Other Parts Discussed in Thread: MSP430F6638
编译MSP430F6638的TFT彩屏实验是出现警告:This project was created using a version of compiler that is not currently installed: 4.0.0 [MSP430]. Another version of the compiler will be used during build: 4.1.5. Please install the compiler of the required version, or migrate the project to one of the available compiler versions by adjusting project properties. Lab07-2a_TFT properties Problems。TFT彩屏一直是黑屏,不能正常显示,不知道是因为程序问题,还是编译问题
