CS_DAP_0: Failed Board Reset: (Error -615 @ 0x0) The target failed to see a correctly formatted SWD header. The connection to the target may be unreliable. Try lowering the TCLK setting before trying again. (Emulation package 9.2.0.00002)
发现使用其他好的芯片的仿真器调试的结果还是出现:Error -615 @ 0x0)这个错误。用本芯片的仿真器调试其他芯片结果正常。
