Other Parts Discussed in Thread: MSP430FR2422
您好
MSP430FR2422 PROGRAM FRAM 位址從 0xE300 開始執行.
FRAM : origin = 0xE300, length = 0x1C80
可是
TI 原廠範例msp430fr2422_fram_protection_offset.c 寫入512 int(DATA) 到 0xE300.
我的疑問是? program code 不是就已經被DATA覆蓋消失?
您好
可是
您可以参考一下该程序的说明部分,是有说明的
//****************************************************************************** // MSP430FR2522 MSP430FR2422 Memory Protection Offset Configuration Example // // Description: Configure FRWPOAx bits in SYSCFG0 register to unprotect // n*1KB(n = 1,2,...7) program FRAM. The rest of program FRAM is // protected by PFWP bit in SYSCFG0 register. // In this example, n = 1; Unprotect FRAM from 0xE300 to 0xE6FF // // Step by Step configuration in CCS: // 1. Replace ¡°FRAM: origin = 0xE300, length = 0x1C80¡± with // ¡°FRAM: origin = 0xE700, length = 0x1880¡± in // lnk_msp430fr2x22.cmd file // 2. Configure SYSCFG0 register in user code // ¡°SYSCFG0 = FRWPPW + FRWPOA0 + DFWP + PFWP;¡± // // Step by Step configuration in IAR: // 1. Replace all ¡°0xE300¡± with ¡°0xE700¡± in lnk430fr2x22.xcl file // 2. Configure SYSCFG0 register in user code // ¡°SYSCFG0 = FRWPPW + FRWPOA0 + DFWP + PFWP;¡± // // Ling Zhu // Texas Instruments Inc. // July 2017 // Built with Code Composer Studio v7.2.0 //******************************************************************************
