Other Parts Discussed in Thread: RM48L950
我在CCSV5.3+RM48L950开发时,在工程属性页面:build->steps->Post-build steps->command下,输入命令:
"${CCS_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin.bat" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/armofd.exe" "${CG_TOOL_ROOT}/bin/armhex.exe" "${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin.exe"
生成的bin文件过大,有131M,我的out文件才255KB。
工程中sys_link.cmd文件的内容:
/* sys_link.cmd */
/* (c) Texas Instruments 2009-2013, All rights reserved. */
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Linker Settings */
--retain="*(.intvecs)"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/* Memory Map */
MEMORY
VECTORS (X) : origin=0x00000000 length=0x00000020
CODE (RX) : origin=0x00000020 length=0x03FFE0
STACKS (RW) : origin=0x08000000 length=0x00001500
RAM (RW) : origin=0x08001500 length=0x0003EB00
/* USER CODE BEGIN (2) */
/* USER CODE END */
/* USER CODE BEGIN (3) */
/* USER CODE END */
/* Section Configuration */
SECTIONS
.intvecs : {} > VECTORS
.text : {} > CODE
.const : {} > CODE
.cinit : {} > CODE
.pinit : {} > CODE
.LOGIC : {} > CODE
.bss : {} > RAM
.data : {} > RAM
.sysmem : {} > RAM
/* USER CODE BEGIN (4) */
/* USER CODE END */
/* USER CODE BEGIN (5) */
/* USER CODE END */
/* Misc */
/* USER CODE BEGIN (6) */
/* USER CODE END */
这个是什么原因导致的,如何解决?
