为什么ADC12设置为多次转换模式时只能进行一次转换
Other Parts Discussed in Thread: MSP430F149
 ADC12CTL0 &= ~ENC;
ADC12CTL1 = SHP+CO,NSEQ_2+ADC12SSEL_3+ADC12DIV_7;
 ADC12MCTL0 = INCH_10+SREF_1+MSC;
 ADC12CTL0 = SHT0_8+ADC12ON+REFON+REF2_5V;
ADC12IE = 0x0001;
_EINT();
 ADC12CTL0 |= ENC;
 ADC12CTL0 |= ADC12SC;
中断程序
  vol=ADC12MEM[0];
 vol=vol/4095*2.5;
num++;
_BIC_SR_IRQ(LPM0_bits);
通过液晶显示得num永远为1 vol=1.09XX;
感觉就是中断只进入了一次就再也没发生中断了
  • Hi xiaolong,
       你需要配置是基于sequence的采样吗?是单次的还是多次循环的采样?
    在我们的CCS里面有相关的例程,可以供你参考。
    /* --COPYRIGHT--,BSD_EX
    * Copyright (c) 2012, Texas Instruments Incorporated
    * All rights reserved.
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions
    * are met:
    * * Redistributions of source code must retain the above copyright
    * notice, this list of conditions and the following disclaimer.
    * * Redistributions in binary form must reproduce the above copyright
    * notice, this list of conditions and the following disclaimer in the
    * documentation and/or other materials provided with the distribution.
    * * Neither the name of Texas Instruments Incorporated nor the names of
    * its contributors may be used to endorse or promote products derived
    * from this software without specific prior written permission.
    * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
    * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
    * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
    * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
    * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
    * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
    * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
    * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
    * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
    * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
    * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    * MSP430 CODE EXAMPLE DISCLAIMER
    * MSP430 code examples are self-contained low-level programs that typically
    * demonstrate a single peripheral function or device feature in a highly
    * concise manner. For this the code may rely on the device's power-on default
    * register values and settings such as the clock configuration and care must
    * be taken when combining code from several examples to avoid potential side
    * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
    * for an API functional library-approach to peripheral configuration.
    * --/COPYRIGHT--*/
    // MSP-FET430P140 Demo - ADC12, Repeated Sequence of Conversions
    // Description: This example shows how to perform a repeated sequence of
    // conversions using "repeat sequence-of-channels" mode. AVcc is used for the
    // reference and repeated sequence of conversions is performed on Channels A0,
    // A1, A2, and A3. Each conversion result is stored in ADC12MEM0, ADC12MEM1,
    // ADC12MEM2, and ADC12MEM3 respectively. After each sequence, the 4 conversion
    // results are moved to A0results[], A1results[], A2results[], and A3results[].
    // Test by applying voltages to channels A0 - A3. Open a watch window in
    // debugger and view the results. Set a breakpoint in the last line to see the
    // array values change sequentially.
    // Note that a sequence has no restrictions on which channels are converted.
    // For example, a valid sequence could be A0, A3, A2, A4, A2, A1, A0, and A7.
    // See the MSP430x1xx User's Guide for instructions on using the ADC12.
    // MSP430F149
    // Vin0 -->|P6.0/A0 |
    // Vin1 -->|P6.1/A1 |
    // Vin2 -->|P6.2/A2 |
    // Vin3 -->|P6.3/A3 |
    // M. Mitchell
    // Texas Instruments Inc.
    // Feb 2005
    // Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.21A
    #include <msp430.h>
    #define Num_of_Results 8
    static unsigned int A0results[Num_of_Results]; // These need to be global in
    static unsigned int A1results[Num_of_Results]; // this example. Otherwise, the
    static unsigned int A2results[Num_of_Results]; // compiler removes them because
    static unsigned int A3results[Num_of_Results]; // they are not used
    int main(void)
    WDTCTL = WDTPW+WDTHOLD; // Stop watchdog timer
    P6SEL = 0x0F; // Enable A/D channel inputs
    ADC12CTL0 = ADC12ON+MSC+SHT0_8; // Turn on ADC12, extend sampling time
    // to avoid overflow of results
    ADC12CTL1 = SHP+CONSEQ_3; // Use sampling timer, repeated sequence
    ADC12MCTL0 = INCH_0; // ref+=AVcc, channel = A0
    ADC12MCTL1 = INCH_1; // ref+=AVcc, channel = A1
    ADC12MCTL2 = INCH_2; // ref+=AVcc, channel = A2
    ADC12MCTL3 = INCH_3+EOS; // ref+=AVcc, channel = A3, end seq.
    ADC12IE = 0x08; // Enable ADC12IFG.3
    ADC12CTL0 |= ENC; // Enable conversions
    ADC12CTL0 |= ADC12SC; // Start conversion
    __bis_SR_register(LPM0_bits + GIE); // Enter LPM0, Enable interrupts
    #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
    #pragma vector=ADC12_VECTOR
    __interrupt void ADC12ISR (void)
    #elif defined(__GNUC__)
    void __attribute__ ((interrupt(ADC12_VECTOR))) ADC12ISR (void)
    #else
    #error Compiler not supported!
    #endif
    static unsigned int index = 0;
    A0results[index] = ADC12MEM0; // Move A0 results, IFG is cleared
    A1results[index] = ADC12MEM1; // Move A1 results, IFG is cleared
    A2results[index] = ADC12MEM2; // Move A2 results, IFG is cleared
    A3results[index] = ADC12MEM3; // Move A3 results, IFG is cleared
    index = (index+1)%Num_of_Results; // Increment results index, modulo; Set Breakpoint here
    ken
  • 请参考MSP430ware里面的例程
  • 谢谢。我调试下。
