关于芯片MSP430AFE253,的可编程增益怎么使用,怎么C语言软件设置呢?例程里也没有详解
jing pan1 说:MSP430AFE253这个芯片的头文件在哪里可以下载,例程都只有.c,网上也找不到,只有430其他系列的头文件。
CCS 里面有
/* Copyright (c) 2017, Texas Instruments Incorporated */
/* All rights reserved. */
/* Redistribution and use in source and binary forms, with or without */
/* modification, are permitted provided that the following conditions */
/* are met: */
/* * Redistributions of source code must retain the above copyright */
/* notice, this list of conditions and the following disclaimer. */
/* * Redistributions in binary form must reproduce the above copyright */
/* notice, this list of conditions and the following disclaimer in the */
/* documentation and/or other materials provided with the distribution. */
/* * Neither the name of Texas Instruments Incorporated nor the names of */
/* its contributors may be used to endorse or promote products derived */
/* from this software without specific prior written permission. */
/* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */
/* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, */
/* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR */
/* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR */
/* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, */
/* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, */
/* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */
/* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, */
/* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR */
/* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
* Standard register and bit definitions for the Texas Instruments
* MSP430 microcontroller.
* This file supports assembler and C development for
* MSP430AFE253 devices.
* Texas Instruments, Version 1.0
* Rev. 1.0, Setup
#ifndef __MSP430AFE253
#define __MSP430AFE253
#define __MSP430_HEADER_VERSION__ 1199
#ifdef __cplusplus
extern "C" {
#endif
/* PERIPHERAL FILE MAP */
/* External references resolved by a device-specific linker command file */
#define SFR_8BIT(address) extern volatile unsigned char address
#define SFR_16BIT(address) extern volatile unsigned int address
#define SFR_32BIT(address) extern volatile unsigned long address
* STANDARD BITS
#define BIT0 (0x0001)
#define BIT1 (0x0002)
#define BIT2 (0x0004)
#define BIT3 (0x0008)
#define BIT4 (0x0010)
#define BIT5 (0x0020)
#define BIT6 (0x0040)
#define BIT7 (0x0080)
#define BIT8 (0x0100)
#define BIT9 (0x0200)
#define BITA (0x0400)
#define BITB (0x0800)
#define BITC (0x1000)
#define BITD (0x2000)
#define BITE (0x4000)
#define BITF (0x8000)
* STATUS REGISTER BITS
#define C (0x0001)
#define Z (0x0002)
#define N (0x0004)
#define V (0x0100)
#define GIE (0x0008)
#define CPUOFF (0x0010)
#define OSCOFF (0x0020)
#define SCG0 (0x0040)
#define SCG1 (0x0080)
/* Low Power Modes coded with Bits 4-7 in SR */
#ifdef __ASM_HEADER__ /* Begin #defines for assembler */
#define LPM0 (CPUOFF)
#define LPM1 (SCG0+CPUOFF)
#define LPM2 (SCG1+CPUOFF)
#define LPM3 (SCG1+SCG0+CPUOFF)
#define LPM4 (SCG1+SCG0+OSCOFF+CPUOFF)
/* End #defines for assembler */
#else /* Begin #defines for C */
#define LPM0_bits (CPUOFF)
#define LPM1_bits (SCG0+CPUOFF)
#define LPM2_bits (SCG1+CPUOFF)
#define LPM3_bits (SCG1+SCG0+CPUOFF)
#define LPM4_bits (SCG1+SCG0+OSCOFF+CPUOFF)
#include "in430.h"
#include <intrinsics.h>
#define LPM0 __bis_SR_register(LPM0_bits) /* Enter Low Power Mode 0 */
#define LPM0_EXIT __bic_SR_register_on_exit(LPM0_bits) /* Exit Low Power Mode 0 */
#define LPM1 __bis_SR_register(LPM1_bits) /* Enter Low Power Mode 1 */
#define LPM1_EXIT __bic_SR_register_on_exit(LPM1_bits) /* Exit Low Power Mode 1 */
#define LPM2 __bis_SR_register(LPM2_bits) /* Enter Low Power Mode 2 */
#define LPM2_EXIT __bic_SR_register_on_exit(LPM2_bits) /* Exit Low Power Mode 2 */
#define LPM3 __bis_SR_register(LPM3_bits) /* Enter Low Power Mode 3 */
#define LPM3_EXIT __bic_SR_register_on_exit(LPM3_bits) /* Exit Low Power Mode 3 */
#define LPM4 __bis_SR_register(LPM4_bits) /* Enter Low Power Mode 4 */
#define LPM4_EXIT __bic_SR_register_on_exit(LPM4_bits) /* Exit Low Power Mode 4 */
#endif /* End #defines for C */
* SPECIAL FUNCTION REGISTER ADDRESSES + CONTROL BITS
SFR_8BIT(IE1); /* Interrupt Enable 1 */
#define U0IE IE1 /* UART0 Interrupt Enable Register */
#define WDTIE (0x01) /* Watchdog Interrupt Enable */
#define OFIE (0x02) /* Osc. Fault Interrupt Enable */
#define NMIIE (0x10) /* NMI Interrupt Enable */
#define ACCVIE (0x20) /* Flash Access Violation Interrupt Enable */
#define URXIE0 (0x40)
#define UTXIE0 (0x80)
SFR_8BIT(IFG1); /* Interrupt Flag 1 */
#define U0IFG IFG1 /* UART0 Interrupt Flag Register */
#define WDTIFG (0x01) /* Watchdog Interrupt Flag */
#define OFIFG (0x02) /* Osc. Fault Interrupt Flag */
#define PORIFG (0x04) /* Power On Interrupt Flag */
#define RSTIFG (0x08) /* Reset Interrupt Flag */
#define NMIIFG (0x10) /* NMI Interrupt Flag */
#define URXIFG0 (0x40)
#define UTXIFG0 (0x80)
SFR_8BIT(ME1); /* Module Enable 1 */
#define U0ME ME1 /* UART0 Module Enable Register */
#define URXE0 (0x40)
#define UTXE0 (0x80)
#define USPIE0 (0x40)
* Basic Clock Module
#define __MSP430_HAS_BC2__ /* Definition to show that Module is available */
SFR_8BIT(DCOCTL); /* DCO Clock Frequency Control */
SFR_8BIT(BCSCTL1); /* Basic Clock System Control 1 */
SFR_8BIT(BCSCTL2); /* Basic Clock System Control 2 */
SFR_8BIT(BCSCTL3); /* Basic Clock System Control 3 */
#define MOD0 (0x01) /* Modulation Bit 0 */
#define MOD1 (0x02) /* Modulation Bit 1 */
#define MOD2 (0x04) /* Modulation Bit 2 */
#define MOD3 (0x08) /* Modulation Bit 3 */
#define MOD4 (0x10) /* Modulation Bit 4 */
#define DCO0 (0x20) /* DCO Select Bit 0 */
#define DCO1 (0x40) /* DCO Select Bit 1 */
#define DCO2 (0x80) /* DCO Select Bit 2 */
#define RSEL0 (0x01) /* Range Select Bit 0 */
#define RSEL1 (0x02) /* Range Select Bit 1 */
#define RSEL2 (0x04) /* Range Select Bit 2 */
#define RSEL3 (0x08) /* Range Select Bit 3 */
#define DIVA0 (0x10) /* ACLK Divider 0 */
#define DIVA1 (0x20) /* ACLK Divider 1 */
#define XTS (0x40) /* LFXTCLK 0:Low Freq. / 1: High Freq. */
#define XT2OFF (0x80) /* Enable XT2CLK */
#define DIVA_0 (0x00) /* ACLK Divider 0: /1 */
#define DIVA_1 (0x10) /* ACLK Divider 1: /2 */
#define DIVA_2 (0x20) /* ACLK Divider 2: /4 */
#define DIVA_3 (0x30) /* ACLK Divider 3: /8 */
#define DIVS0 (0x02) /* SMCLK Divider 0 */
#define DIVS1 (0x04) /* SMCLK Divider 1 */
#define SELS (0x08) /* SMCLK Source Select 0:DCOCLK / 1:XT2CLK/LFXTCLK */
#define DIVM0 (0x10) /* MCLK Divider 0 */
#define DIVM1 (0x20) /* MCLK Divider 1 */
#define SELM0 (0x40) /* MCLK Source Select 0 */
#define SELM1 (0x80) /* MCLK Source Select 1 */
#define DIVS_0 (0x00) /* SMCLK Divider 0: /1 */
#define DIVS_1 (0x02) /* SMCLK Divider 1: /2 */
#define DIVS_2 (0x04) /* SMCLK Divider 2: /4 */
#define DIVS_3 (0x06) /* SMCLK Divider 3: /8 */
#define DIVM_0 (0x00) /* MCLK Divider 0: /1 */
#define DIVM_1 (0x10) /* MCLK Divider 1: /2 */
#define DIVM_2 (0x20) /* MCLK Divider 2: /4 */
#define DIVM_3 (0x30) /* MCLK Divider 3: /8 */
#define SELM_0 (0x00) /* MCLK Source Select 0: DCOCLK */
#define SELM_1 (0x40) /* MCLK Source Select 1: DCOCLK */
#define SELM_2 (0x80) /* MCLK Source Select 2: XT2CLK/LFXTCLK */
#define SELM_3 (0xC0) /* MCLK Source Select 3: LFXTCLK */
#define LFXT1OF (0x01) /* Low/high Frequency Oscillator Fault Flag */
#define XT2OF (0x02) /* High frequency oscillator 2 fault flag */
#define XCAP0 (0x04) /* XIN/XOUT Cap 0 */
#define XCAP1 (0x08) /* XIN/XOUT Cap 1 */
#define LFXT1S0 (0x10) /* Mode 0 for LFXT1 (XTS = 0) */
#define LFXT1S1 (0x20) /* Mode 1 for LFXT1 (XTS = 0) */
#define XT2S0 (0x40) /* Mode 0 for XT2 */
#define XT2S1 (0x80) /* Mode 1 for XT2 */
#define XCAP_0 (0x00) /* XIN/XOUT Cap : 0 pF */
#define XCAP_1 (0x04) /* XIN/XOUT Cap : 6 pF */
#define XCAP_2 (0x08) /* XIN/XOUT Cap : 10 pF */
#define XCAP_3 (0x0C) /* XIN/XOUT Cap : 12.5 pF */
#define LFXT1S_0 (0x00) /* Mode 0 for LFXT1 : Normal operation */
#define LFXT1S_1 (0x10) /* Mode 1 for LFXT1 : Reserved */
#define LFXT1S_2 (0x20) /* Mode 2 for LFXT1 : VLO */
#define LFXT1S_3 (0x30) /* Mode 3 for LFXT1 : Digital input signal */
#define XT2S_0 (0x00) /* Mode 0 for XT2 : 0.4 - 1 MHz */
#define XT2S_1 (0x40) /* Mode 1 for XT2 : 1 - 4 MHz */
#define XT2S_2 (0x80) /* Mode 2 for XT2 : 2 - 16 MHz */
#define XT2S_3 (0xC0) /* Mode 3 for XT2 : Digital input signal */
* Flash Memory
#define __MSP430_HAS_FLASH2__ /* Definition to show that Module is available */
SFR_16BIT(FCTL1); /* FLASH Control 1 */
SFR_16BIT(FCTL2); /* FLASH Control 2 */
SFR_16BIT(FCTL3); /* FLASH Control 3 */
#define FRKEY (0x9600) /* Flash key returned by read */
#define FWKEY (0xA500) /* Flash key for write */
#define FXKEY (0x3300) /* for use with XOR instruction */
#define ERASE (0x0002) /* Enable bit for Flash segment erase */
#define MERAS (0x0004) /* Enable bit for Flash mass erase */
#define WRT (0x0040) /* Enable bit for Flash write */
#define BLKWRT (0x0080) /* Enable bit for Flash segment write */
#define SEGWRT (0x0080) /* old definition */ /* Enable bit for Flash segment write */
#define FN0 (0x0001) /* Divide Flash clock by 1 to 64 using FN0 to FN5 according to: */
#define FN1 (0x0002) /* 32*FN5 + 16*FN4 + 8*FN3 + 4*FN2 + 2*FN1 + FN0 + 1 */
#ifndef FN2
#define FN2 (0x0004)
#endif
#ifndef FN3
#define FN3 (0x0008)
#endif
#ifndef FN4
#define FN4 (0x0010)
#endif
#define FN5 (0x0020)
#define FSSEL0 (0x0040) /* Flash clock select 0 */ /* to distinguish from USART SSELx */
#define FSSEL1 (0x0080) /* Flash clock select 1 */
#define FSSEL_0 (0x0000) /* Flash clock select: 0 - ACLK */
#define FSSEL_1 (0x0040) /* Flash clock select: 1 - MCLK */
#define FSSEL_2 (0x0080) /* Flash clock select: 2 - SMCLK */
#define FSSEL_3 (0x00C0) /* Flash clock select: 3 - SMCLK */
#define BUSY (0x0001) /* Flash busy: 1 */
#define KEYV (0x0002) /* Flash Key violation flag */
#define ACCVIFG (0x0004) /* Flash Access violation flag */
#define WAIT (0x0008) /* Wait flag for segment write */
#define LOCK (0x0010) /* Lock bit: 1 - Flash is locked (read only) */
#define EMEX (0x0020) /* Flash Emergency Exit */
#define LOCKA (0x0040) /* Segment A Lock bit: read = 1 - Segment is locked (read only) */
#define FAIL (0x0080) /* Last Program or Erase failed */
* HARDWARE MULTIPLIER
#define __MSP430_HAS_MPY__ /* Definition to show that Module is available */
SFR_16BIT(MPY); /* Multiply Unsigned/Operand 1 */
SFR_16BIT(MPYS); /* Multiply Signed/Operand 1 */
SFR_16BIT(MAC); /* Multiply Unsigned and Accumulate/Operand 1 */
SFR_16BIT(MACS); /* Multiply Signed and Accumulate/Operand 1 */
SFR_16BIT(OP2); /* Operand 2 */
SFR_16BIT(RESLO); /* Result Low Word */
SFR_16BIT(RESHI); /* Result High Word */
SFR_16BIT(SUMEXT); /* Sum Extend */
* DIGITAL I/O Port1/2 Pull up / Pull down Resistors
#define __MSP430_HAS_PORT1_R__ /* Definition to show that Module is available */
#define __MSP430_HAS_PORT2_R__ /* Definition to show that Module is available */
#define __MSP430_HAS_P1SEL__ /* Define for DriverLib */
#define __MSP430_HAS_P1SEL2__ /* Define for DriverLib */
#define __MSP430_HAS_P2SEL__ /* Define for DriverLib */
#define __MSP430_HAS_P2SEL2__ /* Define for DriverLib */
SFR_8BIT(P1IN); /* Port 1 Input */
SFR_8BIT(P1OUT); /* Port 1 Output */
SFR_8BIT(P1DIR); /* Port 1 Direction */
SFR_8BIT(P1IFG); /* Port 1 Interrupt Flag */
SFR_8BIT(P1IES); /* Port 1 Interrupt Edge Select */
SFR_8BIT(P1IE); /* Port 1 Interrupt Enable */
SFR_8BIT(P1SEL); /* Port 1 Selection */
SFR_8BIT(P1SEL2); /* Port 1 Selection 2 */
SFR_8BIT(P1REN); /* Port 1 Resistor Enable */
SFR_8BIT(P2IN); /* Port 2 Input */
SFR_8BIT(P2OUT); /* Port 2 Output */
SFR_8BIT(P2DIR); /* Port 2 Direction */
SFR_8BIT(P2IFG); /* Port 2 Interrupt Flag */
SFR_8BIT(P2IES); /* Port 2 Interrupt Edge Select */
SFR_8BIT(P2IE); /* Port 2 Interrupt Enable */
SFR_8BIT(P2SEL); /* Port 2 Selection */
SFR_8BIT(P2SEL2); /* Port 2 Selection 2 */
SFR_8BIT(P2REN); /* Port 2 Resistor Enable */
* SD24_A3 - Sigma Delta 24 Bit
#define __MSP430_HAS_SD24_A3__ /* Definition to show that Module is available */
SFR_8BIT(SD24INCTL0); /* SD24 Input Control Register Channel 0 */
SFR_8BIT(SD24INCTL1); /* SD24 Input Control Register Channel 1 */
SFR_8BIT(SD24INCTL2); /* SD24 Input Control Register Channel 2 */
SFR_8BIT(SD24PRE0); /* SD24 Preload Register Channel 0 */
SFR_8BIT(SD24PRE1); /* SD24 Preload Register Channel 1 */
SFR_8BIT(SD24PRE2); /* SD24 Preload Register Channel 2 */
SFR_8BIT(SD24CONF1); /* SD24 Internal Configuration Register 1 */
/* Please use only the recommended settings */
SFR_16BIT(SD24CTL); /* Sigma Delta ADC 24 Control Register */
SFR_16BIT(SD24CCTL0); /* SD24 Channel 0 Control Register */
SFR_16BIT(SD24CCTL1); /* SD24 Channel 1 Control Register */
SFR_16BIT(SD24CCTL2); /* SD24 Channel 2 Control Register */
SFR_16BIT(SD24MEM0); /* SD24 Channel 0 Conversion Memory */
SFR_16BIT(SD24MEM1); /* SD24 Channel 1 Conversion Memory */
SFR_16BIT(SD24MEM2); /* SD24 Channel 2 Conversion Memory */
SFR_16BIT(SD24IV); /* SD24 Interrupt Vector Register */
/* SD24INCTLx */
#define SD24INCH0 (0x0001) /* SD24 Input Channel select 0 */
#define SD24INCH1 (0x0002) /* SD24 Input Channel select 1 */
#define SD24INCH2 (0x0004) /* SD24 Input Channel select 2 */
#define SD24GAIN0 (0x0008) /* SD24 Input Pre-Amplifier Gain Select 0 */
#define SD24GAIN1 (0x0010) /* SD24 Input Pre-Amplifier Gain Select 1 */
#define SD24GAIN2 (0x0020) /* SD24 Input Pre-Amplifier Gain Select 2 */
#define SD24INTDLY0 (0x0040) /* SD24 Interrupt Delay after 1.Conversion 0 */
#define SD24INTDLY1 (0x0080) /* SD24 Interrupt Delay after 1.Conversion 1 */
#define SD24GAIN_1 (0x0000) /* SD24 Input Pre-Amplifier Gain Select *1 */
#define SD24GAIN_2 (0x0008) /* SD24 Input Pre-Amplifier Gain Select *2 */
#define SD24GAIN_4 (0x0010) /* SD24 Input Pre-Amplifier Gain Select *4 */
#define SD24GAIN_8 (0x0018) /* SD24 Input Pre-Amplifier Gain Select *8 */
#define SD24GAIN_16 (0x0020) /* SD24 Input Pre-Amplifier Gain Select *16 */
#define SD24GAIN_32 (0x0028) /* SD24 Input Pre-Amplifier Gain Select *32 */
#define SD24INCH_0 (0x0000) /* SD24 Input Channel select input */
#define SD24INCH_1 (0x0001) /* SD24 Input Channel select input */
#define SD24INCH_2 (0x0002) /* SD24 Input Channel select input */
#define SD24INCH_3 (0x0003) /* SD24 Input Channel select input */
#define SD24INCH_4 (0x0004) /* SD24 Input Channel select input */
#define SD24INCH_5 (0x0005) /* SD24 Input Channel select Vcc divider */
#define SD24INCH_6 (0x0006) /* SD24 Input Channel select Temp */
#define SD24INCH_7 (0x0007) /* SD24 Input Channel select Offset */
#define SD24INTDLY_0 (0x0000) /* SD24 Interrupt Delay: Int. after 4.Conversion */
#define SD24INTDLY_1 (0x0040) /* SD24 Interrupt Delay: Int. after 3.Conversion */
#define SD24INTDLY_2 (0x0080) /* SD24 Interrupt Delay: Int. after 2.Conversion */
#define SD24INTDLY_3 (0x00C0) /* SD24 Interrupt Delay: Int. after 1.Conversion */
/* SD24CTL */
#define SD24OVIE (0x0002) /* SD24 Overflow Interupt Enable */
#define SD24REFON (0x0004) /* SD24 Switch internal Reference on */
#define SD24VMIDON (0x0008) /* SD24 Switch Vmid Buffer on */
#define SD24SSEL0 (0x0010) /* SD24 Clock Source Select 0 */
#define SD24SSEL1 (0x0020) /* SD24 Clock Source Select 1 */
#define SD24DIV0 (0x0040) /* SD24 Clock Divider Select 0 */
#define SD24DIV1 (0x0080) /* SD24 Clock Divider Select 1 */
#define SD24LP (0x0100) /* SD24 Low Power Mode Enable */
#define SD24XDIV0 (0x0200) /* SD24 2.Clock Divider Select 0 */
#define SD24XDIV1 (0x0400) /* SD24 2.Clock Divider Select 1 */
//#define SD24XDIV2 (0x0800) /* SD24 2.Clock Divider Select 2 */
#define SD24DIV_0 (0x0000) /* SD24 Clock Divider Select /1 */
#define SD24DIV_1 (SD24DIV0) /* SD24 Clock Divider Select /2 */
#define SD24DIV_2 (SD24DIV1) /* SD24 Clock Divider Select /4 */
#define SD24DIV_3 (SD24DIV0+SD24DIV1) /* SD24 Clock Divider Select /8 */
#define SD24XDIV_0 (0x0000) /* SD24 2.Clock Divider Select /1 */
#define SD24XDIV_1 (SD24XDIV0) /* SD24 2.Clock Divider Select /3 */
#define SD24XDIV_2 (SD24XDIV1) /* SD24 2.Clock Divider Select /16 */
#define SD24XDIV_3 (SD24XDIV0+SD24XDIV1) /* SD24 2.Clock Divider Select /48 */
#define SD24SSEL_0 (0x0000) /* SD24 Clock Source Select MCLK */
#define SD24SSEL_1 (SD24SSEL0) /* SD24 Clock Source Select SMCLK */
#define SD24SSEL_2 (SD24SSEL1) /* SD24 Clock Source Select ACLK */
#define SD24SSEL_3 (SD24SSEL0+SD24SSEL1) /* SD24 Clock Source Select TACLK */
/* SD24CCTLx */
#define SD24GRP (0x0001) /* SD24 Grouping of Channels: 0:Off/1:On */
#define SD24SC (0x0002) /* SD24 Start Conversion */
#define SD24IFG (0x0004) /* SD24 Channel x Interrupt Flag */
#define SD24IE (0x0008) /* SD24 Channel x Interrupt Enable */
#define SD24DF (0x0010) /* SD24 Channel x Data Format: 0:Unipolar/1:Bipolar */
#define SD24OVIFG (0x0020) /* SD24 Channel x Overflow Interrupt Flag */
#define SD24LSBACC (0x0040) /* SD24 Channel x Access LSB of ADC */
#define SD24LSBTOG (0x0080) /* SD24 Channel x Toggle LSB Output of ADC */
#define SD24OSR0 (0x0100) /* SD24 Channel x OverSampling Ratio 0 */
#define SD24OSR1 (0x0200) /* SD24 Channel x OverSampling Ratio 1 */
#define SD24SNGL (0x0400) /* SD24 Channel x Single Conversion On/Off */
#define SD24XOSR (0x0800) /* SD24 Channel x Extended OverSampling Ratio */
#define SD24UNI (0x1000) /* SD24 Channel x Bipolar(0) / Unipolar(1) Mode */
#define SD24OSR_1024 (SD24OSR0+SD24XOSR) /* SD24 Channel x OverSampling Ratio 1024 */
#define SD24OSR_512 (SD24XOSR) /* SD24 Channel x OverSampling Ratio 512 */
#define SD24OSR_256 (0x0000) /* SD24 Channel x OverSampling Ratio 256 */
#define SD24OSR_128 (0x0100) /* SD24 Channel x OverSampling Ratio 128 */
#define SD24OSR_64 (0x0200) /* SD24 Channel x OverSampling Ratio 64 */
#define SD24OSR_32 (0x0300) /* SD24 Channel x OverSampling Ratio 32 */
/* SD24IV Definitions */
#define SD24IV_NONE (0x0000) /* No Interrupt pending */
#define SD24IV_SD24OVIFG (0x0002) /* SD24OVIFG */
#define SD24IV_SD24MEM0 (0x0004) /* SD24MEM0 SD24IFG */
#define SD24IV_SD24MEM1 (0x0006) /* SD24MEM1 SD24IFG */
#define SD24IV_SD24MEM2 (0x0008) /* SD24MEM2 SD24IFG */
* Brown-Out, Supply Voltage Supervision (SVS)
#define __MSP430_HAS_SVS__ /* Definition to show that Module is available */
SFR_8BIT(SVSCTL); /* SVS Control */
#define SVSFG (0x01) /* SVS Flag */
#define SVSOP (0x02) /* SVS output (read only) */
#define SVSON (0x04) /* Switches the SVS on/off */
#define PORON (0x08) /* Enable POR Generation if Low Voltage */
#define VLD0 (0x10)
#define VLD1 (0x20)
#define VLD2 (0x40)
#define VLD3 (0x80)
#define VLDON (0x10)
#define VLDOFF (0x00)
#define VLD_1_8V (0x10)
* Timer A3
#define __MSP430_HAS_TA3__ /* Definition to show that Module is available */
SFR_16BIT(TAIV); /* Timer A Interrupt Vector Word */
SFR_16BIT(TACTL); /* Timer A Control */
SFR_16BIT(TACCTL0); /* Timer A Capture/Compare Control 0 */
SFR_16BIT(TACCTL1); /* Timer A Capture/Compare Control 1 */
SFR_16BIT(TACCTL2); /* Timer A Capture/Compare Control 2 */
SFR_16BIT(TAR); /* Timer A Counter Register */
SFR_16BIT(TACCR0); /* Timer A Capture/Compare 0 */
SFR_16BIT(TACCR1); /* Timer A Capture/Compare 1 */
SFR_16BIT(TACCR2); /* Timer A Capture/Compare 2 */
/* Alternate register names */
#define CCTL0 TACCTL0 /* Timer A Capture/Compare Control 0 */
#define CCTL1 TACCTL1 /* Timer A Capture/Compare Control 1 */
#define CCTL2 TACCTL2 /* Timer A Capture/Compare Control 2 */
#define CCR0 TACCR0 /* Timer A Capture/Compare 0 */
#define CCR1 TACCR1 /* Timer A Capture/Compare 1 */
#define CCR2 TACCR2 /* Timer A Capture/Compare 2 */
#define CCTL0_ TACCTL0_ /* Timer A Capture/Compare Control 0 */
#define CCTL1_ TACCTL1_ /* Timer A Capture/Compare Control 1 */
#define CCTL2_ TACCTL2_ /* Timer A Capture/Compare Control 2 */
#define CCR0_ TACCR0_ /* Timer A Capture/Compare 0 */
#define CCR1_ TACCR1_ /* Timer A Capture/Compare 1 */
#define CCR2_ TACCR2_ /* Timer A Capture/Compare 2 */
/* Alternate register names - 5xx style */
#define TA0IV TAIV /* Timer A Interrupt Vector Word */
#define TA0CTL TACTL /* Timer A Control */
#define TA0CCTL0 TACCTL0 /* Timer A Capture/Compare Control 0 */
#define TA0CCTL1 TACCTL1 /* Timer A Capture/Compare Control 1 */
#define TA0CCTL2 TACCTL2 /* Timer A Capture/Compare Control 2 */
#define TA0R TAR /* Timer A Counter Register */
#define TA0CCR0 TACCR0 /* Timer A Capture/Compare 0 */
#define TA0CCR1 TACCR1 /* Timer A Capture/Compare 1 */
#define TA0CCR2 TACCR2 /* Timer A Capture/Compare 2 */
#define TA0IV_ TAIV_ /* Timer A Interrupt Vector Word */
#define TA0CTL_ TACTL_ /* Timer A Control */
#define TA0CCTL0_ TACCTL0_ /* Timer A Capture/Compare Control 0 */
#define TA0CCTL1_ TACCTL1_ /* Timer A Capture/Compare Control 1 */
#define TA0CCTL2_ TACCTL2_ /* Timer A Capture/Compare Control 2 */
#define TA0R_ TAR_ /* Timer A Counter Register */
#define TA0CCR0_ TACCR0_ /* Timer A Capture/Compare 0 */
#define TA0CCR1_ TACCR1_ /* Timer A Capture/Compare 1 */
#define TA0CCR2_ TACCR2_ /* Timer A Capture/Compare 2 */
#define TIMER0_A1_VECTOR TIMERA1_VECTOR /* Int. Vector: Timer A CC1-2, TA */
#define TIMER0_A0_VECTOR TIMERA0_VECTOR /* Int. Vector: Timer A CC0 */
#define TASSEL1 (0x0200) /* Timer A clock source select 1 */
#define TASSEL0 (0x0100) /* Timer A clock source select 0 */
#define ID1 (0x0080) /* Timer A clock input divider 1 */
#define ID0 (0x0040) /* Timer A clock input divider 0 */
#define MC1 (0x0020) /* Timer A mode control 1 */
#define MC0 (0x0010) /* Timer A mode control 0 */
#define TACLR (0x0004) /* Timer A counter clear */
#define TAIE (0x0002) /* Timer A counter interrupt enable */
#define TAIFG (0x0001) /* Timer A counter interrupt flag */
#define MC_0 (0*0x10u) /* Timer A mode control: 0 - Stop */
#define MC_1 (1*0x10u) /* Timer A mode control: 1 - Up to CCR0 */
#define MC_2 (2*0x10u) /* Timer A mode control: 2 - Continous up */
#define MC_3 (3*0x10u) /* Timer A mode control: 3 - Up/Down */
#define ID_0 (0*0x40u) /* Timer A input divider: 0 - /1 */
#define ID_1 (1*0x40u) /* Timer A input divider: 1 - /2 */
#define ID_2 (2*0x40u) /* Timer A input divider: 2 - /4 */
#define ID_3 (3*0x40u) /* Timer A input divider: 3 - /8 */
#define TASSEL_0 (0*0x100u) /* Timer A clock source select: 0 - TACLK */
#define TASSEL_1 (1*0x100u) /* Timer A clock source select: 1 - ACLK */
#define TASSEL_2 (2*0x100u) /* Timer A clock source select: 2 - SMCLK */
#define TASSEL_3 (3*0x100u) /* Timer A clock source select: 3 - INCLK */
#define CM1 (0x8000) /* Capture mode 1 */
#define CM0 (0x4000) /* Capture mode 0 */
#define CCIS1 (0x2000) /* Capture input select 1 */
#define CCIS0 (0x1000) /* Capture input select 0 */
#define SCS (0x0800) /* Capture sychronize */
#define SCCI (0x0400) /* Latched capture signal (read) */
#define CAP (0x0100) /* Capture mode: 1 /Compare mode : 0 */
#define OUTMOD2 (0x0080) /* Output mode 2 */
#define OUTMOD1 (0x0040) /* Output mode 1 */
#define OUTMOD0 (0x0020) /* Output mode 0 */
#define CCIE (0x0010) /* Capture/compare interrupt enable */
#define CCI (0x0008) /* Capture input signal (read) */
#define OUT (0x0004) /* PWM Output signal if output mode 0 */
#define COV (0x0002) /* Capture/compare overflow flag */
#define CCIFG (0x0001) /* Capture/compare interrupt flag */
#define OUTMOD_0 (0*0x20u) /* PWM output mode: 0 - output only */
#define OUTMOD_1 (1*0x20u) /* PWM output mode: 1 - set */
#define OUTMOD_2 (2*0x20u) /* PWM output mode: 2 - PWM toggle/reset */
#define OUTMOD_3 (3*0x20u) /* PWM output mode: 3 - PWM set/reset */
#define OUTMOD_4 (4*0x20u) /* PWM output mode: 4 - toggle */
#define OUTMOD_5 (5*0x20u) /* PWM output mode: 5 - Reset */
#define OUTMOD_6 (6*0x20u) /* PWM output mode: 6 - PWM toggle/set */
#define OUTMOD_7 (7*0x20u) /* PWM output mode: 7 - PWM reset/set */
#define CCIS_0 (0*0x1000u) /* Capture input select: 0 - CCIxA */
#define CCIS_1 (1*0x1000u) /* Capture input select: 1 - CCIxB */
#define CCIS_2 (2*0x1000u) /* Capture input select: 2 - GND */
#define CCIS_3 (3*0x1000u) /* Capture input select: 3 - Vcc */
#define CM_0 (0*0x4000u) /* Capture mode: 0 - disabled */
#define CM_1 (1*0x4000u) /* Capture mode: 1 - pos. edge */
#define CM_2 (2*0x4000u) /* Capture mode: 1 - neg. edge */
#define CM_3 (3*0x4000u) /* Capture mode: 1 - both edges */
/* TA3IV Definitions */
#define TAIV_NONE (0x0000) /* No Interrupt pending */
#define TAIV_TACCR1 (0x0002) /* TACCR1_CCIFG */
#define TAIV_TACCR2 (0x0004) /* TACCR2_CCIFG */
#define TAIV_6 (0x0006) /* Reserved */
#define TAIV_8 (0x0008) /* Reserved */
#define TAIV_TAIFG (0x000A) /* TAIFG */
#define TA0IV_NONE (0x0000) /* No Interrupt pending */
#define TA0IV_TACCR1 (0x0002) /* TA0CCR1_CCIFG */
#define TA0IV_TACCR2 (0x0004) /* TA0CCR2_CCIFG */
#define TA0IV_6 (0x0006) /* Reserved */
#define TA0IV_8 (0x0008) /* Reserved */
#define TA0IV_TAIFG (0x000A) /* TA0IFG */
* USART
/* UxCTL */
#define PENA (0x80) /* Parity enable */
#define PEV (0x40) /* Parity 0:odd / 1:even */
#define SPB (0x20) /* Stop Bits 0:one / 1: two */
#define CHAR (0x10) /* Data 0:7-bits / 1:8-bits */
#define LISTEN (0x08) /* Listen mode */
#define SYNC (0x04) /* UART / SPI mode */
#define MM (0x02) /* Master Mode off/on */
#define SWRST (0x01) /* USART Software Reset */
/* UxTCTL */
#define CKPH (0x80) /* SPI: Clock Phase */
#define CKPL (0x40) /* Clock Polarity */
#define SSEL1 (0x20) /* Clock Source Select 1 */
#define SSEL0 (0x10) /* Clock Source Select 0 */
#define URXSE (0x08) /* Receive Start edge select */
#define TXWAKE (0x04) /* TX Wake up mode */
#define STC (0x02) /* SPI: STC enable 0:on / 1:off */
#define TXEPT (0x01) /* TX Buffer empty */
/* UxRCTL */
#define FE (0x80) /* Frame Error */
#define PE (0x40) /* Parity Error */
#define OE (0x20) /* Overrun Error */
#define BRK (0x10) /* Break detected */
#define URXEIE (0x08) /* RX Error interrupt enable */
#define URXWIE (0x04) /* RX Wake up interrupt enable */
#define RXWAKE (0x02) /* RX Wake up detect */
#define RXERR (0x01) /* RX Error Error */
* USART 0
#define __MSP430_HAS_UART0__ /* Definition to show that Module is available */
SFR_8BIT(U0CTL); /* USART 0 Control */
SFR_8BIT(U0TCTL); /* USART 0 Transmit Control */
SFR_8BIT(U0RCTL); /* USART 0 Receive Control */
SFR_8BIT(U0MCTL); /* USART 0 Modulation Control */
SFR_8BIT(U0BR0); /* USART 0 Baud Rate 0 */
SFR_8BIT(U0BR1); /* USART 0 Baud Rate 1 */
SFR_8BIT(U0RXBUF); /* USART 0 Receive Buffer */
SFR_8BIT(U0TXBUF); /* USART 0 Transmit Buffer */
#define UCTL0 U0CTL /* USART 0 Control */
#define UTCTL0 U0TCTL /* USART 0 Transmit Control */
#define URCTL0 U0RCTL /* USART 0 Receive Control */
#define UMCTL0 U0MCTL /* USART 0 Modulation Control */
#define UBR00 U0BR0 /* USART 0 Baud Rate 0 */
#define UBR10 U0BR1 /* USART 0 Baud Rate 1 */
#define RXBUF0 U0RXBUF /* USART 0 Receive Buffer */
#define TXBUF0 U0TXBUF /* USART 0 Transmit Buffer */
#define UCTL0_ U0CTL_ /* USART 0 Control */
#define UTCTL0_ U0TCTL_ /* USART 0 Transmit Control */
#define URCTL0_ U0RCTL_ /* USART 0 Receive Control */
#define UMCTL0_ U0MCTL_ /* USART 0 Modulation Control */
#define UBR00_ U0BR0_ /* USART 0 Baud Rate 0 */
#define UBR10_ U0BR1_ /* USART 0 Baud Rate 1 */
#define RXBUF0_ U0RXBUF_ /* USART 0 Receive Buffer */
#define TXBUF0_ U0TXBUF_ /* USART 0 Transmit Buffer */
#define UCTL_0 U0CTL /* USART 0 Control */
#define UTCTL_0 U0TCTL /* USART 0 Transmit Control */
#define URCTL_0 U0RCTL /* USART 0 Receive Control */
#define UMCTL_0 U0MCTL /* USART 0 Modulation Control */
#define UBR0_0 U0BR0 /* USART 0 Baud Rate 0 */
#define UBR1_0 U0BR1 /* USART 0 Baud Rate 1 */
#define RXBUF_0 U0RXBUF /* USART 0 Receive Buffer */
#define TXBUF_0 U0TXBUF /* USART 0 Transmit Buffer */
#define UCTL_0_ U0CTL_ /* USART 0 Control */
#define UTCTL_0_ U0TCTL_ /* USART 0 Transmit Control */
#define URCTL_0_ U0RCTL_ /* USART 0 Receive Control */
#define UMCTL_0_ U0MCTL_ /* USART 0 Modulation Control */
#define UBR0_0_ U0BR0_ /* USART 0 Baud Rate 0 */
#define UBR1_0_ U0BR1_ /* USART 0 Baud Rate 1 */
#define RXBUF_0_ U0RXBUF_ /* USART 0 Receive Buffer */
#define TXBUF_0_ U0TXBUF_ /* USART 0 Transmit Buffer */
* WATCHDOG TIMER
#define __MSP430_HAS_WDT__ /* Definition to show that Module is available */
SFR_16BIT(WDTCTL); /* Watchdog Timer Control */
/* The bit names have been prefixed with "WDT" */
#define WDTIS0 (0x0001)
#define WDTIS1 (0x0002)
#define WDTSSEL (0x0004)
#define WDTCNTCL (0x0008)
#define WDTTMSEL (0x0010)
#define WDTNMI (0x0020)
#define WDTNMIES (0x0040)
#define WDTHOLD (0x0080)
#define WDTPW (0x5A00)
/* WDT-interval times [1ms] coded with Bits 0-2 */
/* WDT is clocked by fSMCLK (assumed 1MHz) */
#define WDT_MDLY_32 (WDTPW+WDTTMSEL+WDTCNTCL) /* 32ms interval (default) */
#define WDT_MDLY_8 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS0) /* 8ms " */
#define WDT_MDLY_0_5 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1) /* 0.5ms " */
#define WDT_MDLY_0_064 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */
/* WDT is clocked by fACLK (assumed 32KHz) */
#define WDT_ADLY_1000 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL) /* 1000ms " */
#define WDT_ADLY_250 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */
#define WDT_ADLY_16 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */
#define WDT_ADLY_1_9 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */
/* Watchdog mode -> reset after expired time */
#define WDT_MRST_32 (WDTPW+WDTCNTCL) /* 32ms interval (default) */
#define WDT_MRST_8 (WDTPW+WDTCNTCL+WDTIS0) /* 8ms " */
#define WDT_MRST_0_5 (WDTPW+WDTCNTCL+WDTIS1) /* 0.5ms " */
#define WDT_MRST_0_064 (WDTPW+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */
#define WDT_ARST_1000 (WDTPW+WDTCNTCL+WDTSSEL) /* 1000ms " */
#define WDT_ARST_250 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */
#define WDT_ARST_16 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */
#define WDT_ARST_1_9 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */
/* INTERRUPT CONTROL */
/* These two bits are defined in the Special Function Registers */
/* #define WDTIE 0x01 */
/* #define WDTIFG 0x01 */
* Calibration Data in Info Mem
#ifndef __DisableCalData
SFR_8BIT(CALDCO_12MHZ); /* DCOCTL Calibration Data for 12MHz */
SFR_8BIT(CALBC1_12MHZ); /* BCSCTL1 Calibration Data for 12MHz */
SFR_8BIT(CALDCO_8MHZ); /* DCOCTL Calibration Data for 8MHz */
SFR_8BIT(CALBC1_8MHZ); /* BCSCTL1 Calibration Data for 8MHz */
#endif /* #ifndef __DisableCalData */
* Interrupt Vectors (offset from 0xFFE0)
#define VECTOR_NAME(name) name##_ptr
#define EMIT_PRAGMA(x) _Pragma(#x)
#define CREATE_VECTOR(name) void (* const VECTOR_NAME(name))(void) = &name
#define PLACE_VECTOR(vector,section) EMIT_PRAGMA(DATA_SECTION(vector,section))
#define ISR_VECTOR(func,offset) CREATE_VECTOR(func); \
PLACE_VECTOR(VECTOR_NAME(func), offset)
#define PORT2_VECTOR ".int01" /* 0xFFE2 Port 2 */
#else
#define PORT2_VECTOR (1 * 1u) /* 0xFFE2 Port 2 */
#endif
#define PORT1_VECTOR ".int04" /* 0xFFE8 Port 1 */
#else
#define PORT1_VECTOR (4 * 1u) /* 0xFFE8 Port 1 */
#endif
#define TIMERA1_VECTOR ".int05" /* 0xFFEA Timer A CC1, TA */
#else
#define TIMERA1_VECTOR (5 * 1u) /* 0xFFEA Timer A CC1, TA */
#endif
#define TIMERA0_VECTOR ".int06" /* 0xFFEC Timer A CC0 */
#else
#define TIMERA0_VECTOR (6 * 1u) /* 0xFFEC Timer A CC0 */
#endif
#define USART0TX_VECTOR ".int08" /* 0xFFF0 USART 0 Transmit */
#else
#define USART0TX_VECTOR (8 * 1u) /* 0xFFF0 USART 0 Transmit */
#endif
#define USART0RX_VECTOR ".int09" /* 0xFFF2 USART 0 Receive */
#else
#define USART0RX_VECTOR (9 * 1u) /* 0xFFF2 USART 0 Receive */
#endif
#define WDT_VECTOR ".int10" /* 0xFFF4 Watchdog Timer */
#else
#define WDT_VECTOR (10 * 1u) /* 0xFFF4 Watchdog Timer */
#endif
#define SD24_VECTOR ".int12" /* 0xFFF8 Sigma Delta ADC */
#else
#define SD24_VECTOR (12 * 1u) /* 0xFFF8 Sigma Delta ADC */
#endif
#define NMI_VECTOR ".int14" /* 0xFFFC Non-maskable */
#else
#define NMI_VECTOR (14 * 1u) /* 0xFFFC Non-maskable */
#endif
#define RESET_VECTOR ".reset" /* 0xFFFE Reset [Highest Priority] */
#else
#define RESET_VECTOR (15 * 1u) /* 0xFFFE Reset [Highest Priority] */
#endif
* End of Modules
#ifdef __cplusplus
#endif /* extern "C" */
#endif /* #ifndef __MSP430AFE253 */
