关于MSP430FR4133写FRAM的怪问题?
当执行FRAMWrite_uint64((uint64_t *)FRAM_RECORD_ADDRESS,0); 时,后20*4会被修改为0
原来0xffffffff,0xffffffff,被改为0x0000ffff,0x00000000
当执行FRAMWrite_Long((uint32_t *)FRAM_RECORD_ADDRESS, 0);时,后10*4=40会被修改为0
原来0xffffffff,被改为0x0000ffff,
void FRAMWrite_uint64(uint64_t *pFRAM_write_ptr, uint64_t ui64data)
        SYSCFG0 &= ~DFWP;
        *pFRAM_write_ptr = ui64data;
        SYSCFG0 |= DFWP;
void FRAMWrite_Long(uint32_t *pFRAM_write_ptr, uint32_t ui32data)
        SYSCFG0 &= ~DFWP;
        *pFRAM_write_ptr = ui32data;
        SYSCFG0 |= DFWP;
#define FRAM_RECORD_ADDRESS  0x1812
  • 这个函数是自己写的吗,没用过这个芯片,但是感觉你这个函数不大对。
    看了看数据手册,你只是使能写,然后操作了这么一句*pFRAM_write_ptr = ui32data,然后进行数据保护。写数据的过程呢?这句无法执行写数据的操作吧,重新写这个函数吧。
  • 建议先运行官网例程试试
  • 由于开发进度很紧,我直接用TI 《MSP430FR4xx 实现的水表》中的程序
    其中FRAM读写,只是他用的是程序区FRAM
             SYSCFG0 &= ~PFWP;
             SYSCFG0 |= PFWP;
    void FRAMWrite_Char(uint8_t *pFRAM_write_ptr, uint8_t ui8data)
             SYSCFG0 &= ~PFWP;
             *pFRAM_write_ptr = ui8data;
             SYSCFG0 |= PFWP;
    pAddress = (uint8_t *)(FRAM_RECORD_BASE + (tRTCData.ui8Year - 13)*120 + (tRTCData.ui8Month - 1)*10);
    FRAMWrite_Char(pAddress++,tRTCData.ui8Year);
    FRAMWrite_Long((uint32_t *)FRAM_RECORD_ADDRESS,ui32Sum);
    ui32Sum = *((uint32_t *)FRAM_RECORD_ADDRESS);
    // Fram record address
    #define FRAM_RECORD_ADDRESS 0xFF00     // Refresh every 1 second
    #define FRAM_RECORD_CHECK 0xFF40          // First record check address
    #define FRAM_RECORD_BASE 0xFA00        // Monthly record in stand-alone address
    我读写8 16 32 64都根据他改的
  • uint8_t  i;
    uint32_t *pAddress;
                    for(i=0;i<Freq_cn;i++)
                            pAddress = (uint32_t *)(FRAM_RECORD_Freq + i*4);
                      FRAMWrite_Long((uint32_t *)(pAddress),flow_Freq_k[i]);
                            pAddress = (uint32_t *)(FRAM_RECORD_rate + i*4);
                      FRAMWrite_Long((uint32_t *)(pAddress),flow_rate_k[i]);
    uint8_t  i;
    uint32_t *pAddress;
                      flow_Freq_k[i] = *((uint32_t *)pAddress);
                      flow_rate_k[i] = *((uint32_t *)pAddress);
    FRAMWrite_uint64((uint64_t *)FRAM_RECORD_ADDRESS,0); //写FRAM (刷新)
    //FRAMWrite_Long((uint32_t *)FRAM_RECORD_ADDRESS, 0);
    //FRAMWrite_uint16((uint16_t *)FRAM_RECORD_ADDRESS, 0);
    一样的啊!
  • 这时你说的官方的程序
             SYSCFG0 &= ~PFWP;
             SYSCFG0 |= PFWP;
             SYSCFG0 &= ~PFWP;
             SYSCFG0 |= PFWP;
    你假如需要移植到数据区的话,需要测试下,单独写8位,16位,32位的数据进去,是否ok呢,以为msp430的寄存器是16位的,也就是说使用一次*pFRAM_write_ptr = ui8data这样的赋值,最大只能写16位的数据,你32位的数据,一次是肯定写不进去的,只能分两次写。
  • 结贴,是常量地址定义有错,FRAM读写没有问题!
