Other Parts Discussed in Thread: MSP430FR6989
1、硬件平台:MSP430FR6989
2、编译环境:IAR7.10
3、目前处在项目开发阶段,第一次使用MSP430系列单片机;
4、项目背景介绍
通过串口连接GSM模块,实现一个自动上报数据的功能,程序包括:定时器A0 100毫秒中断、串口A0与GSM模块通信接收中断,主循环主要是发送AT命令给串口0,串口1应用打印调试信息;波特率为115200;每个40秒发送一次AT命令,每个1小时上报数据,使用AT命令上报数据
5、问题描述:每隔1小时34分左右单板自动重启,如何定位问题?下面是map文件,无法上传附件,把内容贴上,怀疑堆栈溢出,这个修改了堆栈大小到1024,之前为160,1024正在测试中;
Warning[w6]: Type conflict for external/entry "LedFlash", in module message against external/entry in module main; prototyped function vs K&R function
/* In module message: */
/* K&R Function, args 0, attr 0 */
int (__cc_version2 LedFlash)();
/* In module main: */
/* Function, args 1, attr 0 */
void (__cc_version2 LedFlash)(u8);
typedef unsigned char u8;
Warning[w6]: Type conflict for external/entry "gSystemTick", in module atchannel against external/entry in module main; types have different type attributes
/* In module atchannel: */
u32 gSystemTick;
typedef unsigned long u32;
u32 volatile gSystemTick;
Warning[w6]: Type conflict for external/entry "InitSysParam", in module main against external/entry in module sysparam; prototyped function vs K&R function
int (__cc_version2 InitSysParam)();
/* In module sysparam: */
/* Function, args 0, attr 0 */
s32 (__cc_version2 InitSysParam)(void);
typedef long s32;
# IAR Universal Linker V6.5.0.91 #
# Link time = 23/Aug/2017 09:09:44 #
# Target CPU = MSP430 #
# List file = E:\Project.ext\智能水表\trunk\software\FR6989_ZNS #
# B_RXLOOP\Debug\List\znsb_iar710_fr6989.map #
# Output file 1 = E:\Project.ext\智能水表\trunk\software\FR6989_ZNS #
# B_RXLOOP\Debug\Exe\znsb_iar710_fr6989.d43 #
# Format: ubrof10 #
# UBROF version 10.0.6 #
# Using library modules for C-SPY (-rt) #
# Command line = -f #
# C:\Users\ADMINI~1\AppData\Local\Temp\EW2565.tmp #
# (E:\Project.ext\智能水表\trunk\software\FR6989_ZN #
# SB_RXLOOP\Debug\Obj\atchannel.r43 #
# E:\Project.ext\智能水表\trunk\software\FR6989_ZNS #
# B_RXLOOP\Debug\Obj\crc.r43 #
# B_RXLOOP\Debug\Obj\debug.r43 #
# B_RXLOOP\Debug\Obj\main.r43 #
# B_RXLOOP\Debug\Obj\message.r43 #
# B_RXLOOP\Debug\Obj\queue.r43 #
# B_RXLOOP\Debug\Obj\sysparam.r43 #
# B_RXLOOP\Debug\Obj\timedelay.r43 #
# B_RXLOOP\Debug\Obj\timer.r43 #
# B_RXLOOP\Debug\Obj\timer_a.r43 #
# -o #
# -l #
# -xms #
# "-IC:\Program Files (x86)\IAR Systems\Embedded Wo #
# rkbench 8.0\430\LIB\" #
# -f #
# "C:\Program Files (x86)\IAR Systems\Embedded Work #
# bench 8.0\430\config\linker\lnk430fr6989.xcl" #
# (-cmsp430 -QCODE_I=CODE_ID -QTLS16_I=TLS16_ID #
# -D__iar_HWMUL=4C0 -Z(CONST)INFO=1800-19FF #
# -Z(CONST)INFOA=1980-19FF #
# -Z(CONST)INFOB=1900-197F #
# -Z(CONST)INFOC=1880-18FF #
# -Z(CONST)INFOD=1800-187F #
# -Z(DATA)TINYRAM=0006-001F #
# -Z(DATA)DATA16_I,DATA16_Z,DATA16_N,TLS16_I=1C00-2 #
# 3FF #
# -Z(DATA)CODE_I #
# -Z(DATA)DATA20_I,DATA20_Z,DATA20_N #
# -Z(DATA)CSTACK+_STACK_SIZE# #
# -Z(CONST)DATA16_P,DATA20_P=4400-FF7F #
# -Z(DATA)DATA16_HEAP+_DATA16_HEAP_SIZE #
# -Z(DATA)DATA20_HEAP+_DATA20_HEAP_SIZE #
# -Z(CONST)MPU_B1 -Z(CONST)IPE_B1=4400-FF7F #
# -Z(DATA)IPEDATA16_N -Z(CODE)IPECODE16 #
# -Z(CONST)IPEDATA16_C,IPE_B2 -Z(CONST)MPU_B2 #
# -Z(CONST)DATA16_C,DATA16_ID,TLS16_ID,DIFUNCT,CHEC #
# KSUM=4400-FF7F #
# -Z(CODE)CSTART,ISR_CODE,CODE16=4400-FF7F #
# -P(CODE)CODE=4400-FF7F,10000-23FFF #
# -Z(CODE)CODE_PAD #
# -Z(CONST)DATA20_C,DATA20_ID,CODE_ID=4400-FF7F,100 #
# 40-23FFF #
# -Z(CONST)SIGNATURE=FF80-FF8F #
# -Z(CONST)JTAGSIGNATURE=FF80-FF83 #
# -Z(CONST)BSLSIGNATURE=FF84-FF87 #
# -Z(CONST)IPESIGNATURE=FF88-FF8F #
# -Z(CODE)INTVEC=FF90-FFFF #
# -Z(CODE)RESET=FFFE-FFFF) -f #
# bench 8.0\430\config\linker\multiplier32.xcl" #
# (-e?Mul8Hw=?Mul8 -e?Mul16Hw=?Mul16 #
# -e?Mul16to32uHw=?Mul16to32u #
# -e?Mul16to32sHw=?Mul16to32s -e?Mul32Hw32=?Mul32 #
# -e?Mul64Hw32=_Mul64i #
# -e?Mul32u32uto64iHw32=_Mul32u32uto64i #
# -e?Mul32fHw32=_Mul32f #
# -e_Mul64fHw32Ptr=_Mul64fPtr) -D_STACK_SIZE=400 #
# -rt #
# bench 8.0\430\lib\dlib\dl430xlsfn.r43" #
# -D_DATA16_HEAP_SIZE=A0 -s __program_start #
# -D_DATA20_HEAP_SIZE=50 --enable_stack_usage #
# --call_graph #
# B_RXLOOP\Debug\List\znsb_iar710_fr6989.call_graph #
# .cgx) #
# Copyright (C) 1987-2016 IAR Systems AB. #
* CROSS REFERENCE *
Program entry at : 4A04 Relocatable, from module : ?cstart
* RUNTIME MODEL *
__Heap_Handler = Basic
__SystemLibrary = DLib
__code_model = large
__core = 430X
__data_model = small
__dlib_file_descriptor = 0
__dlib_full_locale_support = 0
__double_size = 32
__pic = no
__reg_r4 = free
__reg_r5 = free
__rt_version = 3
* AUTOMATIC SYMBOL REDIRECTIONS *
All references to: _Printf
were redirected to: _PrintfLargeNoMb
* MODULE MAP *
DEFINED ABSOLUTE ENTRIES
PROGRAM MODULE, NAME : ?ABS_ENTRY_MOD
Absolute parts
ENTRY ADDRESS REF BY
_DATA20_HEAP_SIZE 0050
_DATA16_HEAP_SIZE 00A0
_STACK_SIZE 0400
__iar_HWMUL 04C0 ?Mul16to32sHw (?Mul16to32sHw)
?Mul32Hw32 (?Mul32Hw32)
?Mul32fHw32 (?Mul32fHw32)
Segment part 1 (?Mul8Hw)
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\atchannel.r43
PROGRAM MODULE, NAME : atchannel
SEGMENTS IN THE MODULE
DATA16_AN
Relative segment, address: 05CE - 05CF (0x2 bytes), align: 0
Segment part 1. ROOT Intra module refs: Send_Byte
_A_UCA0TXBUF 05CE
LOCAL ADDRESS
UCA0TXBUF 05CE
UCA0TXBUF_H 05CF
UCA0TXBUF_L 05CE
UCA0TXBUF__SPI 05CE
DATA16_AN
Relative segment, address: 05DC - 05DD (0x2 bytes), align: 0
Segment part 2. ROOT Intra module refs: Send_Byte
USCI_A0_ISR (main)
_A_UCA0IFG 05DC
LOCAL ADDRESS
UCA0IFG 05DC
UCA0IFG_H 05DD
UCA0IFG_L 05DC
UCA0IFG__SPI 05DC
UCA0IFG__SPI_bit 05DC
UCA0IFG__UART 05DC
UCA0IFG__UART_bit 05DC
DATA16_AN
Relative segment, address: 05E0 - 05E1 (0x2 bytes), align: 0
Segment part 3. ROOT Intra module refs: InitUart1 (main)
Send_ByteJS
_A_UCA1CTLW0 05E0
LOCAL ADDRESS
UCA1CTL0 05E1
UCA1CTL0__SPI 05E1
UCA1CTL1 05E0
UCA1CTL1__SPI 05E0
UCA1CTLW0 05E0
UCA1CTLW0_H 05E1
UCA1CTLW0_L 05E0
UCA1CTLW0__SPI 05E0
UCA1CTLW0__SPI_bit 05E0
UCA1CTLW0_bit 05E0
DATA16_AN
Relative segment, address: 05EE - 05EF (0x2 bytes), align: 0
Segment part 4. ROOT Intra module refs: Send_ByteJS
_A_UCA1TXBUF 05EE
LOCAL ADDRESS
UCA1TXBUF 05EE
UCA1TXBUF_H 05EF
UCA1TXBUF_L 05EE
UCA1TXBUF__SPI 05EE
DATA16_AN
Relative segment, address: 05FC - 05FD (0x2 bytes), align: 0
Segment part 5. ROOT Intra module refs: Send_ByteJS
USCI_A1_ISR (main)
_A_UCA1IFG 05FC
LOCAL ADDRESS
UCA1IFG 05FC
UCA1IFG_H 05FD
UCA1IFG_L 05FC
UCA1IFG__SPI 05FC
UCA1IFG__SPI_bit 05FC
UCA1IFG__UART 05FC
UCA1IFG__UART_bit 05FC
DATA16_Z
Relative segment, address: 1CA8 - 1CA8 (0x1 bytes), align: 0
Segment part 83. Intra module refs: AtCmdHandle
AtCmdSend
AtModuleGetCurState
AtModuleStateMachine
AtStateInit
AtUdpSend
LOCAL ADDRESS
s_CurrentState 1CA8
DATA16_Z
Relative segment, address: 1CA9 - 1CA9 (0x1 bytes), align: 0
Segment part 84. Intra module refs: AtStateInit
LOCAL ADDRESS
s_PrevState 1CA9
DATA16_Z
Relative segment, address: 1CAA - 1CAA (0x1 bytes), align: 0
Segment part 85. Intra module refs: AtModuleConnectWithServer
AtModuleState__UdpTransfer
LOCAL ADDRESS
s_DoOnlyOnce 1CAA
DATA16_Z
Relative segment, address: 1CAB - 1CAD (0x3 bytes), align: 0
Segment part 86. Intra module refs: QueueIPDData
LOCAL ADDRESS
s_IpdLen 1CAB
DATA16_Z
Relative segment, address: 1CAE - 1CAE (0x1 bytes), align: 0
Segment part 87. Intra module refs: QueueIPDData
LOCAL ADDRESS
s_Isize 1CAE
DATA16_Z
Relative segment, address: 1CAF - 1CB9 (0xb bytes), align: 0
Segment part 88. Intra module refs: AtStateInit
LOCAL ADDRESS
s_StateQueue 1CAF
DATA16_Z
Relative segment, address: 1C12 - 1C13 (0x2 bytes), align: 1
Segment part 89. Intra module refs: AtCmdHandle
AtModuleState__Null
AtStateInit
AtUdpSend
sp_Queue 1C12 MsgReceive (message)
<CODE> 1 (was CODE)
Relative segment, address: 85B8 - 85CB (0x14 bytes), align: 1
Segment part 90. Intra module refs: AtStateInit
AtCmdParamZero 85B8
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 84D2 - 84EF (0x1e bytes), align: 1
Segment part 92. Intra module refs: AtUdpSend
SendStrs
LOCAL ADDRESS
Send_Byte 84D2
<CODE> 1 (was CODE)
Relative segment, address: 8434 - 8453 (0x20 bytes), align: 1
Segment part 93. Intra module refs: AtCmdSend
AtUdpSend
SendStrs 8434
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7AC8 - 7B47 (0x80 bytes), align: 1
Segment part 94.
Send_ByteJS 7AC8 printu (debug)
<CODE> 1 (was CODE)
Relative segment, address: 722A - 72FF (0xd6 bytes), align: 1
Segment part 96. Intra module refs: AtUdpSend
DumpHex 722A MsgReceive (message)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 86D2 - 86E1 (0x10 bytes), align: 1
Segment part 97. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
AtModuleState__Null 86D2
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 76C2 - 775D (0x9c bytes), align: 1
Segment part 106. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
AtModuleState__Init 76C2
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 8356 - 837F (0x2a bytes), align: 1
Segment part 107. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
AtModuleState__Searching
8356
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 874C - 8751 (0x6 bytes), align: 1
Segment part 108. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
AtModuleState__SimNotready
874C
<CODE> 1 (was CODE)
Relative segment, address: 7C32 - 7C91 (0x60 bytes), align: 1
Segment part 109. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
AtModuleState__RegisterGprs
7C32
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7C92 - 7CE9 (0x58 bytes), align: 1
Segment part 110. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
AtModuleState__PdpAct 7C92
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7FA6 - 7FEB (0x46 bytes), align: 1
Segment part 111. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
AtModuleState__PdpActErr
7FA6
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 8574 - 858B (0x18 bytes), align: 1
Segment part 112. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
AtModuleState__UdpTransferRetry
8574
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 791E - 79AD (0x90 bytes), align: 1
Segment part 113. Intra module refs: TimerEventCallBackFunc
791E
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7300 - 73D3 (0xd4 bytes), align: 1
Segment part 114. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
7300
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7E36 - 7E83 (0x4e bytes), align: 1
Segment part 115. Intra module refs: AtModuleStateMachine
LOCAL ADDRESS
DumpState 7E36
<CODE> 1 (was CODE)
Relative segment, address: 79AE - 7A3B (0x8e bytes), align: 1
Segment part 116.
AtModuleStateMachine 79AE main (main)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7FEC - 8031 (0x46 bytes), align: 1
Segment part 117.
AtSerialPortRx 7FEC USCI_A0_ISR (main)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 5E58 - 603B (0x1e4 bytes), align: 1
Segment part 118.
AtUdpSend 5E58 MsgSend (message)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 67F2 - 6939 (0x148 bytes), align: 1
Segment part 119. Intra module refs: iAppRegisterTimer
LOCAL ADDRESS
67F2
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 8494 - 84B3 (0x20 bytes), align: 1
Segment part 120.
iAppRegisterTimer 8494 main (main)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 80F0 - 812B (0x3c bytes), align: 1
Segment part 105. Intra module refs: AtModuleState__Init
AtCmdSend_ErrorRetry 80F0
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 6A6A - 6B87 (0x11e bytes), align: 1
Segment part 104. Intra module refs: AtCmdSend_ErrorRetry
AtModuleState__Init
AtCmdSend 6A6A
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 8752 - 8757 (0x6 bytes), align: 1
Segment part 121. Intra module refs: TimerEventCallBackFunc
AtModuleGetCurState 8752 TIMER0_A0_ISR (main)
main (main)
<CODE> 1 (was CODE)
Relative segment, address: 6202 - 638B (0x18a bytes), align: 1
Segment part 123. Intra module refs: AtCmdHandle
QueueStrs 6202
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 6E9E - 6F8F (0xf2 bytes), align: 1
Segment part 98. Intra module refs: AtCmdHandle
QueueIPDData 6E9E
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 8454 - 8473 (0x20 bytes), align: 1
Segment part 101. Intra module refs: AtCmdHandle
QueueSetFront 8454
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 832A - 8355 (0x2c bytes), align: 1
Segment part 102. Intra module refs: AtCmdHandle
QueueSetNextFrame 832A
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7BC8 - 7C31 (0x6a bytes), align: 1
Segment part 99. Intra module refs: AtCmdHandle
ObtainCsq 7BC8
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7ED0 - 7F19 (0x4a bytes), align: 1
Segment part 124.
SysTimeIncreament 7ED0 main (main)
<CODE> 1 (was CODE)
Relative segment, address: 6DAA - 6E9D (0xf4 bytes), align: 1
Segment part 100. Intra module refs: AtCmdHandle
ObtainSysTime 6DAA
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 56C4 - 5A1B (0x358 bytes), align: 1
Segment part 103. Intra module refs: AtCmdSend
AtCmdHandle 56C4 TIMER0_A0_ISR (main)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 823E - 826F (0x32 bytes), align: 1
Segment part 126.
AtStateInit 823E main (main)
calls direct
DATA16_C
Relative segment, address: 4400 - 4403 (0x4 bytes), align: 0
Segment part 7. Intra module refs: DumpHex
DATA16_C
Relative segment, address: 4404 - 4406 (0x3 bytes), align: 0
Segment part 8. Intra module refs: AtCmdSend
DumpHex
DATA16_C
Relative segment, address: 4407 - 4409 (0x3 bytes), align: 0
Segment part 9. Intra module refs: DumpHex
DATA16_C
Relative segment, address: 440A - 440D (0x4 bytes), align: 0
Segment part 10. Intra module refs: DumpHex
DATA16_C
Relative segment, address: 440E - 4410 (0x3 bytes), align: 0
Segment part 11. Intra module refs: DumpHex
DATA16_C
Relative segment, address: 4411 - 4414 (0x4 bytes), align: 0
Segment part 12. Intra module refs: DumpHex
DATA16_C
Relative segment, address: 4415 - 4417 (0x3 bytes), align: 0
Segment part 13. Intra module refs: AtModuleState__Init
DATA16_C
Relative segment, address: 4418 - 441C (0x5 bytes), align: 0
Segment part 14. Intra module refs: AtModuleState__Init
DATA16_C
Relative segment, address: 441D - 4426 (0xa bytes), align: 0
Segment part 15. Intra module refs: AtModuleState__Init
DATA16_C
Relative segment, address: 4427 - 442A (0x4 bytes), align: 0
Segment part 16. Intra module refs: AtModuleState__Init
DATA16_C
Relative segment, address: 442B - 4433 (0x9 bytes), align: 0
Segment part 17. Intra module refs: AtModuleState__Init
DATA16_C
Relative segment, address: 4434 - 443A (0x7 bytes), align: 0
Segment part 18. Intra module refs: AtModuleState__Searching
DATA16_C
Relative segment, address: 443B - 4444 (0xa bytes), align: 0
Segment part 19. Intra module refs: AtModuleState__Searching
DATA16_C
Relative segment, address: 4445 - 444F (0xb bytes), align: 0
Segment part 20. Intra module refs: AtModuleState__PdpActErr
DATA16_C
Relative segment, address: 4450 - 445B (0xc bytes), align: 0
Segment part 21. Intra module refs: AtModuleState__RegisterGprs
DATA16_C
Relative segment, address: 445C - 446F (0x14 bytes), align: 0
Segment part 22. Intra module refs: AtModuleState__RegisterGprs
DATA16_C
Relative segment, address: 4470 - 447B (0xc bytes), align: 0
Segment part 23. Intra module refs: AtModuleState__RegisterGprs
DATA16_C
Relative segment, address: 447C - 4484 (0x9 bytes), align: 0
Segment part 24. Intra module refs: AtModuleState__RegisterGprs
DATA16_C
Relative segment, address: 4485 - 448F (0xb bytes), align: 0
Segment part 25. Intra module refs: AtModuleState__PdpAct
DATA16_C
Relative segment, address: 4490 - 449B (0xc bytes), align: 0
Segment part 26. Intra module refs: AtModuleState__PdpAct
DATA16_C
Relative segment, address: 449C - 44A8 (0xd bytes), align: 0
Segment part 27. Intra module refs: AtModuleState__PdpAct
DATA16_C
Relative segment, address: 44A9 - 44D1 (0x29 bytes), align: 0
Segment part 28. Intra module refs: AtModuleState__PdpAct
DATA16_C
Relative segment, address: 44D2 - 44DB (0xa bytes), align: 0
Segment part 29. Intra module refs: AtModuleState__PdpActErr
DATA16_C
Relative segment, address: 44DC - 44E6 (0xb bytes), align: 0
Segment part 30. Intra module refs: AtModuleState__PdpActErr
DATA16_C
Relative segment, address: 44E7 - 44EB (0x5 bytes), align: 0
Segment part 31. Intra module refs: DumpState
DATA16_C
Relative segment, address: 44EC - 44F0 (0x5 bytes), align: 0
Segment part 32. Intra module refs: DumpState
DATA16_C
Relative segment, address: 44F1 - 44FA (0xa bytes), align: 0
Segment part 33. Intra module refs: DumpState
DATA16_C
Relative segment, address: 44FB - 4508 (0xe bytes), align: 0
Segment part 34. Intra module refs: DumpState
DATA16_C
Relative segment, address: 4509 - 4516 (0xe bytes), align: 0
Segment part 35. Intra module refs: DumpState
DATA16_C
Relative segment, address: 4517 - 451E (0x8 bytes), align: 0
Segment part 36. Intra module refs: DumpState
DATA16_C
Relative segment, address: 451F - 4522 (0x4 bytes), align: 0
Segment part 37. Intra module refs: DumpState
DATA16_C
Relative segment, address: 4523 - 4529 (0x7 bytes), align: 0
Segment part 38. Intra module refs: DumpState
DATA16_C
Relative segment, address: 452A - 4541 (0x18 bytes), align: 0
Segment part 39. Intra module refs: AtModuleStateMachine
DATA16_C
Relative segment, address: 4542 - 4547 (0x6 bytes), align: 0
Segment part 40. Intra module refs: AtSerialPortRx
DATA16_C
Relative segment, address: 4548 - 4562 (0x1b bytes), align: 0
Segment part 41. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 4563 - 4571 (0xf bytes), align: 0
Segment part 42. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 4572 - 4580 (0xf bytes), align: 0
Segment part 43. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 4581 - 458F (0xf bytes), align: 0
Segment part 44. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 4590 - 459E (0xf bytes), align: 0
Segment part 45. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 459F - 45AD (0xf bytes), align: 0
Segment part 46. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 45AE - 45BC (0xf bytes), align: 0
Segment part 47. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 45BD - 45CB (0xf bytes), align: 0
Segment part 48. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 45CC - 45E2 (0x17 bytes), align: 0
Segment part 49. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 45E3 - 4603 (0x21 bytes), align: 0
Segment part 50. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 4604 - 4621 (0x1e bytes), align: 0
Segment part 51. Intra module refs: AtUdpSend
DATA16_C
Relative segment, address: 4622 - 462A (0x9 bytes), align: 0
Segment part 52. Intra module refs: TimerEventCallBackFunc
DATA16_C
Relative segment, address: 462B - 4645 (0x1b bytes), align: 0
Segment part 53. Intra module refs: AtCmdSend
DATA16_C
Relative segment, address: 4646 - 4649 (0x4 bytes), align: 0
Segment part 54. Intra module refs: AtCmdSend
DATA16_C
Relative segment, address: 464A - 4651 (0x8 bytes), align: 0
Segment part 55. Intra module refs: AtCmdSend
DATA16_C
Relative segment, address: 4652 - 465E (0xd bytes), align: 0
Segment part 56. Intra module refs: AtCmdSend
DATA16_C
Relative segment, address: 465F - 466B (0xd bytes), align: 0
Segment part 58. Intra module refs: ObtainCsq
DATA16_C
Relative segment, address: 466C - 467D (0x12 bytes), align: 0
Segment part 60. Intra module refs: ObtainSysTime
DATA16_C
Relative segment, address: 467E - 4681 (0x4 bytes), align: 0
Segment part 61. Intra module refs: ObtainSysTime
DATA16_C
Relative segment, address: 4682 - 4685 (0x4 bytes), align: 0
Segment part 62. Intra module refs: ObtainSysTime
DATA16_C
Relative segment, address: 4686 - 468B (0x6 bytes), align: 0
Segment part 63. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 468C - 4691 (0x6 bytes), align: 0
Segment part 64. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 4692 - 4699 (0x8 bytes), align: 0
Segment part 65. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 469A - 46A4 (0xb bytes), align: 0
Segment part 66. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46A5 - 46A7 (0x3 bytes), align: 0
Segment part 67. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46A8 - 46AD (0x6 bytes), align: 0
Segment part 68. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46AE - 46B2 (0x5 bytes), align: 0
Segment part 69. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46B3 - 46BD (0xb bytes), align: 0
Segment part 70. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46BE - 46C8 (0xb bytes), align: 0
Segment part 71. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46C9 - 46D1 (0x9 bytes), align: 0
Segment part 72. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46D2 - 46D5 (0x4 bytes), align: 0
Segment part 73. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46D6 - 46DB (0x6 bytes), align: 0
Segment part 74. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46DC - 46E3 (0x8 bytes), align: 0
Segment part 75. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46E4 - 46E7 (0x4 bytes), align: 0
Segment part 76. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46E8 - 46ED (0x6 bytes), align: 0
Segment part 77. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46EE - 46F4 (0x7 bytes), align: 0
Segment part 78. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46F5 - 46FA (0x6 bytes), align: 0
Segment part 79. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46FB - 46FE (0x4 bytes), align: 0
Segment part 80. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 46FF - 470B (0xd bytes), align: 0
Segment part 81. Intra module refs: AtCmdHandle
DATA16_C
Relative segment, address: 470C - 470D (0x2 bytes), align: 0
Segment part 82. Intra module refs: AtCmdHandle
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\crc.r43
PROGRAM MODULE, NAME : crc
DATA16_C
Relative segment, address: 470E - 480D (0x100 bytes), align: 0
Segment part 2. Intra module refs: calcCrc8
crc8_tab 470E
<CODE> 1 (was CODE)
Relative segment, address: 82D0 - 82FD (0x2e bytes), align: 1
Segment part 3.
calcCrc8 82D0 MsgSend (message)
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\debug.r43
PROGRAM MODULE, NAME : debug
<CODE> 1 (was CODE)
Relative segment, address: 77F6 - 788B (0x96 bytes), align: 1
Segment part 3. Intra module refs: printu
itoa 77F6
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7154 - 7229 (0xd6 bytes), align: 1
Segment part 4.
printu 7154 AtCmdSend (atchannel)
AtModuleStateMachine (atchannel)
AtSerialPortRx (atchannel)
AtUdpSend (atchannel)
DeQueue (queue)
DumpHex (atchannel)
HandleTimerEvents (timer)
ModTimer (timer)
MsgSend (message)
ObtainCsq (atchannel)
ObtainSysTime (atchannel)
StartTimer (timer)
main (main)
calls direct
DATA16_C
Relative segment, address: 480E - 4832 (0x25 bytes), align: 0
Segment part 2. Intra module refs: itoa
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\main.r43
PROGRAM MODULE, NAME : main
DATA16_AN
Relative segment, address: 0160 - 0161 (0x2 bytes), align: 0
Segment part 1. ROOT Intra module refs: InitClock_8MHz
_A_CSCTL0 0160
LOCAL ADDRESS
CSCTL0 0160
CSCTL0_H 0161
CSCTL0_L 0160
DATA16_AN
Relative segment, address: 0162 - 0163 (0x2 bytes), align: 0
Segment part 2. ROOT Intra module refs: InitClock_8MHz
_A_CSCTL1 0162
LOCAL ADDRESS
CSCTL1 0162
CSCTL1_H 0163
CSCTL1_L 0162
CSCTL1_bit 0162
DATA16_AN
Relative segment, address: 0164 - 0165 (0x2 bytes), align: 0
Segment part 3. ROOT Intra module refs: InitClock_8MHz
_A_CSCTL2 0164
LOCAL ADDRESS
CSCTL2 0164
CSCTL2_H 0165
CSCTL2_L 0164
CSCTL2_bit 0164
DATA16_AN
Relative segment, address: 0166 - 0167 (0x2 bytes), align: 0
Segment part 4. ROOT Intra module refs: InitClock_8MHz
_A_CSCTL3 0166
LOCAL ADDRESS
CSCTL3 0166
CSCTL3_H 0167
CSCTL3_L 0166
CSCTL3_bit 0166
DATA16_AN
Relative segment, address: 0130 - 0131 (0x2 bytes), align: 0
Segment part 5. ROOT Intra module refs: main
_A_PM5CTL0 0130
LOCAL ADDRESS
PM5CTL0 0130
PM5CTL0_H 0131
PM5CTL0_L 0130
PM5CTL0_bit 0130
DATA16_AN
Relative segment, address: 0202 - 0203 (0x2 bytes), align: 0
Segment part 6. ROOT Intra module refs: LedEnable
TIMER0_A0_ISR
_A_PAOUT 0202
LOCAL ADDRESS
P1OUT 0202
P1OUT_bit 0202
P2OUT 0203
P2OUT_bit 0203
PAOUT 0202
PAOUT_H 0203
PAOUT_L 0202
PAOUT_bit 0202
DATA16_AN
Relative segment, address: 0204 - 0205 (0x2 bytes), align: 0
Segment part 7. ROOT Intra module refs: Init_GPIO
_A_PADIR 0204
LOCAL ADDRESS
P1DIR 0204
P1DIR_bit 0204
P2DIR 0205
P2DIR_bit 0205
PADIR 0204
PADIR_H 0205
PADIR_L 0204
PADIR_bit 0204
DATA16_AN
Relative segment, address: 020A - 020B (0x2 bytes), align: 0
Segment part 8. ROOT Intra module refs: Init_GPIO
_A_PASEL0 020A
LOCAL ADDRESS
P1SEL0 020A
P1SEL0_bit 020A
P2SEL0 020B
P2SEL0_bit 020B
PASEL0 020A
PASEL0_H 020B
PASEL0_L 020A
PASEL0_bit 020A
DATA16_AN
Relative segment, address: 020C - 020D (0x2 bytes), align: 0
Segment part 9. ROOT Intra module refs: Init_GPIO
_A_PASEL1 020C
LOCAL ADDRESS
P1SEL1 020C
P1SEL1_bit 020C
P2SEL1 020D
P2SEL1_bit 020D
PASEL1 020C
PASEL1_H 020D
PASEL1_L 020C
PASEL1_bit 020C
DATA16_AN
Relative segment, address: 0224 - 0225 (0x2 bytes), align: 0
Segment part 10. ROOT Intra module refs: Init_GPIO
_A_PBDIR 0224
LOCAL ADDRESS
P3DIR 0224
P3DIR_bit 0224
P4DIR 0225
P4DIR_bit 0225
PBDIR 0224
PBDIR_H 0225
PBDIR_L 0224
PBDIR_bit 0224
DATA16_AN
Relative segment, address: 022A - 022B (0x2 bytes), align: 0
Segment part 11. ROOT Intra module refs: InitUart0
InitUart1
Init_GPIO
_A_PBSEL0 022A
LOCAL ADDRESS
P3SEL0 022A
P3SEL0_bit 022A
P4SEL0 022B
P4SEL0_bit 022B
PBSEL0 022A
PBSEL0_H 022B
PBSEL0_L 022A
PBSEL0_bit 022A
DATA16_AN
Relative segment, address: 022C - 022D (0x2 bytes), align: 0
Segment part 12. ROOT Intra module refs: InitUart0
InitUart1
Init_GPIO
_A_PBSEL1 022C
LOCAL ADDRESS
P3SEL1 022C
P3SEL1_bit 022C
P4SEL1 022D
P4SEL1_bit 022D
PBSEL1 022C
PBSEL1_H 022D
PBSEL1_L 022C
PBSEL1_bit 022C
DATA16_AN
Relative segment, address: 0262 - 0263 (0x2 bytes), align: 0
Segment part 13. ROOT Intra module refs: main
_A_PDOUT 0262
LOCAL ADDRESS
P7OUT 0262
P7OUT_bit 0262
P8OUT 0263
P8OUT_bit 0263
PDOUT 0262
PDOUT_H 0263
PDOUT_L 0262
PDOUT_bit 0262
DATA16_AN
Relative segment, address: 0264 - 0265 (0x2 bytes), align: 0
Segment part 14. ROOT Intra module refs: Init_GPIO
_A_PDDIR 0264
LOCAL ADDRESS
P7DIR 0264
P7DIR_bit 0264
P8DIR 0265
P8DIR_bit 0265
PDDIR 0264
PDDIR_H 0265
PDDIR_L 0264
PDDIR_bit 0264
DATA16_AN
Relative segment, address: 026A - 026B (0x2 bytes), align: 0
Segment part 15. ROOT Intra module refs: Init_GPIO
_A_PDSEL0 026A
LOCAL ADDRESS
P7SEL0 026A
P7SEL0_bit 026A
P8SEL0 026B
P8SEL0_bit 026B
PDSEL0 026A
PDSEL0_H 026B
PDSEL0_L 026A
PDSEL0_bit 026A
DATA16_AN
Relative segment, address: 026C - 026D (0x2 bytes), align: 0
Segment part 16. ROOT Intra module refs: Init_GPIO
_A_PDSEL1 026C
LOCAL ADDRESS
P7SEL1 026C
P7SEL1_bit 026C
P8SEL1 026D
P8SEL1_bit 026D
PDSEL1 026C
PDSEL1_H 026D
PDSEL1_L 026C
PDSEL1_bit 026C
DATA16_AN
Relative segment, address: 0284 - 0285 (0x2 bytes), align: 0
Segment part 17. ROOT Intra module refs: Init_GPIO
_A_PEDIR 0284
LOCAL ADDRESS
P10DIR 0285
P10DIR_bit 0285
P9DIR 0284
P9DIR_bit 0284
PEDIR 0284
PEDIR_H 0285
PEDIR_L 0284
PEDIR_bit 0284
DATA16_AN
Relative segment, address: 028A - 028B (0x2 bytes), align: 0
Segment part 18. ROOT Intra module refs: Init_GPIO
_A_PESEL0 028A
LOCAL ADDRESS
P10SEL0 028B
P10SEL0_bit 028B
P9SEL0 028A
P9SEL0_bit 028A
PESEL0 028A
PESEL0_H 028B
PESEL0_L 028A
PESEL0_bit 028A
DATA16_AN
Relative segment, address: 028C - 028D (0x2 bytes), align: 0
Segment part 19. ROOT Intra module refs: Init_GPIO
_A_PESEL1 028C
LOCAL ADDRESS
P10SEL1 028D
P10SEL1_bit 028D
P9SEL1 028C
P9SEL1_bit 028C
PESEL1 028C
PESEL1_H 028D
PESEL1_L 028C
PESEL1_bit 028C
DATA16_AN
Relative segment, address: 0352 - 0353 (0x2 bytes), align: 0
Segment part 20. ROOT Intra module refs: TIMER0_A0_ISR
TA0CCR0 0352
DATA16_AN
Relative segment, address: 05C0 - 05C1 (0x2 bytes), align: 0
Segment part 21. ROOT Intra module refs: InitUart0
_A_UCA0CTLW0 05C0
LOCAL ADDRESS
UCA0CTL0 05C1
UCA0CTL0__SPI 05C1
UCA0CTL1 05C0
UCA0CTL1__SPI 05C0
UCA0CTLW0 05C0
UCA0CTLW0_H 05C1
UCA0CTLW0_L 05C0
UCA0CTLW0__SPI 05C0
UCA0CTLW0__SPI_bit 05C0
UCA0CTLW0_bit 05C0
DATA16_AN
Relative segment, address: 05C6 - 05C7 (0x2 bytes), align: 0
Segment part 22. ROOT Intra module refs: InitUart0
_A_UCA0BRW 05C6
LOCAL ADDRESS
UCA0BR0 05C6
UCA0BR0__SPI 05C6
UCA0BR1 05C7
UCA0BR1__SPI 05C7
UCA0BRW 05C6
UCA0BRW_H 05C7
UCA0BRW_L 05C6
UCA0BRW__SPI 05C6
DATA16_AN
Relative segment, address: 05C8 - 05C9 (0x2 bytes), align: 0
Segment part 23. ROOT Intra module refs: InitUart0
_A_UCA0MCTLW 05C8
LOCAL ADDRESS
UCA0MCTLW 05C8
UCA0MCTLW_H 05C9
UCA0MCTLW_L 05C8
UCA0MCTLW_bit 05C8
DATA16_AN
Relative segment, address: 05CC - 05CD (0x2 bytes), align: 0
Segment part 24. ROOT Intra module refs: USCI_A0_ISR
_A_UCA0RXBUF 05CC
LOCAL ADDRESS
UCA0RXBUF 05CC
UCA0RXBUF_H 05CD
UCA0RXBUF_L 05CC
UCA0RXBUF__SPI 05CC
DATA16_AN
Relative segment, address: 05DA - 05DB (0x2 bytes), align: 0
Segment part 25. ROOT Intra module refs: InitUart0
_A_UCA0IE 05DA
LOCAL ADDRESS
UCA0IE 05DA
UCA0IE_H 05DB
UCA0IE_L 05DA
UCA0IE__SPI 05DA
UCA0IE__SPI_bit 05DA
UCA0IE__UART 05DA
UCA0IE__UART_bit 05DA
DATA16_AN
Relative segment, address: 05E6 - 05E7 (0x2 bytes), align: 0
Segment part 28. ROOT Intra module refs: InitUart1
_A_UCA1BRW 05E6
LOCAL ADDRESS
UCA1BR0 05E6
UCA1BR0__SPI 05E6
UCA1BR1 05E7
UCA1BR1__SPI 05E7
UCA1BRW 05E6
UCA1BRW_H 05E7
UCA1BRW_L 05E6
UCA1BRW__SPI 05E6
DATA16_AN
Relative segment, address: 05E8 - 05E9 (0x2 bytes), align: 0
Segment part 29. ROOT Intra module refs: InitUart1
_A_UCA1MCTLW 05E8
LOCAL ADDRESS
UCA1MCTLW 05E8
UCA1MCTLW_H 05E9
UCA1MCTLW_L 05E8
UCA1MCTLW_bit 05E8
DATA16_AN
Relative segment, address: 05FE - 05FF (0x2 bytes), align: 0
Segment part 31. ROOT Intra module refs: USCI_A1_ISR
_A_UCA1IV 05FE
LOCAL ADDRESS
UCA1IV 05FE
UCA1IV__SPI 05FE
DATA16_Z
Relative segment, address: 1CBA - 1CC9 (0x10 bytes), align: 0
Segment part 45.
g_WaterId 1CBA MsgReceive (message)
MsgSend (message)
SysParamSetDefaultVal (sysparam)
DATA16_Z
Relative segment, address: 1CCA - 1CD1 (0x8 bytes), align: 0
Segment part 46.
g_WaterInfo 1CCA MsgSend (message)
DATA16_Z
Relative segment, address: 1CD2 - 1CE7 (0x16 bytes), align: 0
Segment part 47. Intra module refs: main
g_ReportInfo 1CD2 MsgSend (message)
DATA16_Z
Relative segment, address: 1CE8 - 1D04 (0x1d bytes), align: 0
Segment part 48.
g_Settings 1CE8 AtCmdSend (atchannel)
AtModuleState__PdpAct (atchannel)
AtModuleState__PdpActErr (atchannel)
MsgSend (message)
DATA16_Z
Relative segment, address: 1D05 - 1D0A (0x6 bytes), align: 0
Segment part 49.
g_AlarmInfo 1D05 MsgSend (message)
DATA16_Z
Relative segment, address: 1D0B - 1D4A (0x40 bytes), align: 0
Segment part 50. Intra module refs: main
g_DebugInfo 1D0B
DATA16_Z
Relative segment, address: 1C14 - 1C17 (0x4 bytes), align: 1
Segment part 51. Intra module refs: TIMER0_A0_ISR
main
gSystemTick 1C14 AtCmdSend (atchannel)
MsgSend (message)
DATA16_Z
Relative segment, address: 1D4B - 1D4B (0x1 bytes), align: 0
Segment part 52. Intra module refs: TIMER0_A0_ISR
main
g_SystemCmd 1D4B ObtainSysTime (atchannel)
SysTimeIncreament (atchannel)
DATA16_Z
Relative segment, address: 1D4C - 1DBE (0x73 bytes), align: 0
Segment part 53.
s_AtResponse 1D4C AtCmdHandle (atchannel)
AtCmdParamZero (atchannel)
AtStateInit (atchannel)
DATA16_Z
Relative segment, address: 1C18 - 1C19 (0x2 bytes), align: 1
Segment part 54.
gp_Queue 1C18 AtCmdHandle (atchannel)
DATA16_I
Relative segment, address: 1C04 - 1C10 (0xd bytes), align: 0
Segment part 55. Intra module refs: TIMERA_Init
initUpParam_A0 1C04
ISR_CODE
Relative segment, address: 4A2C - 4A6F (0x44 bytes), align: 1
Segment part 57. Intra module refs: TIMER0_A0_ISR::??INTVEC 88
TIMER0_A0_ISR 4A2C
interrupt function
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 8718 - 8723 (0xc bytes), align: 1
Segment part 60. Intra module refs: main
LOCAL ADDRESS
TIMERA_Init 8718
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7DE6 - 7E35 (0x50 bytes), align: 1
Segment part 61. Intra module refs: main
Init_GPIO 7DE6
<CODE> 1 (was CODE)
Relative segment, address: 8072 - 80B1 (0x40 bytes), align: 1
Segment part 62. Intra module refs: main
InitClock_8MHz 8072
<CODE> 1 (was CODE)
Relative segment, address: 850C - 8527 (0x1c bytes), align: 1
Segment part 63. Intra module refs: main
WDT_A_hold 850C
ISR_CODE
Relative segment, address: 4A70 - 4A8D (0x1e bytes), align: 1
Segment part 58. Intra module refs: USCI_A0_ISR::??INTVEC 94
USCI_A0_ISR 4A70
interrupt function
calls direct
ISR_CODE
Relative segment, address: 4A8E - 4AC1 (0x34 bytes), align: 1
Segment part 59. Intra module refs: USCI_A1_ISR::??INTVEC 84
USCI_A1_ISR 4A8E
interrupt function
<CODE> 1 (was CODE)
Relative segment, address: 86B2 - 86C1 (0x10 bytes), align: 1
Segment part 65. Intra module refs: LedFlash
LedEnable 86B2
<CODE> 1 (was CODE)
Relative segment, address: 7D40 - 7D93 (0x54 bytes), align: 1
Segment part 66.
LedFlash 7D40 MsgSend (message)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7564 - 761F (0xbc bytes), align: 1
Segment part 67. Intra module refs: main
InitUart0 7564
<CODE> 1 (was CODE)
Relative segment, address: 775E - 77F5 (0x98 bytes), align: 1
Segment part 68. Intra module refs: main
InitUart1 775E
<CODE> 1 (was CODE)
Relative segment, address: 603C - 6201 (0x1c6 bytes), align: 1
Segment part 69.
main 603C Segment part 27 (?cstart)
calls direct
INTVEC
Common segment, address: FF90 - FFE5 (0x56 bytes), align: 1
Segment part 32. ROOT
FFE4
INTVEC
Common segment, address: FF90 - FFE9 (0x5a bytes), align: 1
Segment part 33. ROOT
FFE8
INTVEC
Common segment, address: FF90 - FFEF (0x60 bytes), align: 1
Segment part 34. ROOT
FFEE
DATA16_ID
Relative segment, address: 49F6 - 4A02 (0xd bytes), align: 0
Segment part 56. Intra module refs: initUpParam_A0
DATA16_C
Relative segment, address: 4833 - 485C (0x2a bytes), align: 0
Segment part 36. Intra module refs: main
DATA16_C
Relative segment, address: 485D - 488E (0x32 bytes), align: 0
Segment part 37. Intra module refs: main
DATA16_C
Relative segment, address: 488F - 4898 (0xa bytes), align: 0
Segment part 38. Intra module refs: main
DATA16_C
Relative segment, address: 4899 - 48A2 (0xa bytes), align: 0
Segment part 39. Intra module refs: main
DATA16_C
Relative segment, address: 48A3 - 48AB (0x9 bytes), align: 0
Segment part 40. Intra module refs: main
DATA16_C
Relative segment, address: 48AC - 48B0 (0x5 bytes), align: 0
Segment part 41. Intra module refs: main
DATA16_C
Relative segment, address: 48B1 - 48B9 (0x9 bytes), align: 0
Segment part 42. Intra module refs: main
DATA16_C
Relative segment, address: 48BA - 48CB (0x12 bytes), align: 0
Segment part 43. Intra module refs: main
DATA16_C
Relative segment, address: 48CC - 48D5 (0xa bytes), align: 0
Segment part 44. Intra module refs: main
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\message.r43
PROGRAM MODULE, NAME : message
DATA16_Z
Relative segment, address: 1DBF - 1DBF (0x1 bytes), align: 0
Segment part 15. Intra module refs: MsgSend
LOCAL ADDRESS
seq 1DBF
DATA16_Z
Relative segment, address: 1DC0 - 1DDE (0x1f bytes), align: 0
Segment part 16. Intra module refs: MsgSettings__Handle
g_DateBuf 1DC0 AtModuleState__UdpTransfer (atchannel)
DATA16_Z
Relative segment, address: 1DDF - 1E1D (0x3f bytes), align: 0
Segment part 17. Intra module refs: MsgReceive
MsgSend
s_Msg 1DDF
DATA16_Z
Relative segment, address: 1E1E - 1E9D (0x80 bytes), align: 0
Segment part 18.
g_RxMsg 1E1E QueueIPDData (atchannel)
DATA16_Z
Relative segment, address: 1E9E - 1EA4 (0x7 bytes), align: 0
Segment part 19. Intra module refs: MsgReceive
s_ReportTimer 1E9E
DATA16_Z
Relative segment, address: 1EA5 - 1EA8 (0x4 bytes), align: 0
Segment part 20. Intra module refs: MsgSettings__Handle
g_SysTime 1EA5 AtModuleState__UdpTransfer (atchannel)
main (main)
<CODE> 1 (was CODE)
Relative segment, address: 5A1C - 5C53 (0x238 bytes), align: 1
Segment part 21. Intra module refs: MsgReportFlowMeter
MsgSend 5A1C AtModuleConnectWithServer (atchannel)
TimerEventCallBackFunc (atchannel)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7074 - 7153 (0xe0 bytes), align: 1
Segment part 22. Intra module refs: MsgReceive
LOCAL ADDRESS
MsgSettings__Handle 7074
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 6C9E - 6DA9 (0x10c bytes), align: 1
Segment part 24.
MsgReceive 6C9E QueueIPDData (atchannel)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 85A2 - 85B7 (0x16 bytes), align: 1
Segment part 25.
MsgReportFlowMeter 85A2 AtModuleConnectWithServer (atchannel)
main (main)
calls direct
DATA16_C
Relative segment, address: 48D6 - 48E2 (0xd bytes), align: 0
Segment part 2. Intra module refs: MsgSend
DATA16_C
Relative segment, address: 48E3 - 48E5 (0x3 bytes), align: 0
Segment part 3. Intra module refs: MsgSend
DATA16_C
Relative segment, address: 48E6 - 48E9 (0x4 bytes), align: 0
Segment part 4. Intra module refs: MsgSend
DATA16_C
Relative segment, address: 48EA - 4908 (0x1f bytes), align: 0
Segment part 5. Intra module refs: MsgSend
DATA16_C
Relative segment, address: 4909 - 4927 (0x1f bytes), align: 0
Segment part 12. Intra module refs: MsgSettings__Handle
DATA16_C
Relative segment, address: 4928 - 493C (0x15 bytes), align: 0
Segment part 14. Intra module refs: MsgReceive
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\queue.r43
PROGRAM MODULE, NAME : queue
<CODE> 1 (was CODE)
Relative segment, address: 86C2 - 86D1 (0x10 bytes), align: 1
Segment part 5.
InitQueue 86C2 AtStateInit (atchannel)
<CODE> 1 (was CODE)
Relative segment, address: 862A - 863B (0x12 bytes), align: 1
Segment part 6. Intra module refs: DeQueue
QueueFront
QueueEmpty 862A AtCmdHandle (atchannel)
QueueStrs (atchannel)
<CODE> 1 (was CODE)
Relative segment, address: 85F4 - 8605 (0x12 bytes), align: 1
Segment part 7. Intra module refs: EnQueue
QueueFull 85F4
<CODE> 1 (was CODE)
Relative segment, address: 8166 - 819D (0x38 bytes), align: 1
Segment part 8.
EnQueue 8166 AtSerialPortRx (atchannel)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7B48 - 7BC7 (0x80 bytes), align: 1
Segment part 9.
DeQueue 7B48 AtCmdHandle (atchannel)
QueueSetFront (atchannel)
QueueSetNextFrame (atchannel)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 84B4 - 84D1 (0x1e bytes), align: 1
Segment part 10.
QueueFront 84B4 AtCmdHandle (atchannel)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 8672 - 8681 (0x10 bytes), align: 1
Segment part 11.
SInitQueue 8672 AtStateInit (atchannel)
<CODE> 1 (was CODE)
Relative segment, address: 8606 - 8617 (0x12 bytes), align: 1
Segment part 12. Intra module refs: SDeQueue
SQueueEmpty 8606
<CODE> 1 (was CODE)
Relative segment, address: 8692 - 86A1 (0x10 bytes), align: 1
Segment part 13. Intra module refs: SEnQueue
SQueueFull 8692
<CODE> 1 (was CODE)
Relative segment, address: 81D4 - 8209 (0x36 bytes), align: 1
Segment part 14.
SEnQueue 81D4 AtCmdHandle (atchannel)
AtModuleState__Null (atchannel)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 812C - 8165 (0x3a bytes), align: 1
Segment part 15.
SDeQueue 812C AtModuleStateMachine (atchannel)
calls direct
DATA16_C
Relative segment, address: 493D - 4940 (0x4 bytes), align: 0
Segment part 2. Intra module refs: DeQueue
DATA16_C
Relative segment, address: 4941 - 4943 (0x3 bytes), align: 0
Segment part 3. Intra module refs: DeQueue
DATA16_C
Relative segment, address: 4944 - 4947 (0x4 bytes), align: 0
Segment part 4. Intra module refs: DeQueue
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\sysparam.r43
PROGRAM MODULE, NAME : sysparam
<CODE> 1 (was CODE)
Relative segment, address: 6514 - 668D (0x17a bytes), align: 1
Segment part 5. Intra module refs: SysParamLoadFromFlash
SysParamSetDefaultVal 6514
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 8744 - 874B (0x8 bytes), align: 1
Segment part 6. Intra module refs: InitSysParam
SysParamLoadFromFlash 8744
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 875E - 8761 (0x4 bytes), align: 1
Segment part 7.
InitSysParam 875E main (main)
calls direct
DATA16_C
Relative segment, address: 4948 - 4954 (0xd bytes), align: 0
Segment part 2. Intra module refs: SysParamSetDefaultVal
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\timedelay.r43
PROGRAM MODULE, NAME : timedelay
<CODE> 1 (was CODE)
Relative segment, address: 8414 - 8433 (0x20 bytes), align: 1
Segment part 2.
delay_sse 8414 AtCmdSend_ErrorRetry (atchannel)
MsgSend (message)
<CODE> 1 (was CODE)
Relative segment, address: 8528 - 8541 (0x1a bytes), align: 1
Segment part 3.
delay_mse 8528 LedFlash (main)
MsgSend (message)
main (main)
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\timer.r43
PROGRAM MODULE, NAME : timer
DATA16_Z
Relative segment, address: 1EA9 - 1EC9 (0x21 bytes), align: 0
Segment part 6. Intra module refs: HandleTimerEvents
ModTimer
StartTimer
TimerCallBackRegister
g_TimerEvents 1EA9 main (main)
<CODE> 1 (was CODE)
Relative segment, address: 73D4 - 74A5 (0xd2 bytes), align: 1
Segment part 7.
TimerCallBackRegister 73D4 iAppRegisterTimer (atchannel)
<CODE> 1 (was CODE)
Relative segment, address: 74A6 - 7563 (0xbe bytes), align: 1
Segment part 8.
ModTimer 74A6 AtCmdHandle (atchannel)
AtModuleState__Init (atchannel)
main (main)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 7CEA - 7D3F (0x56 bytes), align: 1
Segment part 9.
StartTimer 7CEA AtCmdHandle (atchannel)
main (main)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 5C54 - 5E57 (0x204 bytes), align: 1
Segment part 12.
HandleTimerEvents 5C54 main (main)
calls direct and indirect
DATA16_C
Relative segment, address: 4955 - 4962 (0xe bytes), align: 0
Segment part 2. Intra module refs: ModTimer
DATA16_C
Relative segment, address: 4963 - 496B (0x9 bytes), align: 0
Segment part 3. Intra module refs: ModTimer
DATA16_C
Relative segment, address: 496C - 497B (0x10 bytes), align: 0
Segment part 4. Intra module refs: StartTimer
DATA16_C
Relative segment, address: 497C - 498D (0x12 bytes), align: 0
Segment part 5. Intra module refs: HandleTimerEvents
FILE NAME : E:\Project.ext\智能水表\trunk\software\FR6989_ZNSB_RXLOOP\Debug\Obj\timer_a.r43
PROGRAM MODULE, NAME : timer_a
<CODE> 1 (was CODE)
Relative segment, address: 6F90 - 7073 (0xe4 bytes), align: 1
Segment part 4.
Timer_A_initUpMode 6F90 TIMERA_Init (main)
FILE NAME : C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\430\lib\dlib\dl430xlsfn.r43
LIBRARY MODULE, NAME : ?__dbg_break
<CODE> 1 (was CODE)
Relative segment, address: 8776 - 8777 (0x2 bytes), align: 1
Segment part 2.
__DebugBreak 8776 __exit (?__exit)
LIBRARY MODULE, NAME : ?__exit
<CODE> 1 (was CODE)
Relative segment, address: 85E0 - 85F3 (0x14 bytes), align: 1
Segment part 2.
__exit 85E0 Segment part 6 (?_exit)
_exit (?_exit)
calls direct
LIBRARY MODULE, NAME : ?atoi
<CODE> 1 (was CODE)
Relative segment, address: 8730 - 8739 (0xa bytes), align: 1
Segment part 2.
atoi 8730 MsgSettings__Handle (message)
calls direct
LIBRARY MODULE, NAME : ?_exit
<CODE> 1 (was CODE)
Relative segment, address: 8766, align: 1
Segment part 0.
_exit 8766 exit (?exit)
<CODE> 1 (was CODE)
Relative segment, address: 8766 - 8769 (0x4 bytes), align: 1
Segment part 6. Intra module refs: _exit
LIBRARY MODULE, NAME : ?cstart
CSTACK
Relative segment, address: 2000, align: 1
Segment part 1.
DATA16_Z
Relative segment, address: 1C1A, align: 1
Segment part 2.
DATA16_I
Relative segment, address: 1C00, align: 1
Segment part 3.
DATA16_ID
Relative segment, address: 49F2, align: 1
Segment part 4.
CODE_I
Relative segment, address: 1ECC, align: 1
Segment part 5.
CODE_ID
Relative segment, address: 8778, align: 1
Segment part 6.
DATA20_Z
Segment part 7.
DATA20_I
Segment part 8.
DATA20_ID
Segment part 9.
DATA20_C
Segment part 10.
DATA20_N
Segment part 12.
CSTART
Relative segment, address: 4A04 - 4A07 (0x4 bytes), align: 1
Segment part 15.
__program_start 4A04 ?reset_vector (?reset_vector)
Absolute parts (?ABS_ENTRY_MOD)
?cstart_begin 4A04
CSTART
Relative segment, address: 4A08 - 4A13 (0xc bytes), align: 1
Segment part 20.
?cstart_init_zero 4A08 Segment part 7 (?rand)
Segment part 9 (?rand)
_Randinit (?rand)
__iar_Errno (?errno)
__iar_Tls_setup__Randinit (?rand)
__iar_Tls_setup__Randseed (?rand)
gSystemTick (main)
g_AlarmInfo (main)
g_DateBuf (message)
g_DebugInfo (main)
g_ReportInfo (main)
g_RxMsg (message)
g_Settings (main)
g_SysTime (message)
g_SystemCmd (main)
g_TimerEvents (timer)
g_WaterId (main)
g_WaterInfo (main)
gp_Queue (main)
s_AtResponse (main)
s_CurrentState (atchannel)
s_DoOnlyOnce (atchannel)
s_IpdLen (atchannel)
s_Isize (atchannel)
s_Msg (message)
s_PrevState (atchannel)
s_ReportTimer (message)
s_StateQueue (atchannel)
seq (message)
sp_Queue (atchannel)
CSTART
Relative segment, address: 4A14 - 4A23 (0x10 bytes), align: 1
Segment part 21.
?cstart_init_copy 4A14 _Randseed (?rand)
initUpParam_A0 (main)
CSTART
Relative segment, address: 4A24 - 4A2B (0x8 bytes), align: 1
Segment part 27. Intra module refs: Segment part 15
?cstart_call_main 4A24
?cstart_end 4A2C
CODE_ID
Segment part 28. Intra module refs: Segment part 5
LIBRARY MODULE, NAME : ?reset_vector
RESET
Relative segment, address: FFFE - FFFF (0x2 bytes), align: 1
Segment part 0.
?reset_vector FFFE Segment part 15 (?cstart)
LIBRARY MODULE, NAME : ?div64i
<CODE> 1 (was CODE)
Relative segment, address: 7620 - 76C1 (0xa2 bytes), align: 1
Segment part 2.
_Div64u 7620 _LitobLargeNoMb (?xprintflarge_nomb)
<CODE> 1 (was CODE)
Relative segment, address: 8542 - 855B (0x1a bytes), align: 1
Segment part 4. Intra module refs: _Div64u
<CODE> 1 (was CODE)
Relative segment, address: 858C - 85A1 (0x16 bytes), align: 1
Segment part 0.
div 858C _GenldLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : ?errno
DATA16_Z
Relative segment, address: 1C1A - 1C1B (0x2 bytes), align: 1
Segment part 2.
__iar_Errno 1C1A __iar_Stoulx (?xstoul)
LIBRARY MODULE, NAME : ?exit
<CODE> 1 (was CODE)
Relative segment, address: 876E - 8771 (0x4 bytes), align: 1
Segment part 2.
exit 876E Segment part 27 (?cstart)
calls direct
LIBRARY MODULE, NAME : ?Mul32fHw32
<CODE> 1 (was CODE)
Relative segment, address: 6B88 - 6C9D (0x116 bytes), align: 1
Segment part 0.
?Mul32fHw32 6B88 _LdtobLargeNoMb (?xprintflarge_nomb)
scale (?xprintflarge_nomb)
LIBRARY MODULE, NAME : ?Cast32f32i
<CODE> 1 (was CODE)
Relative segment, address: 788C - 789F (0x14 bytes), align: 1
Segment part 0.
_Cast32sto32f 788C MsgSend (message)
<CODE> 1 (was CODE)
Relative segment, address: 78A0 - 791D (0x7e bytes), align: 1
Segment part 1. Intra module refs: _Cast32sto32f
_Cast32uto32f 78A0 _LdtobLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : _Cast32fto32u
<CODE> 1 (was CODE)
Relative segment, address: 8724 - 872F (0xc bytes), align: 1
Segment part 0.
_Cast32fto32u 8724 _LdtobLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : ?FLT_Extract
<CODE> 1 (was CODE)
Relative segment, address: 7E84 - 7ECF (0x4c bytes), align: 1
Segment part 0.
?FLT_Extract 7E84 _Cast32fto32u (_Cast32fto32u)
LIBRARY MODULE, NAME : ?FLT_LT
<CODE> 1 (was CODE)
Relative segment, address: 7D94 - 7DE5 (0x52 bytes), align: 1
Segment part 0.
?FLT_LT 7D94 _LdtobLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : _Div32f
<CODE> 1 (was CODE)
Relative segment, address: 693A - 6A69 (0x130 bytes), align: 1
Segment part 0.
_Div32f 693A MsgSend (message)
LIBRARY MODULE, NAME : _Add32f
<CODE> 1 (was CODE)
Relative segment, address: 668E - 6691 (0x4 bytes), align: 1
Segment part 0.
_Sub32f 668E _LdtobLargeNoMb (?xprintflarge_nomb)
<CODE> 1 (was CODE)
Relative segment, address: 6692 - 67F1 (0x160 bytes), align: 1
Segment part 1. Intra module refs: _Sub32f
_Add32f 6692 MsgSend (message)
LIBRARY MODULE, NAME : ?DivMod816u
<CODE> 1 (was CODE)
Relative segment, address: 855C - 8573 (0x18 bytes), align: 1
Segment part 1.
?DivMod16u 855C ?DivMod16s (?DivMod816s)
DeQueue (queue)
EnQueue (queue)
SDeQueue (queue)
SEnQueue (queue)
LIBRARY MODULE, NAME : ?DivMod816s
<CODE> 1 (was CODE)
Relative segment, address: 8270 - 829F (0x30 bytes), align: 1
Segment part 1.
?DivMod16s 8270 DumpHex (atchannel)
MsgSend (message)
div (?div)
itoa (debug)
LIBRARY MODULE, NAME : ?DivMod32u
<CODE> 1 (was CODE)
Relative segment, address: 82A0 - 82CF (0x30 bytes), align: 1
Segment part 0.
?DivMod32u 82A0 ?DivMod32s (?DivMod32s)
LIBRARY MODULE, NAME : ?DivMod32s
<CODE> 1 (was CODE)
Relative segment, address: 8032 - 8071 (0x40 bytes), align: 1
Segment part 0.
?DivMod32s 8032 _LdtobLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : ?memchr
<CODE> 1 (was CODE)
Relative segment, address: 85CC - 85DF (0x14 bytes), align: 1
Segment part 2.
__iar_Memchr 85CC _PrintfLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : ?memcpy
<CODE> 1 (was CODE)
Relative segment, address: 8618 - 8629 (0x12 bytes), align: 1
Segment part 2.
memcpy 8618 MsgReceive (message)
MsgSend (message)
Segment part 12 (?xprintflarge_nomb)
__data16_memcpy (?memzero)
LIBRARY MODULE, NAME : ?CopyMemoryBytes
<CODE> 1 (was CODE)
Relative segment, address: 86A2 - 86B1 (0x10 bytes), align: 1
Segment part 0.
?CopyMemoryBytes 86A2 itoa (debug)
LIBRARY MODULE, NAME : ?memset
<CODE> 1 (was CODE)
Relative segment, address: 863C - 864D (0x12 bytes), align: 1
Segment part 2.
memset 863C AtCmdParamZero (atchannel)
MsgSend (message)
LIBRARY MODULE, NAME : ?memzero
<CODE> 1 (was CODE)
Relative segment, address: 8682 - 8691 (0x10 bytes), align: 1
Segment part 2.
__data16_memzero 8682 ?cstart_init_zero (?cstart)
<CODE> 1 (was CODE)
Relative segment, address: 876A - 876D (0x4 bytes), align: 1
Segment part 3.
__data16_memcpy 876A ?cstart_init_copy (?cstart)
calls direct
LIBRARY MODULE, NAME : ?Mul8Hw
<CODE> 1 (was CODE)
Relative segment, address: 8474 - 8477 (0x4 bytes), align: 1
Segment part 0.
?Mul8Hw 8474 _LitobLargeNoMb (?xprintflarge_nomb)
<CODE> 1 (was CODE)
Relative segment, address: 8478 - 8493 (0x1c bytes), align: 1
Segment part 1. Intra module refs: ?Mul8Hw
?Mul16Hw 8478
?Mul16to32uHw 8478
LIBRARY MODULE, NAME : ?Mul16to32sHw
<CODE> 1 (was CODE)
Relative segment, address: 84F0 - 850B (0x1c bytes), align: 1
Segment part 0.
?Mul16to32sHw 84F0 _LdtobLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : ?Mul32Hw32
<CODE> 1 (was CODE)
Relative segment, address: 83CE - 83F1 (0x24 bytes), align: 1
Segment part 0.
?Mul32Hw32 83CE Segment part 12 (?rand)
LIBRARY MODULE, NAME : ?rand
DATA16_Z
Relative segment, address: 1ECA - 1ECA (0x1 bytes), align: 0
Segment part 2. Intra module refs: rand
_Randinit 1ECA srand (?srand)
DATA16_Z
Relative segment, address: 1C1C - 1C1F (0x4 bytes), align: 1
Segment part 3. Intra module refs: rand
1C1C srand (?srand)
DATA16_I
Relative segment, address: 1C00 - 1C03 (0x4 bytes), align: 1
Segment part 4. Intra module refs: Segment part 12
_Randseed 1C00 srand (?srand)
DATA16_Z
Relative segment, address: 1C20 - 1C23 (0x4 bytes), align: 1
Segment part 6. Intra module refs: rand
1C20 srand (?srand)
DATA16_Z
Relative segment, address: 1C24 - 1C27 (0x4 bytes), align: 1
Segment part 7. Intra module refs: rand
DATA16_Z
Relative segment, address: 1C28 - 1CA7 (0x80 bytes), align: 1
Segment part 9. Intra module refs: rand
<CODE> 1 (was CODE)
Relative segment, address: 7A3C - 7AC7 (0x8c bytes), align: 1
Segment part 11.
rand 7A3C MsgSend (message)
<CODE> 1 (was CODE)
Relative segment, address: 83A8 - 83CD (0x26 bytes), align: 1
Segment part 12. Intra module refs: rand
DATA16_ID
Relative segment, address: 49F2 - 49F5 (0x4 bytes), align: 1
Segment part 5. Intra module refs: _Randseed
LIBRARY MODULE, NAME : ?IndCallR11
<CODE> 1 (was CODE)
Relative segment, address: 8762 - 8765 (0x4 bytes), align: 1
Segment part 0.
?IndCallR11 8762 _PutcharLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : ?IndCallR15
<CODE> 1 (was CODE)
Relative segment, address: 8772 - 8775 (0x4 bytes), align: 1
Segment part 0.
?IndCallR15 8772 HandleTimerEvents (timer)
LIBRARY MODULE, NAME : ?sprintf
<CODE> 1 (was CODE)
Relative segment, address: 7F1A - 7F5F (0x46 bytes), align: 1
Segment part 2.
sprintf 7F1A MsgSettings__Handle (message)
main (main)
calls direct
LIBRARY MODULE, NAME : ?srand
<CODE> 1 (was CODE)
Relative segment, address: 820A - 823D (0x34 bytes), align: 1
Segment part 2.
srand 820A AtModuleState__UdpTransfer (atchannel)
calls indirect
LIBRARY MODULE, NAME : ?strchr
<CODE> 1 (was CODE)
Relative segment, address: 86FE - 870B (0xe bytes), align: 1
Segment part 2.
__iar_Strchr 86FE _PrintfLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : ?strlen
<CODE> 1 (was CODE)
Relative segment, address: 8660 - 8671 (0x12 bytes), align: 1
Segment part 2.
strlen 8660 AtCmdSend (atchannel)
LIBRARY MODULE, NAME : ?xdunscal
<CODE> 1 (was CODE)
Relative segment, address: 7F60 - 7FA5 (0x46 bytes), align: 1
Segment part 2.
__iar_Dunscale 7F60 _LdtobLargeNoMb (?xprintflarge_nomb)
LIBRARY MODULE, NAME : ?xprintflarge_nomb
<CODE> 1 (was CODE)
Relative segment, address: 522C - 56C3 (0x498 bytes), align: 1
Segment part 19.
_PrintfLargeNoMb 522C sprintf (?sprintf)
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 83F2 - 83F9 (0x8 bytes), align: 1
Segment part 23. Intra module refs: Segment part 26
_PrintfLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 83FA - 8401 (0x8 bytes), align: 1
Segment part 24. Intra module refs: _PrintfLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 8402 - 840D (0xc bytes), align: 1
Segment part 25. Intra module refs: Segment part 23
Segment part 24
<CODE> 1 (was CODE)
Relative segment, address: 840E - 8413 (0x6 bytes), align: 1
Segment part 26. Intra module refs: _PrintfLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 4AC2 - 4B45 (0x84 bytes), align: 1
Segment part 8. Intra module refs: _PrintfLargeNoMb
LOCAL ADDRESS
LoadInt 4AC2
<CODE> 1 (was CODE)
Relative segment, address: 4B46 - 4B53 (0xe bytes), align: 1
Segment part 9. Intra module refs: LoadInt
<CODE> 1 (was CODE)
Relative segment, address: 4B54 - 4D91 (0x23e bytes), align: 1
Segment part 10. Intra module refs: _LdtobLargeNoMb
LOCAL ADDRESS
_GenldLargeNoMb 4B54
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 4D92 - 4DA1 (0x10 bytes), align: 1
Segment part 11. Intra module refs: _GenldLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 4DA2 - 4DAF (0xe bytes), align: 1
Segment part 12. Intra module refs: Segment part 11
_GenldLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 4DB0 - 4DCD (0x1e bytes), align: 1
Segment part 13. Intra module refs: _GenldLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 4DCE - 4E0F (0x42 bytes), align: 1
Segment part 14. Intra module refs: _LdtobLargeNoMb
LOCAL ADDRESS
scale 4DCE
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 4E10 - 504D (0x23e bytes), align: 1
Segment part 15. Intra module refs: _PrintfLargeNoMb
LOCAL ADDRESS
_LdtobLargeNoMb 4E10
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 504E - 520F (0x1c2 bytes), align: 1
Segment part 16. Intra module refs: _PrintfLargeNoMb
LOCAL ADDRESS
_LitobLargeNoMb 504E
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 5210 - 5221 (0x12 bytes), align: 1
Segment part 17. Intra module refs: _LitobLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 5222 - 522B (0xa bytes), align: 1
Segment part 18. Intra module refs: LoadInt
_LitobLargeNoMb
_PrintfLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 819E - 81D3 (0x36 bytes), align: 1
Segment part 28. Intra module refs: Segment part 23
LOCAL ADDRESS
pad 819E
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 8380 - 83A7 (0x28 bytes), align: 1
Segment part 29. Intra module refs: _PrintfLargeNoMb
_PutcharsLargeNoMb
LOCAL ADDRESS
_PutcharLargeNoMb 8380
calls indirect
<CODE> 1 (was CODE)
Relative segment, address: 82FE - 8329 (0x2c bytes), align: 1
Segment part 30. Intra module refs: Segment part 24
pad
LOCAL ADDRESS
_PutcharsLargeNoMb 82FE
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 86F0 - 86FD (0xe bytes), align: 1
Segment part 20. Intra module refs: _PrintfLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 873A - 8743 (0xa bytes), align: 1
Segment part 21. Intra module refs: _PrintfLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 864E - 865F (0x12 bytes), align: 1
Segment part 22. Intra module refs: _PrintfLargeNoMb
<CODE> 1 (was CODE)
Relative segment, address: 80B2 - 80EF (0x3e bytes), align: 1
Segment part 27. Intra module refs: _PrintfLargeNoMb
DATA16_C
Relative segment, address: 498E - 4994 (0x7 bytes), align: 0
Segment part 2. Intra module refs: _PrintfLargeNoMb
DATA16_C
Relative segment, address: 4995 - 4998 (0x4 bytes), align: 0
Segment part 3. Intra module refs: _LdtobLargeNoMb
DATA16_C
Relative segment, address: 4999 - 499C (0x4 bytes), align: 0
Segment part 4. Intra module refs: _LdtobLargeNoMb
DATA16_C
Relative segment, address: 499D - 49A0 (0x4 bytes), align: 0
Segment part 5. Intra module refs: _LdtobLargeNoMb
DATA16_C
Relative segment, address: 49A1 - 49A4 (0x4 bytes), align: 0
Segment part 6. Intra module refs: _LdtobLargeNoMb
DATA16_C
Relative segment, address: 49A5 - 49A6 (0x2 bytes), align: 0
Segment part 7. Intra module refs: _GenldLargeNoMb
LIBRARY MODULE, NAME : ?xsprout
<CODE> 1 (was CODE)
Relative segment, address: 870C - 8717 (0xc bytes), align: 1
Segment part 2.
_SProut 870C sprintf (?sprintf)
LIBRARY MODULE, NAME : ?xstoul
DATA16_C
Relative segment, address: 49A7 - 49CB (0x25 bytes), align: 0
Segment part 2. Intra module refs: __iar_Stoulx
DATA16_C
Relative segment, address: 49CC - 49F0 (0x25 bytes), align: 0
Segment part 3. Intra module refs: __iar_Stoulx
<CODE> 1 (was CODE)
Relative segment, address: 638C - 6513 (0x188 bytes), align: 1
Segment part 4. Intra module refs: __iar_Stoul
__iar_Stoulx 638C
calls direct
<CODE> 1 (was CODE)
Relative segment, address: 86E2 - 86EF (0xe bytes), align: 1
Segment part 5. Intra module refs: __iar_Stoulx
<CODE> 1 (was CODE)
Relative segment, address: 8758 - 875D (0x6 bytes), align: 1
Segment part 6.
__iar_Stoul 8758 atoi (?atoi)
calls direct
* STACK USAGE *
Call Graph Root Category Max Use Total Use
interrupt 344 466
Program entry 390 390
Uncalled function 358 358
Program entry
"__program_start": 0x00004a04
Maximum call chain *?* 390 bytes
(** call graph contains indirect calls (example: "srand") **)
"__program_start" 0
"main" 8
"AtModuleStateMachine" 6
"AtModuleState__Init" [atchannel] 6
"AtCmdSend_ErrorRetry" 16
"AtCmdSend" 22
"AtCmdHandle" 12
"QueueIPDData" 20
"MsgReceive" 16
"MsgSettings__Handle" [message] 40
"sprintf" 12
"_PrintfLargeNoMb" 112
"_LdtobLargeNoMb" [?xprintflarge_nomb] 72
"_GenldLargeNoMb" [?xprintflarge_nomb] 32
"div" 6
"?DivMod16s" 6
"?DivMod16u" 4
interrupt
"TIMER0_A0_ISR": 0x00004a2c
Maximum call chain 344 bytes
"TIMER0_A0_ISR" 12
"AtCmdHandle" 12
"QueueIPDData" 20
"MsgReceive" 16
"sprintf" 12
"div" 6
"?DivMod16s" 6
"?DivMod16u" 4
interrupt
"USCI_A0_ISR": 0x00004a70
Maximum call chain 114 bytes
"USCI_A0_ISR" 16
"AtSerialPortRx" 8
"printu" 26
"itoa" 54
"?DivMod16s" 6
"?DivMod16u" 4
interrupt
"USCI_A1_ISR": 0x00004a8e
Maximum call chain 8 bytes
"USCI_A1_ISR" 8
Uncalled function
"TimerEventCallBackFunc" [atchannel]: 0x000067f2
Maximum call chain *?* 358 bytes
(** call graph contains indirect calls (example: "rand") **)
"TimerEventCallBackFunc" [atchannel] 4
"AtCmdSend" 22
"AtCmdHandle" 12
"QueueIPDData" 20
"MsgReceive" 16
"sprintf" 12
"div" 6
"?DivMod16s" 6
"?DivMod16u" 4
The following functions perform unknown indirect calls:
"HandleTimerEvents": 0x00005c54
"rand": 0x00007a3c
"srand": 0x0000820a
* SEGMENTS IN ADDRESS ORDER *
SEGMENT SPACE START ADDRESS END ADDRESS SIZE TYPE ALIGN
DATA16_AN 0130 - 0131 2 rel 0
0160 - 0167 8
0202 - 0205 4
020A - 020D 4
0224 - 0225 2
022A - 022D 4
0262 - 0265 4
026A - 026D 4
0284 - 0285 2
028A - 028D 4
0352 - 0353 2
05C0 - 05C1 2
05C6 - 05C9 4
05CC - 05CF 4
05DA - 05DD 4
05E0 - 05E1 2
05E6 - 05E9 4
05EE - 05EF 2
05FC - 05FF 4
DATA16_I 1C00 - 1C10 11 rel 1
DATA16_Z 1C12 - 1ECA 2B9 rel 1
DATA20_I 1ECC rel 1
DATA20_Z 1ECC rel 1
DATA20_N 1ECC rel 1
CODE_I 1ECC rel 1
CSTACK 2000 - 23FF 400 rel 1
DATA16_C 4400 - 49F0 5F1 rel 0
DATA16_ID 49F2 - 4A02 11 rel 1
CSTART 4A04 - 4A2B 28 rel 1
ISR_CODE 4A2C - 4AC1 96 rel 1
<CODE> 1 4AC2 - 8777 3CB6 rel 1
CODE_ID 8778 rel 1
DATA20_ID 8778 rel 1
DATA20_C 8778 rel 1
INTVEC FF90 - FFEF 60 com 1
RESET FFFE - FFFF 2 rel 1
* END OF CROSS REFERENCE *
15 830 bytes of CODE memory
1 738 bytes of DATA memory (+ 66 absolute )
1 538 bytes of CONST memory
Errors: none
Warnings: 4
