MSP430F5529LPADC多通道转换,怎么设置?
我在ADC12CONSEQ中选择序列通道重复转换模式,我给A0、A1送入了电压,但ADC12MEM2和ADC12MEM3也有数值,与ADC12MEM1里的数值相近。我给A0、A2送入电压,ADC12MEM1和ADC12MEM3里的数值也与ADC12MEM2里的数值相似,这是为什么?
还有我设置ADC12INCH选择模拟输入通道什么用都没有,我看没有效果,这是为什么?
还有ADC12CSTARTADDx不用按照Ax来设置吧,就是A0不是一定对应ADC12CSTARTADD0吧!  还有在单次转换里,用A0和A1,好像只使用一个ADC12CSTARTADDx就可以,不用每个A0和A1都使用一个存储寄存器吧?
  谢谢大佬们,爱你们哦!!!!!
  • 给A0、A1送入了电压的时候,A2是否在悬空?
    悬空的io电平状态会由周围的电磁环境决定。
    其他问题建议调试的时候追一下对应寄存器内数值的变化,就清楚了。
  • 请您参考下下面的代码
    /* --COPYRIGHT--,BSD_EX
     * Copyright (c) 2012, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     *    notice, this list of conditions and the following disclaimer.
     * *  Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in the
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     *    its contributors may be used to endorse or promote products derived
     *    from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *                       MSP430 CODE EXAMPLE DISCLAIMER
     * MSP430 code examples are self-contained low-level programs that typically
     * demonstrate a single peripheral function or device feature in a highly
     * concise manner. For this the code may rely on the device's power-on default
     * register values and settings such as the clock configuration and care must
     * be taken when combining code from several examples to avoid potential side
     * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
     * for an API functional library-approach to peripheral configuration.
     * --/COPYRIGHT--*/
    //  MSP430F552x Demo - ADC12, Sequence of Conversions (non-repeated)
    //  Description: This example shows how to perform A/D conversions on a sequence
    //  of channels. A single sequence of conversions is performed - one conversion
    //  each on channels A0, A1, A2, and A3. Each conversion uses AVcc and AVss for
    //  the references. The conversion results are stored in ADC12MEM0, ADC12MEM1,
    //  ADC12MEM2, and ADC12MEM3 respectively and are moved to 'results[]' upon
    //  completion of the sequence. Test by applying voltages to pins A0, A1, A2,
    //  and A3, then setting and running to a break point at the "_BIC..."
    //  instruction in the ISR. To view the conversion results, open a watch window
    //  in debugger and view 'results' or view ADC12MEM0, ADC12MEM1, ADC12MEM2, and
    //  ADC12MEM3 in an ADC12 SFR window.
    //  This can run even in LPM4 mode as ADC has its own clock
    //  Note that a sequence has no restrictions on which channels are converted.
    //  For example, a valid sequence could be A0, A3, A2, A4, A2, A1, A0, and A7.
    //  See the MSP430x5xx User's Guide for instructions on using the ADC12.
    //               MSP430F552x
    //          --|RST              |
    //    Vin0 -->|P6.0/CB0/A0      |
    //    Vin1 -->|P6.1/CB1/A1      |
    //    Vin2 -->|P6.2/CB2/A2      |
    //    Vin3 -->|P6.3/CB3/A3      |
    //   Bhargavi Nisarga
    //   Texas Instruments Inc.
    //   April 2009
    //   Built with CCSv4 and IAR Embedded Workbench Version: 4.21
    #include <msp430.h>
    volatile unsigned int results[4];           // Needs to be global in this example
                                                // Otherwise, the compiler removes it
                                                // because it is not used for anything.
    int main(void)
      WDTCTL = WDTPW+WDTHOLD;                   // Stop watchdog timer
      P6SEL = 0x0F;                             // Enable A/D channel inputs
      ADC12CTL0 = ADC12ON+ADC12MSC+ADC12SHT0_2; // Turn on ADC12, set sampling time
      ADC12CTL1 = ADC12SHP+ADC12CONSEQ_1;       // Use sampling timer, single sequence
      ADC12MCTL0 = ADC12INCH_0;                 // ref+=AVcc, channel = A0
      ADC12MCTL1 = ADC12INCH_1;                 // ref+=AVcc, channel = A1
      ADC12MCTL2 = ADC12INCH_2;                 // ref+=AVcc, channel = A2
      ADC12MCTL3 = ADC12INCH_3+ADC12EOS;        // ref+=AVcc, channel = A3, end seq.
      ADC12IE = 0x08;                           // Enable ADC12IFG.3
      ADC12CTL0 |= ADC12ENC;                    // Enable conversions
      while(1)
        ADC12CTL0 |= ADC12SC;                   // Start convn - software trigger
        __bis_SR_register(LPM4_bits + GIE);     // Enter LPM4, Enable interrupts
        __no_operation();                       // For debugger
    #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
    #pragma vector=ADC12_VECTOR
    __interrupt void ADC12ISR (void)
    #elif defined(__GNUC__)
    void __attribute__ ((interrupt(ADC12_VECTOR))) ADC12ISR (void)
    #else
    #error Compiler not supported!
    #endif
        switch(__even_in_range(ADC12IV,34))
      case  0: break;                           // Vector  0:  No interrupt
      case  2: break;                           // Vector  2:  ADC overflow
      case  4: break;                           // Vector  4:  ADC timing overflow
      case  6: break;                           // Vector  6:  ADC12IFG0
      case  8: break;                           // Vector  8:  ADC12IFG1
      case 10: break;                           // Vector 10:  ADC12IFG2
      case 12:                                  // Vector 12:  ADC12IFG3
        results[0] = ADC12MEM0;                 // Move results, IFG is cleared
        results[1] = ADC12MEM1;                 // Move results, IFG is cleared
        results[2] = ADC12MEM2;                 // Move results, IFG is cleared
        results[3] = ADC12MEM3;                 // Move results, IFG is cleared
        __bic_SR_register_on_exit(LPM4_bits);   // Exit active CPU, SET BREAKPOINT HERE
      case 14: break;                           // Vector 14:  ADC12IFG4
      case 16: break;                           // Vector 16:  ADC12IFG5
      case 18: break;                           // Vector 18:  ADC12IFG6
      case 20: break;                           // Vector 20:  ADC12IFG7
      case 22: break;                           // Vector 22:  ADC12IFG8
      case 24: break;                           // Vector 24:  ADC12IFG9
      case 26: break;                           // Vector 26:  ADC12IFG10
      case 28: break;                           // Vector 28:  ADC12IFG11
      case 30: break;                           // Vector 30:  ADC12IFG12
      case 32: break;                           // Vector 32:  ADC12IFG13
      case 34: break;                           // Vector 34:  ADC12IFG14
      default: break;
