BCSCTL3 |= LFXT1S_2; // LFXT1 = VLO
TACCTL0 = CCIE; // TACCR0 interrupt enabled
TACCR0 = 12000; // ~1 second
TACTL = TASSEL_1 + MC_1; // ACLK, upmode
ACLK对应的是32K的晶振时钟源,12000为什么对应1s呢,求解答
// THIS PROGRAM IS PROVIDED "AS IS". TI MAKES NO WARRANTIES OR
// REPRESENTATIONS, EITHER EXPRESS, IMPLIED OR STATUTORY,
// INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS
// FOR A PARTICULAR PURPOSE, LACK OF VIRUSES, ACCURACY OR
// COMPLETENESS OF RESPONSES, RESULTS AND LACK OF NEGLIGENCE.
// TI DISCLAIMS ANY WARRANTY OF TITLE, QUIET ENJOYMENT, QUIET
// POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY
// INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO THE PROGRAM OR
// YOUR USE OF THE PROGRAM.
// IN NO EVENT SHALL TI BE LIABLE FOR ANY SPECIAL, INCIDENTAL,
// CONSEQUENTIAL OR INDIRECT DAMAGES, HOWEVER CAUSED, ON ANY
// THEORY OF LIABILITY AND WHETHER OR NOT TI HAS BEEN ADVISED
// OF THE POSSIBILITY OF SUCH DAMAGES, ARISING IN ANY WAY OUT
// OF THIS AGREEMENT, THE PROGRAM, OR YOUR USE OF THE PROGRAM.
// EXCLUDED DAMAGES INCLUDE, BUT ARE NOT LIMITED TO, COST OF
// REMOVAL OR REINSTALLATION, COMPUTER TIME, LABOR COSTS, LOSS
// OF GOODWILL, LOSS OF PROFITS, LOSS OF SAVINGS, OR LOSS OF
// USE OR INTERRUPTION OF BUSINESS. IN NO EVENT WILL TI'S
// AGGREGATE LIABILITY UNDER THIS AGREEMENT OR ARISING OUT OF
// YOUR USE OF THE PROGRAM EXCEED FIVE HUNDRED DOLLARS
// (U.S.$500).
// Unless otherwise stated, the Program written and copyrighted
// by Texas Instruments is distributed as "freeware". You may,
// only under TI's copyright in the Program, use and modify the
// Program without any charge or restriction. You may
// distribute to third parties, provided that you transfer a
// copy of this license to the third party and the third party
// agrees to these terms by its first use of the Program. You
// must reproduce the copyright notice and any other legend of
// ownership on each copy or partial copy, of the Program.
// You acknowledge and agree that the Program contains
// copyrighted material, trade secrets and other TI proprietary
// information and is protected by copyright laws,
// international copyright treaties, and trade secret laws, as
// well as other intellectual property laws. To protect TI's
// rights in the Program, you agree not to decompile, reverse
// engineer, disassemble or otherwise translate any object code
// versions of the Program to a human-readable form. You agree
// that in no event will you alter, remove or destroy any
// copyright notice included in the Program. TI reserves all
// rights not specifically granted under this license. Except
// as specifically provided herein, nothing in this agreement
// shall be construed as conferring by implication, estoppel,
// or otherwise, upon you, any license or other right under any
// TI patents, copyrights or trade secrets.
// You may not use the Program in non-TI devices.
// eZ430-RF2500 Temperature Sensor Access Point
// Description: This is the Access Point software for the eZ430-2500RF
// Temperature Sensing demo
// L. Westlund
// Version 1.02
// Texas Instruments, Inc
// November 2007
// Built with IAR Embedded Workbench Version: 4.09A
//Change Log:
//Version: 1.02
//Comments: Changed Port toggling to abstract method
// Removed ToggleLED
// Fixed comment typos/errors
// Changed startup string to 1.02
//Version: 1.01
//Comments: Added support for SimpliciTI 1.0.3
// Changed RSSI read method
// Added 3 digit temperature output for 100+F
// Changed startup string to 1.01
//Version: 1.00
//Comments: Initial Release Version
#include "bsp.h"
#include "mrfi.h"
#include "bsp_leds.h"
#include "bsp_buttons.h"
#include "nwk_types.h"
#include "nwk_api.h"
#include "nwk_frame.h"
#include "nwk.h"
#include "msp430x22x4.h"
#include "vlo_rand.h"
#define MESSAGE_LENGTH 3
void TXString( char* string, int length );
void MCU_Init(void);
void transmitData(int addr, signed char rssi, char msg[MESSAGE_LENGTH] );
void transmitDataString(char addr[4],char rssi[3], char msg[MESSAGE_LENGTH]);
void createRandomAddress();
//data for terminal output
const char splash[] = {"\r\n--------------------------------------------------\r\n ****\r\n **** eZ430-RF2500\r\n ******o**** Temperature Sensor Network\r\n********_///_**** Copyright 2007\r\n ******/_//_/***** Texas Instruments Incorporated\r\n ** ***(__/***** All rights reserved.\r\n ********* Version 1.02\r\n *****\r\n ***\r\n--------------------------------------------------\r\n"};
__no_init volatile int tempOffset @ 0x10F4; // Temperature offset set at production
__no_init volatile char Flash_Addr[4] @ 0x10F0; // Flash address set randomly
// reserve space for the maximum possible peer Link IDs
static linkID_t sLID[NUM_CONNECTIONS];
static uint8_t sNumCurrentPeers;
// callback handler
static uint8_t sCB(linkID_t);
// work loop semaphores
static uint8_t sPeerFrameSem;
static uint8_t sJoinSem;
static uint8_t sSelfMeasureSem;
// mode data verbose = default, deg F = default
char verboseMode = 1;
char degCMode = 0;
void main (void)
addr_t lAddr;
bspIState_t intState;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
// delay loop to ensure proper startup before SimpliciTI increases DCO
// This is typically tailored to the power supply used, and in this case
// is overkill for safety due to wide distribution.
volatile int i;
for(i = 0; i < 0xFFFF; i++){}
if( CALBC1_8MHZ == 0xFF ) // Do not run if cal values are erased
volatile int i;
P1DIR |= 0x03;
BSP_TURN_ON_LED1();
BSP_TURN_OFF_LED2();
while(1)
for(i = 0; i < 0x5FFF; i++){}
BSP_TOGGLE_LED2();
BSP_TOGGLE_LED1();
BSP_Init();
if( Flash_Addr[0] == 0xFF &&
Flash_Addr[1] == 0xFF &&
Flash_Addr[2] == 0xFF &&
Flash_Addr[3] == 0xFF )
createRandomAddress(); // set Random device address at initial startup
lAddr.addr[0]=Flash_Addr[0];
lAddr.addr[1]=Flash_Addr[1];
lAddr.addr[2]=Flash_Addr[2];
lAddr.addr[3]=Flash_Addr[3];
SMPL_Ioctl(IOCTL_OBJ_ADDR, IOCTL_ACT_SET, &lAddr);
MCU_Init();
//Transmit splash screen and network init notification
TXString( (char*)splash, sizeof splash);
TXString( "\r\nInitializing Network....", 26 );
SMPL_Init(sCB);
// network initialized
TXString( "Done\r\n", 6);
// main work loop
while (1)
// Wait for the Join semaphore to be set by the receipt of a Join frame from a
// device that supports and End Device.
if (sJoinSem && (sNumCurrentPeers < NUM_CONNECTIONS))
// listen for a new connection
SMPL_LinkListen(&sLID[sNumCurrentPeers]);
sNumCurrentPeers++;
BSP_ENTER_CRITICAL_SECTION(intState);
if (sJoinSem)
sJoinSem--;
BSP_EXIT_CRITICAL_SECTION(intState);
// if it is time to measure our own temperature...
if(sSelfMeasureSem)
char msg [6];
char addr[] = {"HUB0"};
char rssi[] = {"000"};
int degC, volt;
volatile long temp;
int results[2];
ADC10CTL1 = INCH_10 + ADC10DIV_4; // Temp Sensor ADC10CLK/5
ADC10CTL0 = SREF_1 + ADC10SHT_3 + REFON + ADC10ON + ADC10IE + ADC10SR;
for( degC = 240; degC > 0; degC-- ); // delay to allow reference to settle
ADC10CTL0 |= ENC + ADC10SC; // Sampling and conversion start
__bis_SR_register(CPUOFF + GIE); // LPM0 with interrupts enabled
results[0] = ADC10MEM;
ADC10CTL0 &= ~ENC;
ADC10CTL1 = INCH_11; // AVcc/2
ADC10CTL0 = SREF_1 + ADC10SHT_2 + REFON + ADC10ON + ADC10IE + REF2_5V;
results[1] = ADC10MEM;
ADC10CTL0 &= ~ENC;
ADC10CTL0 &= ~(REFON + ADC10ON); // turn off A/D to save power
// oC = ((A10/1024)*1500mV)-986mV)*1/3.55mV = A10*423/1024 - 278
// the temperature is transmitted as an integer where 32.1 = 321
// hence 4230 instead of 423
temp = results[0];
degC = (((temp - 673) * 4230) / 1024);
if( tempOffset != 0xFFFF )
degC += tempOffset;
temp = results[1];
volt = (temp*25)/512;
msg[0] = degC&0xFF;
msg[1] = (degC>>8)&0xFF;
msg[2] = volt;
transmitDataString(addr, rssi, msg );
BSP_TOGGLE_LED1();
sSelfMeasureSem = 0;
// Have we received a frame on one of the ED connections?
// No critical section -- it doesn't really matter much if we miss a poll
if (sPeerFrameSem)
uint8_t msg[MAX_APP_PAYLOAD], len, i;
// process all frames waiting
for (i=0; i<sNumCurrentPeers; ++i)
if (SMPL_Receive(sLID[i], msg, &len) == SMPL_SUCCESS)
ioctlRadioSiginfo_t sigInfo;
sigInfo.lid = sLID[i];
SMPL_Ioctl(IOCTL_OBJ_RADIO, IOCTL_ACT_RADIO_SIGINFO, (void *)&sigInfo);
transmitData( i, (signed char)sigInfo.sigInfo[0], (char*)msg );
BSP_TOGGLE_LED2();
sPeerFrameSem--;
unsigned int rand, rand2;
do
rand = TI_getRandomIntegerFromVLO(); // first byte can not be 0x00 of 0xFF
while( (rand & 0xFF00)==0xFF00 || (rand & 0xFF00)==0x0000 );
rand2 = TI_getRandomIntegerFromVLO();
BCSCTL1 = CALBC1_1MHZ; // Set DCO to 1MHz
DCOCTL = CALDCO_1MHZ;
FCTL2 = FWKEY + FSSEL0 + FN1; // MCLK/3 for Flash Timing Generator
FCTL3 = FWKEY + LOCKA; // Clear LOCK & LOCKA bits
FCTL1 = FWKEY + WRT; // Set WRT bit for write operation
Flash_Addr[0]=(rand>>8) & 0xFF;
Flash_Addr[1]=rand & 0xFF;
Flash_Addr[2]=(rand2>>8) & 0xFF;
Flash_Addr[3]=rand2 & 0xFF;
FCTL1 = FWKEY; // Clear WRT bit
FCTL3 = FWKEY + LOCKA + LOCK; // Set LOCK & LOCKA bit
char addrString[4];
char rssiString[3];
volatile signed int rssi_int;
addrString[0] = '0';
addrString[1] = '0';
addrString[2] = '0'+(((addr+1)/10)%10);
addrString[3] = '0'+((addr+1)%10);
rssi_int = (signed int) rssi;
rssi_int = rssi_int+128;
rssi_int = (rssi_int*100)/256;
rssiString[0] = '0'+(rssi_int%10);
rssiString[1] = '0'+((rssi_int/10)%10);
rssiString[2] = '0'+((rssi_int/100)%10);
transmitDataString( addrString, rssiString, msg );
void transmitDataString(char addr[4],char rssi[3], char msg[MESSAGE_LENGTH] )
char temp_string[] = {" XX.XC"};
int temp = msg[0] + (msg[1]<<8);
if( !degCMode )
temp = (((float)temp)*1.8)+320;
temp_string[5] = 'F';
if( temp < 0 )
temp_string[0] = '-';
temp = temp * -1;
else if( ((temp/1000)%10) != 0 )
temp_string[0] = '0'+((temp/1000)%10);
temp_string[4] = '0'+(temp%10);
temp_string[2] = '0'+((temp/10)%10);
temp_string[1] = '0'+((temp/100)%10);
if( verboseMode )
char output_verbose[] = {"\r\nNode:XXXX,Temp:-XX.XC,Battery:X.XV,Strength:XXX%,RE:no "};
output_verbose[46] = rssi[2];
output_verbose[47] = rssi[1];
output_verbose[48] = rssi[0];
output_verbose[17] = temp_string[0];
output_verbose[18] = temp_string[1];
output_verbose[19] = temp_string[2];
output_verbose[20] = temp_string[3];
output_verbose[21] = temp_string[4];
output_verbose[22] = temp_string[5];
output_verbose[32] = '0'+(msg[2]/10)%10;
output_verbose[34] = '0'+(msg[2]%10);
output_verbose[7] = addr[0];
output_verbose[8] = addr[1];
output_verbose[9] = addr[2];
output_verbose[10] = addr[3];
TXString(output_verbose, sizeof output_verbose );
else
char output_short[] = {"\r\n$ADDR,-XX.XC,V.C,RSI,N#"};
output_short[19] = rssi[2];
output_short[20] = rssi[1];
output_short[21] = rssi[0];
output_short[8] = temp_string[0];
output_short[9] = temp_string[1];
output_short[10] = temp_string[2];
output_short[11] = temp_string[3];
output_short[12] = temp_string[4];
output_short[13] = temp_string[5];
output_short[15] = '0'+(msg[2]/10)%10;
output_short[17] = '0'+(msg[2]%10);
output_short[3] = addr[0];
output_short[4] = addr[1];
output_short[5] = addr[2];
output_short[6] = addr[3];
TXString(output_short, sizeof output_short );
int pointer;
for( pointer = 0; pointer < length; pointer++)
volatile int i;
UCA0TXBUF = string[pointer];
while (!(IFG2&UCA0TXIFG)); // USCI_A0 TX buffer ready?
void MCU_Init()
BCSCTL1 = CALBC1_8MHZ; // Set DCO
DCOCTL = CALDCO_8MHZ;
P3SEL |= 0x30; // P3.4,5 = USCI_A0 TXD/RXD
UCA0CTL1 = UCSSEL_2; // SMCLK
UCA0BR0 = 0x41; // 9600 from 8Mhz
UCA0BR1 = 0x3;
UCA0MCTL = UCBRS_2;
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
__enable_interrupt();
* Runs in ISR context. Reading the frame should be done in the
* application thread not in the ISR thread.
static uint8_t sCB(linkID_t lid)
if (lid)
sPeerFrameSem++;
else
sJoinSem++;
// leave frame to be read by application.
return 0;
* ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
__bic_SR_register_on_exit(CPUOFF); // Clear CPUOFF bit from 0(SR)
* Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void)
sSelfMeasureSem = 1;
* USCIA interrupt service routine
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
char rx = UCA0RXBUF;
if ( rx == 'V' || rx == 'v' )
verboseMode = 1;
else if ( rx == 'M' || rx == 'm' )
verboseMode = 0;
else if ( rx == 'F' || rx == 'f' )
degCMode = 0;
else if ( rx == 'C' || rx == 'c' )
degCMode = 1;
EZ430-RF2500这套组件原始代码里面demo.AP.c里面的程序,谢谢了Susan Yang 说:请给出完整程序以及出处
