ccs无法安装
官网上下的ccs安装到一半,弹出个错误提示窗大致意思是最有可能导致失败的原因是1.杀毒软件阻止安装2.网络连接中断。
以下是安装记录开始出现“failed”到结束的部分,我看不懂。安装记录在附件里
02/05/2014 19:12:16PM - ** Checking to see if C:\ti/ccsv5/eclipse/ccs_config.xml.bk exists
02/05/2014 19:12:16PM - Condition failed
02/05/2014 19:12:16PM - Skipping action 8DC9C68D-0C93-432C-9F50-9ECCB01EE7D2 - Rename Config File - conditions failed
02/05/2014 19:12:16PM - Checking conditions for 399F1ECF-EE97-4986-B49B-AFBAAA32EEB7 - Rename Update Installer - Before Action is Executed
02/05/2014 19:12:16PM - Checking condition 6C4DE03E-6713-48F2-82B8-822120A43BE6 - String Is Condition
02/05/2014 19:12:16PM - Checking to see if <%UpdateMode%> is true
02/05/2014 19:12:16PM - ** Checking to see if 0 is true
02/05/2014 19:12:16PM - Skipping action 399F1ECF-EE97-4986-B49B-AFBAAA32EEB7 - Rename Update Installer - conditions failed
02/05/2014 19:12:16PM - Checking conditions for BFD51AB7-3ADC-495B-8102-3465FBB334B3 - Message Box - Before Action is Executed
02/05/2014 19:12:16PM - Checking condition D4BB77EC-B3CA-4A9A-8817-3D84D19B7811 - String Is Condition
02/05/2014 19:12:16PM - Checking to see if <%GuiMode%> is true
02/05/2014 19:12:16PM - ** Checking to see if 1 is true
02/05/2014 19:12:16PM - Condition passed
02/05/2014 19:12:16PM - Checking condition EBE9B8A8-38F1-4848-BCAD-5D7C7C548025 - String Is Condition
02/05/2014 19:12:16PM - Skipping action BFD51AB7-3ADC-495B-8102-3465FBB334B3 - Message Box - conditions failed
02/05/2014 19:12:16PM - Checking conditions for 05EE68FE-6C93-4340-82C2-21CF20CE1591 - Create Update.txt - Before Action is Executed
02/05/2014 19:12:16PM - Checking condition C8AE338B-8D17-4EDB-99A9-313C01CA352A - String Is Condition
02/05/2014 19:12:16PM - Checking to see if <%updates_found%> is true
02/05/2014 19:12:16PM - ** Checking to see if false is true
02/05/2014 19:12:16PM - Skipping action 05EE68FE-6C93-4340-82C2-21CF20CE1591 - Create Update.txt - conditions failed
02/05/2014 19:12:16PM - Checking conditions for 1160585F-F26F-4111-911E-B0D10C849C31 - Remove .ij_running.txt - Before Action is Executed
02/05/2014 19:12:16PM - Checking condition 588D69A8-22C4-4BE8-A09F-5123D47D7FEF - File Exists Condition
02/05/2014 19:12:16PM - Checking to see if <%EclipseDir%>/downloads/.ijrunning.txt exists
02/05/2014 19:12:16PM - ** Checking to see if C:\ti/ccsv5/eclipse/downloads/.ijrunning.txt exists
02/05/2014 19:12:16PM - Skipping action 1160585F-F26F-4111-911E-B0D10C849C31 -
Remove .ij_running.txt - conditions failed
  • mo wang,
    你把CCS安装文件都下下来之后再安装,就是下载那个Off-line Installers, 链接为:http://processors.wiki.ti.com/index.php/Download_CCS
    这样在安装过程中没有网也没有关系。
    然后在安装时,试着关闭杀毒软件和防火墙,可能会有冲突。另外,如果你只用MSP430的话,就只选MSP430相关即可,装的快。
    希望对你有帮助!O(∩_∩)O~
    BR,
    Lina
  • 你好,我也遇到相同的问题,请问你解决了吗?怎么解决的?望指教
