关于MSP430FR5994的UART问题
最近调试MSP430FR5994的4个串口(UART),同样的配置,UART0,1都没问题,但UART2,UART3就是没有反应,循环发送数据,用示波器测试TX脚没波形。不知这个地方有什么需要注意的吗?
  • 可以把配置代码发上来,才好看问题
  • 你用的什么封装的5994?不是所有封装都引出了所有串口io
  • uint8_t BLE_Init(uint16_t baudrate)
    // Configure UART_BLE pins EUSCI_A2_BASE
    //Set P5.4 and P5.5 as Secondary Module Function Input.
    GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P5,GPIO_PIN4 + GPIO_PIN5,
    GPIO_SECONDARY_MODULE_FUNCTION);
    // Configure UART_BLE EUSCI_A2_BASE
    EUSCI_A_UART_initParam param = {0};
    param.selectClockSource = EUSCI_A_UART_CLOCKSOURCE_SMCLK;
    param.clockPrescalar = 6;
    param.firstModReg = 8;
    param.secondModReg = 0;//92
    param.parity = EUSCI_A_UART_NO_PARITY;
    param.msborLsbFirst = EUSCI_A_UART_LSB_FIRST;
    param.numberofStopBits = EUSCI_A_UART_ONE_STOP_BIT;
    param.uartMode = EUSCI_A_UART_MODE;
    param.overSampling = EUSCI_A_UART_OVERSAMPLING_BAUDRATE_GENERATION;
    if(STATUS_FAIL == EUSCI_A_UART_init(UART_BLE, &param))
    return 0 ;
    EUSCI_A_UART_enable(UART_BLE);
    EUSCI_A_UART_clearInterrupt(UART_BLE,EUSCI_A_UART_RECEIVE_INTERRUPT);
    // Enable USCI_A2 RX interrupt EUSCI_A2_BASE
    EUSCI_A_UART_enableInterrupt(UART_BLE,EUSCI_A_UART_RECEIVE_INTERRUPT); // Enable interrupt
    // POWER_BLE On
    POWER_BLE_On;
    return 1;
    voia main(void)
    WDT_A_hold(WDT_A_BASE); // stop watchdog
    // LFXT Setup
    //Set PJ.4 and PJ.5 as Primary Module Function Input.
    * Select Port J
    * Set Pin 4, 5 to input Primary Module Function, LFXT.
    GPIO_setAsPeripheralModuleFunctionInputPin( GPIO_PORT_PJ,GPIO_PIN4 + GPIO_PIN5,
    GPIO_PRIMARY_MODULE_FUNCTION);
    //Set DCO frequency to 1 MHz
    CS_setDCOFreq(CS_DCORSEL_0,CS_DCOFSEL_0);
    //Set external clock frequency to 32.768 KHz
    CS_setExternalClockSource(32768,0);
    //Set ACLK=LFXT
    CS_initClockSignal(CS_ACLK,CS_LFXTCLK_SELECT,CS_CLOCK_DIVIDER_1);
    //Set SMCLK = DCO with frequency divider of 1
    CS_initClockSignal(CS_SMCLK,CS_DCOCLK_SELECT,CS_CLOCK_DIVIDER_1);
    //Set MCLK = DCO with frequency divider of 1
    CS_initClockSignal(CS_MCLK,CS_DCOCLK_SELECT,CS_CLOCK_DIVIDER_1);
    //Start XT1 with no time out
    CS_turnOnLFXT(CS_LFXT_DRIVE_0);//Start XT1 with no time out
    __enable_interrupt();
    while(1)
    EUSCI_A_UART_transmitData(EUSCI_A2_BASE,*pTem++);//EUSCI_A2_BASE
    __delay_cycles(1000);
  • 同样的配置方法(UART口选择不一致,端口部分初始化不一样)在UART0,UART1都能正常收发数据,但用到UART2,UART3用示波器观察发送管脚没有信号输出,换了几块板测试都是这种情况
  • 用的是80脚的封装TQFP封装,这个封装是支持4个UART的
