Other Parts Discussed in Thread: HALCOGEN
请问是什么原因:
提示的错误如下:
Description Resource Path Location Type
unresolved symbol __TI_auto_init, first referenced in ./HalCoGen4.7_arm/source/HL_sys_startup.obj 02025939_arm C/C++ Problem
unresolved symbol exit, first referenced in ./HalCoGen4.7_arm/source/HL_sys_startup.obj 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/e_hypotf.c.obj] Error 256 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/e_log10f.c.obj] Error 256 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/e_logf.c.obj] Error 256 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/e_powf.c.obj] Error 256 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/fd_div32.asm.obj] Error 256 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/fd_mul32.asm.obj] Error 256 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/libcxx/mutex.cpp.obj] Error 256 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/libcxx/random.cpp.obj] Error 256 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/s_log1pf.c.obj] Error 256 02025939_arm C/C++ Problem
gmake.exe[2]: *** [c:/users/admini~1/appdata/local/temp/ti_mkl~1/obj/w_cabsl.c.obj] Error 256 02025939_arm C/C++ Problem
