msp430f5529开发板上LCD的资料在哪?
Other Parts Discussed in Thread: MSP430F5529
  • 请问您具体是想了解什么信息呢?
    您可以看一下 www.ti.com.cn/.../slau330b.pdf
    The EA DOGS102W-6 is a dot-matrix LCD with a resolution of 102x64 pixels. The LCD has a built-in back-light driver that can be controlled by a PWM signal from the MSP430F5529, pin P7.6. The MSP430F5529 communicates with the EA DOGS102W-6 through an SPI-like communication protocol. To
    supplement the limited set of instructions and functionalities provided by the on-chip LCD driver, an LCD driver has been developed for the MSP430F5529 to support additional functionalities such as font set and graphical utilities. More information on the LCD can be obtained from the manufacturer's data sheet.
    LCD的数据手册可以参考 www.lcd-module.com/.../dogs102-6e.pdf
  • 这个型号的lcd在国内好像不太好买。
    做其他设计建议采用方便购买的液晶
