Dear TI MCU工程师
IAR for MSP430 6.4版本采用MSP-FET430UIF 烧录MSP430I2021 Fail
可通过编译,但烧录提示如下错误
Tue Mar 28, 2017 16:51:58: Using license: Standalone license - IAR Embedded Workbench for Texas Instruments MSP430
Tue Mar 28, 2017 16:52:00: Firmware version 3.5.1.1
Tue Mar 28, 2017 16:52:00: Interface dll version 3.5.1.1
Tue Mar 28, 2017 16:52:01: Device : MSP430I204x_I203x_I202x
Tue Mar 28, 2017 16:52:01: External voltage : 0.1 V
Tue Mar 28, 2017 16:52:01: VCC voltage : 3.4 V
Tue Mar 28, 2017 16:52:18: Could not reset device : (Reset) , method=0x1, execute=0x0, releaseJTAG=0x0
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8027 on target 0xff in file 0x41
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8026 on target 0xff in file 0x30
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8025 on target 0xff in file 0x43
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8024 on target 0xff in file 0xc
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8023 on target 0xff in file 0x1
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8022 on target 0xff in file 0x20
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8021 on target 0xff in file 0x5a
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8020 on target 0xff in file 0x80
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801f on target 0xff in file 0x40
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801e on target 0xff in file 0xb2
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8031 on target 0xff in file 0x41
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8030 on target 0xff in file 0x30
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801d on target 0xff in file 0x3f
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801c on target 0xff in file 0xf9
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801b on target 0xff in file 0x80
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801a on target 0xff in file 0x30
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8019 on target 0xff in file 0x12
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8018 on target 0xff in file 0xb0
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8017 on target 0xff in file 0x43
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8016 on target 0xff in file 0x5c
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8015 on target 0xff in file 0x41
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8014 on target 0xff in file 0xd
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8013 on target 0xff in file 0x0
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8012 on target 0xff in file 0x0
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8011 on target 0xff in file 0x4a
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8010 on target 0xff in file 0x81
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800f on target 0xff in file 0x4c
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800e on target 0xff in file 0xa
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800d on target 0xff in file 0x83
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800c on target 0xff in file 0x21
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802b on target 0xff in file 0x80
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802a on target 0xff in file 0xc
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8029 on target 0xff in file 0x40
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8028 on target 0xff in file 0x30
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800b on target 0xff in file 0x80
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800a on target 0xff in file 0x2c
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8009 on target 0xff in file 0x12
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8008 on target 0xff in file 0xb0
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8007 on target 0xff in file 0x80
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8006 on target 0xff in file 0x1e
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8005 on target 0xff in file 0x12
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8004 on target 0xff in file 0xb0
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8003 on target 0xff in file 0xa
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8002 on target 0xff in file 0x0
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8001 on target 0xff in file 0x40
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8000 on target 0xff in file 0x31
Tue Mar 28, 2017 16:52:30: Verify error at address 0xffff on target 0xff in file 0x80
Tue Mar 28, 2017 16:52:30: Verify error at address 0xfffe on target 0xff in file 0x0
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802f on target 0xff in file 0x80
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802e on target 0xff in file 0x28
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802d on target 0xff in file 0x40
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802c on target 0xff in file 0x30
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8027. Value should be 0x41 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8026. Value should be 0x30 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8025. Value should be 0x43 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8024. Value should be 0xc but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8023. Value should be 0x1 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8022. Value should be 0x20 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8021. Value should be 0x5a but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8020. Value should be 0x80 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801f. Value should be 0x40 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801e. Value should be 0xb2 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8031. Value should be 0x41 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8030. Value should be 0x30 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801d. Value should be 0x3f but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801c. Value should be 0xf9 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801b. Value should be 0x80 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x801a. Value should be 0x30 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8019. Value should be 0x12 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8018. Value should be 0xb0 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8017. Value should be 0x43 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8016. Value should be 0x5c but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8015. Value should be 0x41 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8014. Value should be 0xd but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8013. Value should be 0x0 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8012. Value should be 0x0 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8011. Value should be 0x4a but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8010. Value should be 0x81 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800f. Value should be 0x4c but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800e. Value should be 0xa but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800d. Value should be 0x83 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800c. Value should be 0x21 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802b. Value should be 0x80 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802a. Value should be 0xc but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8029. Value should be 0x40 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8028. Value should be 0x30 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800b. Value should be 0x80 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x800a. Value should be 0x2c but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8009. Value should be 0x12 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8008. Value should be 0xb0 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8007. Value should be 0x80 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8006. Value should be 0x1e but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8005. Value should be 0x12 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8004. Value should be 0xb0 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8003. Value should be 0xa but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8002. Value should be 0x0 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8001. Value should be 0x40 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x8000. Value should be 0x31 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0xffff. Value should be 0x80 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0xfffe. Value should be 0x0 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802f. Value should be 0x80 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802e. Value should be 0x28 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802d. Value should be 0x40 but is 0xff.
Tue Mar 28, 2017 16:52:30: Verify error at address 0x802c. Value should be 0x30 but is 0xff.
Tue Mar 28, 2017 16:52:30: Failed to load debugee: D:\TN912L\TN912L\Debug\Exe\TN912L.d43
请帮忙确认原因。
非常感谢!
