5529 BSL升级代码
5529 BSL代码中发送密码的疑问,
如果第一次密码发送失败,就会擦除flash(密码也恢复到默认?),  然后再用默认密码(这个时候密码就对了?).
如果是这样,就可以轻易把密码绕过了
 // Send Password... Causes mass erase if password is wrong!
  reply = BSL_RX_Password(pass);
  if(reply)
    // Wrong password provided.
    // Memory is being mass erased. Setting a 1sec delay.
    *massErased = true;
    worker->ReportProgress(5,"Mass erase occured!\r\n");
    Sleep(2000);
 // Memory is blank now. Re-send blank password to access device.
 reply = BSL_RX_Password(blankPass);
    if(reply)
      worker->ReportProgress(10,"Password FAILED!\r\n");
      e->Result = false;
      return false;
  worker->ReportProgress(10,"Password Sent Successfully\r\n");
  • TI 技术支持没人看看这个问题嘛?
  • li dong 说:
    5529 BSL代码中发送密码的疑问,
    如果是这样,就可以轻易把密码绕过了
      if(reply)
        *massErased = true;
        Sleep(2000);
        if(reply)
          e->Result = false;
          return false;
    擦除掉代码的MCU就没什么保密的需要了啊
  • 然后重新烧录的时候,密码是如何烧录的?
