msp430f415 硬件仿真问题
芯片是F415,设置断点, 就一个十几行的小程序。
用FET硬件仿真调试程序,在单步执行一条if语句时,执行不下去,出现以下提示.
Fri May 23 14:45:34 2014: Failed to set hardware breakpoint. All available resources are already in use.
Fri May 23 14:45:34 2014: Virtual breakpoints can be enabled in Options dialog under Debugger->FET Debugger->Breakpoints
Fri May 23 14:45:34 2014: Performance warning: Lack of breakpoints forces single-stepping.
请问这是为什么呢?看了说明书,看不明白,急求怎么解决?!!
