msp430单片机中增量式pid算法的C实现方法
  •  #include <stdio.h>
      #include<math.h>
      struct _pid {
       int pv; /*integer that contains the process value*/
       int sp; /*integer that contains the set point*/
       float integral;
       float pgain;
       float igain;
       float dgain;
       int deadband;
       int last_error;
      struct _pid warm,*pid;
      int process_point, set_point,dead_band;
      float p_gain, i_gain, d_gain, integral_val,new_integ;;
      pid_init
      DESCRIPTION This function initializes the pointers in the _pid structure
      to the process variable and the setpoint. *pv and *sp are
      integer pointers.
      void pid_init(struct _pid *warm, int process_point, int set_point)
       struct _pid *pid;
       pid = warm;
       pid->pv = process_point;
       pid->sp = set_point;
      pid_tune
      DESCRIPTION Sets the proportional gain (p_gain), integral gain (i_gain),
      derivitive gain (d_gain), and the dead band (dead_band) of
      a pid control structure _pid.
      void pid_tune(struct _pid *pid, float p_gain, float i_gain, float d_gain, int dead_band)
       pid->pgain = p_gain;
       pid->igain = i_gain;
       pid->dgain = d_gain;
       pid->deadband = dead_band;
       pid->integral= integral_val;
       pid->last_error=0;
      pid_setinteg
      DESCRIPTION Set a new value for the integral term of the pid equation.
      This is useful for setting the initial output of the
      pid controller at start up.
      void pid_setinteg(struct _pid *pid,float new_integ)
       pid->integral = new_integ;
       pid->last_error = 0;
      pid_bumpless
      DESCRIPTION Bumpless transfer algorithim. When suddenly changing
      setpoints, or when restarting the PID equation after an
      extended pause, the derivative of the equation can cause
      a bump in the controller output. This function will help
      smooth out that bump. The process value in *pv should
      be the updated just before this function is used.
      void pid_bumpless(struct _pid *pid)
       pid->last_error = (pid->sp)-(pid->pv);
      pid_calc
      DESCRIPTION Performs PID calculations for the _pid structure *a. This function uses the positional form of the pid equation, and incorporates an integral windup prevention algorithim. Rectangular integration is used, so this function must be repeated on a consistent time basis for accurate control.
      RETURN VALUE The new output value for the pid loop.
      USAGE #include "control.h"*/
      float pid_calc(struct _pid *pid)
       int err;
       float pterm, dterm, result, ferror;
       err = (pid->sp) - (pid->pv);
       if (abs(err) > pid->deadband)
       ferror = (float) err; /*do integer to float conversion only once*/
       pterm = pid->pgain * ferror;
       if (pterm > 100 || pterm < -100)
       pid->integral = 0.0;
       else
       pid->integral += pid->igain * ferror;
       if (pid->integral > 100.0)
       pid->integral = 100.0;
       else if (pid->integral < 0.0) pid->integral = 0.0;
       dterm = ((float)(err - pid->last_error)) * pid->dgain;
       result = pterm + pid->integral + dterm;
       else result = pid->integral;
       pid->last_error = err;
       return (result);
      void main(void)
       float display_value;
       int count=0;
       pid = &warm;
      // printf("Enter the values of Process point, Set point, P gain, I gain, D gain \n");
      // scanf("%d%d%f%f%f", &process_point, &set_point, &p_gain, &i_gain, &d_gain);
       process_point = 30;
       set_point = 40;
       p_gain = (float)(5.2);
       i_gain = (float)(0.77);
       d_gain = (float)(0.18);
       dead_band = 2;
       integral_val =(float)(0.01);
       printf("The values of Process point, Set point, P gain, I gain, D gain \n");
       printf(" %6d %6d %4f %4f %4f\n", process_point, set_point, p_gain, i_gain, d_gain);
       printf("Enter the values of Process point\n");
       while(count<=20)
       scanf("%d",&process_point);
       pid_init(&warm, process_point, set_point);
       pid_tune(&warm, p_gain,i_gain,d_gain,dead_band);
       pid_setinteg(&warm,0.0); //pid_setinteg(&warm,30.0);
       //Get input value for process point
       pid_bumpless(&warm);
       // how to display output
       display_value = pid_calc(&warm);
       printf("%f\n", display_value);
       //printf("\n%f%f%f%f",warm.pv,warm.sp,warm.igain,warm.dgain);
       count++;
  • 请教一下这个代码在CCS上编译通过不了,对结构体变量的定义应如何书写呢?谢谢!
