Other Parts Discussed in Thread: HALCOGEN, DP83640, TMS570LS3137
wiki上下载的HALCoGen EMAC Driver with lwIP Demonstration
程序烧写到自己做的板子里,PHY是DP83640
连接PHY时失败
请问是什么原因
连接PHY时失败
请问是什么原因
/** @file pinmux.c
* @brief PINMUX Driver Implementation File
* @date 07-July-2017
* @version 04.07.00
* Copyright (C) 2009-2016 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Include Files */
#include "pinmux.h"
/*LDRA_INSPECTWINDOW 50 */
/*SAFETYMCUSW 125 S MR: 19.13 REVIEWED " Needs usage of ## in the macro " */
/*SAFETYMCUSW 76 S MR: 19.12 REVIEWED " Needs usage of multiple ## in the macro " */
/*SAFETYMCUSW 78 S MR: 19.10 REVIEWED " Macro parameter used for concatenation " */
#define PINMUX_SET(REG, PINNUM, MUX) \
(pinMuxReg->PINMMR##REG = (pinMuxReg->PINMMR##REG & PINMUX_PIN_##PINNUM##_MASK) | (PINMUX_PIN_##PINNUM##_##MUX))
#define PINMUX_GATE_EMIF_CLK_ENABLE(state) \
(pinMuxReg->PINMMR29 = (pinMuxReg->PINMMR29 & PINMUX_GATE_EMIF_CLK_MASK) | (PINMUX_GATE_EMIF_CLK_##state))
#define PINMUX_GIOB_DISABLE_HET2_ENABLE(state) \
(pinMuxReg->PINMMR29 = (pinMuxReg->PINMMR29 & PINMUX_GIOB_DISABLE_HET2_MASK) | (PINMUX_GIOB_DISABLE_HET2_##state))
#define PINMUX_ALT_ADC_TRIGGER_SELECT(num) \
(pinMuxReg->PINMMR30 = (pinMuxReg->PINMMR30 & PINMUX_ALT_ADC_TRIGGER_MASK) | (PINMUX_ALT_ADC_TRIGGER_##num))
#define PINMUX_ETHERNET_SELECT(interface) \
(pinMuxReg->PINMMR29 = (pinMuxReg->PINMMR29 & PINMUX_ETHERNET_MASK) | (PINMUX_ETHERNET_##interface))
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* SourceId : PINMUX_SourceId_001 */
/* DesignId : PINMUX_DesignId_001 */
/* Requirements : HL_SR325 */
void muxInit(void){
/* USER CODE BEGIN (1) */
/* USER CODE END */
/* Enable Pin Muxing */
kickerReg->KICKER0 = 0x83E70B13U;
kickerReg->KICKER1 = 0x95A4F1E0U;
/* USER CODE BEGIN (2) */
/* USER CODE END */
pinMuxReg->PINMMR0 = PINMUX_PIN_1_GIOB_3 | PINMUX_PIN_2_GIOA_0 | PINMUX_PIN_3_MIBSPI3NCS_3 | PINMUX_PIN_4_MIBSPI3NCS_2;
pinMuxReg->PINMMR1 = PINMUX_PIN_5_GIOA_1 | PINMUX_PIN_6_HET1_11;
pinMuxReg->PINMMR2 = PINMUX_PIN_9_GIOA_2 | PINMUX_PIN_14_GIOA_5;
pinMuxReg->PINMMR3 = PINMUX_PIN_15_HET1_22 | PINMUX_PIN_16_GIOA_6;
pinMuxReg->PINMMR4 = PINMUX_PIN_22_GIOA_7 | PINMUX_PIN_23_HET1_01 | PINMUX_PIN_24_HET1_03;
pinMuxReg->PINMMR5 = PINMUX_PIN_25_HET1_0 | PINMUX_PIN_30_HET1_02 | PINMUX_PIN_31_HET1_05;
pinMuxReg->PINMMR6 = PINMUX_PIN_33_HET1_07 | PINMUX_PIN_35_HET1_09;
pinMuxReg->PINMMR7 = PINMUX_PIN_37_MDCLK | PINMUX_PIN_38_HET1_06;
pinMuxReg->PINMMR8 = PINMUX_PIN_39_HET1_13 | PINMUX_PIN_40_MDIO | PINMUX_PIN_41_HET1_15;
pinMuxReg->PINMMR9 = ((~(pinMuxReg->PINMMR9 >> 18U) & 0x00000001U ) << 18U) | PINMUX_PIN_54_MIBSPI3NENA | PINMUX_PIN_55_MIBSPI3NCS_0;
pinMuxReg->PINMMR10 = PINMUX_PIN_86_MII_RX_ER;
pinMuxReg->PINMMR11 = PINMUX_PIN_91_MII_RXD_0;
pinMuxReg->PINMMR12 = PINMUX_PIN_92_MII_RXD_1 | PINMUX_PIN_96_MII_RXD_2 | PINMUX_PIN_97_MII_RXD_3;
pinMuxReg->PINMMR13 = PINMUX_PIN_98_MII_TXD_0 | PINMUX_PIN_99_MII_TXD_1 | PINMUX_PIN_100_MII_TXEN | PINMUX_PIN_105_MII_TXD_2;
pinMuxReg->PINMMR14 = PINMUX_PIN_106_MII_TXD_3 | PINMUX_PIN_107_MII_RXCLK;
pinMuxReg->PINMMR15 = 0x01010101U;
pinMuxReg->PINMMR16 = 0x01010101U;
pinMuxReg->PINMMR17 = PINMUX_PIN_118_MII_TX_CLK | PINMUX_PIN_124_MII_CRS;
pinMuxReg->PINMMR18 = PINMUX_PIN_125_HET1_14 | PINMUX_PIN_126_GIOB_0;
pinMuxReg->PINMMR19 = PINMUX_PIN_127_MII_RX_DV;
pinMuxReg->PINMMR20 = PINMUX_PIN_130_MII_COL;
pinMuxReg->PINMMR21 = PINMUX_PIN_133_GIOB_1;
pinMuxReg->PINMMR22 = 0x01010101U;
pinMuxReg->PINMMR23 = ((~(pinMuxReg->PINMMR5 >> 1U) & 0x00000001U ) << 8U) | ((~(pinMuxReg->PINMMR5 >> 9U) & 0x00000001U ) << 16U) | ((~(pinMuxReg->PINMMR5 >> 17U) & 0x00000001U ) << 24U);
pinMuxReg->PINMMR24 = ((~(pinMuxReg->PINMMR4 >> 17U) & 0x00000001U ) << 0U) | ((~(pinMuxReg->PINMMR4 >> 25U) & 0x00000001U ) << 8U) | ((~(pinMuxReg->PINMMR20 >> 17U) & 0x00000001U ) << 16U) | ((~(pinMuxReg->PINMMR8 >> 9U) & 0x00000001U ) << 24U);
/*SAFETYMCUSW 134 S MR:12.2 <APPROVED> "LDRA Tool issue" */
pinMuxReg->PINMMR25 = ((~(pinMuxReg->PINMMR12 >> 17U) & 0x00000001U ) << 8U) | ((~(pinMuxReg->PINMMR7 >> 9U) & 0x00000001U ) << 16U) | ((~(pinMuxReg->PINMMR0 >> 26U) & 0x00000001U ) << 24U);
pinMuxReg->PINMMR26 = ((~(pinMuxReg->PINMMR0 >> 18U) & 0x00000001U ) << 0U) | ((~(pinMuxReg->PINMMR9 >> 10U) & 0x00000001U ) << 8U);
pinMuxReg->PINMMR27 = PINMUX_PIN_32_MIBSPI5NCS_0;
pinMuxReg->PINMMR28 = 0x01010101U;
pinMuxReg->PINMMR29 = 0x01010101U;
PINMUX_GATE_EMIF_CLK_ENABLE(OFF);
PINMUX_GIOB_DISABLE_HET2_ENABLE(OFF);
PINMUX_ALT_ADC_TRIGGER_SELECT(1);
PINMUX_ETHERNET_SELECT(MII);
/* USER CODE BEGIN (3) */
/* USER CODE END */
/* Disable Pin Muxing */
kickerReg->KICKER0 = 0x00000000U;
kickerReg->KICKER1 = 0x00000000U;
/* USER CODE BEGIN (4) */
/* USER CODE END */
/** @fn void pinmuxGetConfigValue(pinmux_config_reg_t *config_reg, config_value_type_t type)
* @brief Get the initial or current values of the configuration registers
* @param[in] *config_reg: pointer to the struct to which the initial or current
* value of the configuration registers need to be stored
* @param[in] type: whether initial or current value of the configuration registers need to be stored
* - InitialValue: initial value of the configuration registers will be stored
* in the struct pointed by config_reg
* - CurrentValue: initial value of the configuration registers will be stored
* This function will copy the initial or current value (depending on the parameter 'type')
* of the configuration registers to the struct pointed by config_reg
/* SourceId : PINMUX_SourceId_002 */
/* DesignId : PINMUX_DesignId_002 */
/* Requirements : HL_SR328 */
if (type == InitialValue)
{/* Do not pass Initial Value as parameter */
else
config_reg->CONFIG_PINMMR0 = pinMuxReg->PINMMR0;
config_reg->CONFIG_PINMMR1 = pinMuxReg->PINMMR1;
config_reg->CONFIG_PINMMR2 = pinMuxReg->PINMMR2;
config_reg->CONFIG_PINMMR3 = pinMuxReg->PINMMR3;
config_reg->CONFIG_PINMMR4 = pinMuxReg->PINMMR4;
config_reg->CONFIG_PINMMR5 = pinMuxReg->PINMMR5;
config_reg->CONFIG_PINMMR6 = pinMuxReg->PINMMR6;
config_reg->CONFIG_PINMMR7 = pinMuxReg->PINMMR7;
config_reg->CONFIG_PINMMR8 = pinMuxReg->PINMMR8;
config_reg->CONFIG_PINMMR9 = pinMuxReg->PINMMR9;
config_reg->CONFIG_PINMMR10 = pinMuxReg->PINMMR10;
config_reg->CONFIG_PINMMR11 = pinMuxReg->PINMMR11;
config_reg->CONFIG_PINMMR12 = pinMuxReg->PINMMR12;
config_reg->CONFIG_PINMMR13 = pinMuxReg->PINMMR13;
config_reg->CONFIG_PINMMR14 = pinMuxReg->PINMMR14;
config_reg->CONFIG_PINMMR15 = pinMuxReg->PINMMR15;
config_reg->CONFIG_PINMMR16 = pinMuxReg->PINMMR16;
config_reg->CONFIG_PINMMR17 = pinMuxReg->PINMMR17;
config_reg->CONFIG_PINMMR18 = pinMuxReg->PINMMR18;
config_reg->CONFIG_PINMMR19 = pinMuxReg->PINMMR19;
config_reg->CONFIG_PINMMR20 = pinMuxReg->PINMMR20;
config_reg->CONFIG_PINMMR21 = pinMuxReg->PINMMR21;
config_reg->CONFIG_PINMMR22 = pinMuxReg->PINMMR22;
config_reg->CONFIG_PINMMR23 = pinMuxReg->PINMMR23;
config_reg->CONFIG_PINMMR24 = pinMuxReg->PINMMR24;
config_reg->CONFIG_PINMMR25 = pinMuxReg->PINMMR25;
config_reg->CONFIG_PINMMR26 = pinMuxReg->PINMMR26;
config_reg->CONFIG_PINMMR27 = pinMuxReg->PINMMR27;
config_reg->CONFIG_PINMMR28 = pinMuxReg->PINMMR28;
config_reg->CONFIG_PINMMR29 = pinMuxReg->PINMMR29;
config_reg->CONFIG_PINMMR30 = pinMuxReg->PINMMR30;
/* USER CODE BEGIN (5) */
/* USER CODE END */
