I want to clear that the value of CAP of reset circuit for F425. 0.1uF is OK( because F425 only support 4wire JTAG but not SBW )? 2.2nF is also OK? Which document talk about it?
Thanks a lot!
Thanks a lot!
There is no SBW in MSP430F425/MSP430F425A, you could check the user guide, user guide will tell you if the device contain sbw or not.
2.2nf is also ok, you could make the design by the PCB layout, and download check after PCB is prepared.
