Other Parts Discussed in Thread: MSP430F5529
*说明:波特率9600,无校验位,数据位8为,停止位1位,采用低频波特率模式
#include <msp430f5529.h>
* main.c
int main(void) {
WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
P3SEL |= BIT3 + BIT4;
UCA0CTL1 = UCSWRST;
UCA0CTL1 = UCSSEL_1;
UCA0BR0 = 3;
UCA0BR1 = 0;
UCA0MCTL = UCBRS_3 + UCBRF_0;
UCA0CTL1 &= ~UCSWRST;
UCA0IE = UCRXIE;
//_EINT();
_bis_SR_register(LPM3_bits+GIE);
//return 0;
#pragma vector=USCI_A0_VECTOR
interrupt void USCI_A0_ISR(void)
switch(_even_in_range(UCA0IV,4))
{ case 0:
break;
case 2:
while(!(UCA0IFG & UCTXIFG));//等待发送完成
UCA0RXBUF = UCA0TXBUF;//将发送缓冲寄存器中的字符发送到接受缓冲寄存器中, 发给上位机,助手回显
break;
case 4:
break;
default:
break;
