BEGIN (14) */
/* USER CODE END */
uint32_t success = 0U;
/* USER CODE BEGIN (15) */
/* USER CODE END */
if (!(rtiREG1->GCTRL & (1U << (counter & 3U))))
rtiREG1->CNT[counter].UCx = 0x00000000U;
rtiREG1->CNT[counter].FRCx = 0x00000000U;
success = 1U;
* The selected counter block has to be stopped before it can reset.
/* USER CODE BEGIN (16) */
/* USER CODE END */
return success;
/* USER CODE BEGIN (17) */
/* USER CODE END */
/** @fn void rtiSetPeriod(uint32_t compare, uint32_t period)
* @brief Set new period of RTI compare
* @param[in] compare Select compare to change period:
* - rtiCOMPARE0: RTI compare 0 will change the period
* - rtiCOMPARE1: RTI compare 1 will change the period
* - rtiCOMPARE2: RTI compare 2 will change the period
* - rtiCOMPARE3: RTI compare 3 will change the period
* @param[in] period new period in [ticks - 1]:
* - 0x00000000: Divide by 1
* - n: Divide by n + 1
* This function will change the period of the selected compare.
/* USER CODE BEGIN (18) */
/* USER CODE END */
/* USER CODE BEGIN (19) */
/* USER CODE END */
rtiREG1->CMP[compare].UDCPx = period;
* When the corresponding counter block is not stopped,\n
* the period will change on the next compare match of the old period.
/* USER CODE BEGIN (20) */
/* USER CODE END */
/* USER CODE BEGIN (21) */
/* USER CODE END */
/** @fn uint32_t rtiGetPeriod(uint32_t compare)
* @brief Get current period of RTI compare
* @param[in] compare Select compare to return the current period:
* - rtiCOMPARE0: RTI compare 0 will return the current period
* - rtiCOMPARE1: RTI compare 1 will return the current period
* - rtiCOMPARE2: RTI compare 2 will return the current period
* - rtiCOMPARE3: RTI compare 3 will return the current period
* @return Current period of selected compare in [ticks - 1]:
/* USER CODE BEGIN (22) */
/* USER CODE END */
uint32_t period;
/* USER CODE BEGIN (23) */
/* USER CODE END */
period = rtiREG1->CMP[compare].UDCPx;
/* USER CODE BEGIN (24) */
/* USER CODE END */
return period;
/* USER CODE BEGIN (25) */
/* USER CODE END */
/** @fn uint32_t rtiGetCurrentTick(uint32_t compare)
* @brief Get current tick of RTI compare
* @param[in] compare Select compare to return the current tick:
* @return Current tick of selected compare
/* USER CODE BEGIN (26) */
/* USER CODE END */
uint32_t tick;
uint32_t counter = (rtiREG1->COMPCTRL & (1U << (compare << 2U))) ? 1U : 0U;
/* USER CODE BEGIN (27) */
/* USER CODE END */
tick = rtiREG1->CNT[counter].FRCx - (rtiREG1->CMP[compare].COMPx - rtiREG1->CMP[compare].UDCPx);
/* USER CODE BEGIN (28) */
/* USER CODE END */
return tick;
/* USER CODE BEGIN (29) */
/* USER CODE END */
/** @fn void rtiEnableNotification(uint32_t notification)
* @brief Enable notification of RTI module
* @param[in] notification Select notification of RTI module:
* - rtiNOTIFICATION_COMPARE0: RTI compare 0 notification
* - rtiNOTIFICATION_COMPARE1: RTI compare 1 notification
* - rtiNOTIFICATION_COMPARE2: RTI compare 2 notification
* - rtiNOTIFICATION_COMPARE3: RTI compare 3 notification
* - rtiNOTIFICATION_TIMEBASE: RTI Timebase notification
* - rtiNOTIFICATION_COUNTER0: RTI counter 0 overflow notification
* - rtiNOTIFICATION_COUNTER1: RTI counter 1 overflow notification
* This function will enable the selected notification of a RTI module.
* It is possible to enable multiple notifications masked.
/* USER CODE BEGIN (30) */
/* USER CODE END */
/* USER CODE BEGIN (31) */
/* USER CODE END */
rtiREG1->INTFLAG &= ~notification;
rtiREG1->SETINT = notification;
/* USER CODE BEGIN (32) */
/* USER CODE END */
/* USER CODE BEGIN (33) */
/* USER CODE END */
/** @fn void rtiDisableNotification(uint32_t notification)
* @brief Disable notification of RTI module
* This function will disable the selected notification of a RTI module.
* It is possible to disable multiple notifications masked.
/* USER CODE BEGIN (34) */
/* USER CODE END */
/* USER CODE BEGIN (35) */
/* USER CODE END */
rtiREG1->CLEARINT = notification;
/* USER CODE BEGIN (36) */
/* USER CODE END */
/* USER CODE BEGIN (37) */
/* USER CODE END */
/** @fn void rtiCompare0Interrupt(void)
* @brief RTI1 Compare 0 Interrupt Handler
* RTI1 Compare 0 interrupt handler
/* USER CODE BEGIN (38) */
/* USER CODE END */
#pragma INTERRUPT(rtiCompare0Interrupt, IRQ)
/* USER CODE BEGIN (39) */
/* USER CODE END */
rtiREG1->INTFLAG = 1U;
rtiNotification(rtiNOTIFICATION_COMPARE0);
/* USER CODE BEGIN (40) */
/* USER CODE END */
/* USER CODE BEGIN (41) */
/* USER CODE END */
/** @fn void rtiCompare1Interrupt(void)
* @brief RTI1 Compare 1 Interrupt Handler
* RTI1 Compare 1 interrupt handler
/* USER CODE BEGIN (42) */
/* USER CODE END */
#pragma INTERRUPT(rtiCompare1Interrupt, IRQ)
/* USER CODE BEGIN (43) */
/* USER CODE END */
rtiREG1->INTFLAG = 2U;
rtiNotification(rtiNOTIFICATION_COMPARE1);
/* USER CODE BEGIN (44) */
/* USER CODE END */
/* USER CODE BEGIN (45) */
/* USER CODE END */
/** @fn void rtiCompare2Interrupt(void)
* @brief RTI1 Compare 2 Interrupt Handler
* RTI1 Compare 2 interrupt handler
/* USER CODE BEGIN (46) */
/* USER CODE END */
#pragma INTERRUPT(rtiCompare2Interrupt, IRQ)
/* USER CODE BEGIN (47) */
/* USER CODE END */
rtiREG1->INTFLAG = 4U;
rtiNotification(rtiNOTIFICATION_COMPARE2);
/* USER CODE BEGIN (48) */
/* USER CODE END */
/* USER CODE BEGIN (49) */
/* USER CODE END */
/** @fn void rtiCompare3Interrupt(void)
* @brief RTI1 Compare 3 Interrupt Handler
* RTI1 Compare 3 interrupt handler
/* USER CODE BEGIN (50) */
/* USER CODE END */
#pragma INTERRUPT(rtiCompare3Interrupt, IRQ)
/* USER CODE BEGIN (51) */
/* USER CODE END */
rtiREG1->INTFLAG = 8U;
rtiNotification(rtiNOTIFICATION_COMPARE3);
/* USER CODE BEGIN (52) */
/* USER CODE END */
/* USER CODE BEGIN (53) */
/* USER CODE END */
/** @fn void rtiTimebaseInterrupt(void)
* @brief RTI1 Timebase Interrupt Handler
* RTI1 timebase interrupt handler
/* USER CODE BEGIN (54) */
/* USER CODE END */
#pragma INTERRUPT(rtiTimebaseInterrupt, IRQ)
/* USER CODE BEGIN (55) */
/* USER CODE END */
rtiREG1->INTFLAG = 0x10000U;
rtiNotification(rtiNOTIFICATION_TIMEBASE);
/* USER CODE BEGIN (56) */
/* USER CODE END */
/* USER CODE BEGIN (57) */
/* USER CODE END */
/** @fn void rtiOverflow0Interrupt(void)
* @brief RTI1 Counter 0 overflow Interrupt Handler
* RTI1 counter 0 overflow interrupt handler
/* USER CODE BEGIN (58) */
/* USER CODE END */
#pragma INTERRUPT(rtiOverflow0Interrupt, IRQ)
/* USER CODE BEGIN (59) */
/* USER CODE END */
rtiREG1->INTFLAG = 0x20000U;
rtiNotification(rtiNOTIFICATION_COUNTER0);
/* USER CODE BEGIN (60) */
/* USER CODE END */
/* USER CODE BEGIN (61) */
/* USER CODE END */
/** @fn void rtiOverflow1Interrupt(void)
* @brief RTI1 Counter 1 overflow Interrupt Handler
* RTI1 counter 1 overflow interrupt handler
/* USER CODE BEGIN (62) */
/* USER CODE END */
#pragma INTERRUPT(rtiOverflow1Interrupt, IRQ)
/* USER CODE BEGIN (63) */
/* USER CODE END */
rtiREG1->INTFLAG = 0x40000U;
rtiNotification(rtiNOTIFICATION_COUNTER1);
/* USER CODE BEGIN (64) */
/* USER CODE END */
/* USER CODE BEGIN (65) */
// end of file
/* USER CODE END */
